Messed up spark plug thread
sherwinz28
219
3
Aug 25, 2004
Hayward, California
Well I did a search and I believe I may need a Heli Coil kit. Story: I got my cylinder head back and I believe it may not be the cylinder head I sent out. In any case I tried to put my spark plugs back in and one of them won't go in at all. I went and bought a 14mm tap kit and its way to big. I tried to just start the tap...maybe 4 turns so I could get the the spark plug to start turning in the head. The spark plug did start turning but its incredibly hard to turn. I think I may have messed up the thread even more. I've never used a tap/dieV kit(until now) or a heli coil kit. What size kit do I need from this list:
http://www.napaonline.com/cgi-bin/ncommerce3/ExecMacro/NAPAonline/search_results_kw.d2w/report
Thanks
Ok the link doesn't work but just do a search for "Heli Coil" kit and select "Heli Coil Tap"?
That looks just like the tap kit I bought. So if I use that I will always have to use that insert whenever I change plugs? In other words the insert stays there in the head, correct? The one I have is the 14mm but it looks like it will take a lot of material out of the head. It doesn't say its a heli coil, though...it says tap kit.
Wouldn't be a bad idea to get a magent in there to get all the shavings and such either.
Be sure to use one of those NASA aluminum-attracting magnets.
I think the head's off, according to the poster. Otherwise, use grease on the tap to hold the chips.
I wish I would've checked all the threads before I put the head on but I didn't...lesson learned. I do have a pencil type magnet thing I use to pick up nuts and bolts I drop in the engine bay. I was going to use some 30w oil while I tap the hole and then some red loctite when I insert the "insert" with the plug into the spark plug hole. I'm a little scared but hopefully it will be ok. I'll try to vacuum/blow out all the extra metal shavings that I can and use the magnet as well. If you've got any more advice I'm all ears. I do have an air compressor to blow air in the hole.
Aluminum isn't magnetic. Thus the wise comment on the NASA magnet. it's cheaper to pull the head than to score a cylinder and end up doing a rebuild just down the road cause of a metal flake that got caught in the ring.
Haha oops, wasn't thinking. Oh defiant your witty, wise ass remarks never get old.
Thanks guys I tapped the hole and got the insert in there. The plug is in there but now there are other problems. I will post in the correct forum for this next problem though...once again thanks for the help.
