Megan Racing DP rubbing on cv shaft
Boomdeeze
2,145
394
Jul 5, 2009
Independence, Minnesota
AS stated in the title, the flex section of my MR DP is touching the cv shaft. Will this cause it to leak after time? The DP eliminates the converter and I have the MR catback system. No matter what I do, when i tighten it down it flexes up and touches the cv shaft. Any ideas whats causing this?
My flex section sits next to transfercase and the have clothes sex all day and then because of the halfshaft being bolted to the block it never comes in contact with the transfercase or DP, what is going on there?
In the fourth picture of that post, you can see the flex section of the DP and the CV shaft above it, those two are touching after I installed the megan racing DP and catback. I also have the SBR turbo setup with their manifold, turbo, and o2 housing.
