Megan Racing Exhaust and N1 Downpipe
xrobbx03
164
Jul 25, 2005
., Massachusetts
I have a 1997 GST and my apex N1 is falling apart on me. Had it about 7 years now. There is a monster hole in the muffler itself and other smaller holes. The N1 downpipe i have is still good, recently had the flex pipe redone which was leaking and added a high flow cat to it for emissions reasons.
My questions is, is that will a megan racing exhaust bolt up to a N1 downpipe flange?
It wont bolt up. The Apexi N1 downpipe is longer than the stock unit and made specifically to bolt up to their exhaust systems. Normally if you want to use an Apexi catback with a stock length DP, you have to use the adapter or get your DP extended and flanged.
The megan racing should bolt up. The megan comes with a 3 inch adapter and 2.5 inch adapter. If your downpipe hasn't been cut short, it should just be an easy job.
yeah it should be unless you have a problem where your downpipe is 3 inches and your catback goes from 2.5 till 3 like someone i know.
