- 2,020
- 29
- Nov 10, 2002
Raleigh,
North Carolina
Has anyone bothered to check the flatness of both the cylinder head and the block when installing the new MLS headgasket? Also, what kind of cleaning methods were used when removing the old gasket material from both the block and head?
I have little experience with the turbo cars and no head gasket experience with them. However, I am quite familiar with the Chrysler 2.0 SOHC, DOHC and 2.4L DOHC headgasket repair procedures as I am a tech at a chrysler dealership.
The only time I see any failures with the MLS headgasket is when people do shotty work cleaning of the old gasket, if they even bother to do the job properly. I've seen many people drain the coolant, take off the valve cover, take out the head bolts just far enough to raise the head, slide out the old gasket and slide in the new one. Cleaning NONE of the old gasket material off. Common problems include coolant leaks, oil leaks, and I've even seen one destroy the engine by starving the head for oil.
Intentional fraud asside... there's the improper cleaning methods and lack of inspection and mis-diagnosis that can add to more head gasket problems.
http://www.carolinadsm.com/cgi-bin/ikonboard.cgi?;act=ST;f=16;t=2
Above is the technical service bulliten regarding the proper methods for cleaning the gasket material off.
I ask because I'm curious, not trying to bash or point fingers. I just haven't seen the MLS gaskets fail and if they have been... I'd like more info on them and what other info supports the fact/opinion that the gasket was to blame.
Thanks,
Doug
Thanks,
Doug
