May a eclipse GST ECU fit the eclipse spyder 2.4 gs - with turbo added ?
I'm sure it can be done, because I just did a chip for a guy today in Texas who did that same conversion. He is running a 1997 turbo ECU at the moment, at only 11psi because of the very high compression, until my chip and ECU get to him. Email me at [email protected] and I'll put you in touch with him.
keydiver
There are many differences between the two engines. It is unlikely that you will be able to just swap the ecus. However as i am not as familiar with those engines, I may be wrong. It sounds like jeffo will be the best bet for your info though.
