MBC boost leak help!
stealth13
136
Oct 10, 2008
calgary,
I did a boost leak test and most of it was coming out of my manual boost controller on the 2 sides. How can I fix this? It is a turbosmart bc.
Also I took the mbc out and directly attached the lines with a tee. Is this safe to run it like this? It only hits 12-13 psi max like this.
No the turbosmart is not supposed to leak at all. I'm just wondering if it's safe to run the way I set it up, until I can get it fixed. This was purely the problem.
