Might Bid on a 16g today,,Will this work on a 1g
BOBS90TURBO
581
5
Sep 18, 2002
Tulsa, Oklahoma
I know it will work as far as bolting to my 2g manifold but I need to know what I would have to do to get it to bolt up and work as a normal wastgate setup, as you can see in the pic, the wastgate outlet has been blocked off.
Also will the actuator off my 14b work on this big 16??? And all together how many parts would I need to get to make it work like a normal setup. And yes I have the all the support mods allready installed, all I need is a bigger turbo. Thanks
http://www.obsidiansales.com/graphics/alcoa/DSC06378.JPG
The guy selling it says it's a Big 16g and it will bolt up to a 1g dsm.
The housing says td-05 and the housing looks like it should bolt to my exhaust manifold.
If I bought it, could I buy a 02 housing that would fit and open up the internal waste gate and it would work then, If I got it cheap enough would it be worth the trouble of all that.
that is deffinately not a Big16G...it looks like a 14b...the compressor fin sizes are supposed to alternate big/small on the 16g's.
It is not a 16g and it is not for a 1g dsm. The 16g has staggered fins on the copressor wheel and the exhaust housing is larger than that. You can bid but dont complain here when you get it and learn that it is not what you were told it was. Like I said, it looks like a 14b for a 3kgt. Thats whay there is 2 of them in the pic.
Yep, it'll bolt up to your exhaust manifold...
As far as the O2 housing, it looks like you might need some type of weird gasket surface to get it to seal. The wastegate is definitely blocked off.
It may be as simple as removing that metal plate to use the internal wastegate... not sure though.
Oh yeah, and that's a 14b.
Thanks for all the help,,, I will keep looking for one,,, I feel sorry for the person that gets stuck with it,,I emailed the seller and he says it is a big 16g for sure. :thumbdown
