mbc
tSiAWD97
Jul 22, 2006
N.olmsted, Ohio
I recently put a mbc on my 97 tsi and it seems to be still running on factory boost settings can anyone help me
did you make sure and double check your connection process?
Sounds to me like you did something wrong. You should completely bypass your Boost Control Solonoid.
i completly removed the solenoid. But i figured it out thanks for replying though.
So how high can i take the factory turbo without hurting anything
No more than 15 psi. Get some fuel mods soon. Also, you should look into some kind of tuning device like a logger.
do you have a logger, if so then start easing it up until you see knock and then back it off about 1 lbs or 2 and then re log and see if that helps. you wont be able to take it very high due to the efficency range of the turbo and the fact that you have factory injectors and no way of tuning. Good luck and have fun
ok then it looks like ill do injectors and a logger next. thanx im new to turbos...ive had 2 other dsm's but this is the first with a turbo and i love the thing and would hate to hurt it so any input or help from anyone would be very apreciated
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
