maxing out smic?
epic fail
60
Nov 15, 2008
Mesquite, Texas
Coming next month car will be at 15 psi with the stock smic and intercooler piping. I'm guessing that'll be maxing it out without a fmic/supra/or meth. Anyone go over that? Or should I stay there until I get a fmic?
You should be fine. you can heat soak any intercooler but its a bit harder with a fmic.
I guess as long as your smart enough not to do long pulls back to back to back you will be fine.
I figured I should. Driving to work I usually don't get into boost anyways. Dsm's are more reliable than made out to be *knock on wood* worse problem mine had was the alt. belt breaking
Your sidemount should be fine for now. I'm getting a fmic however, can't argue with an affordable, super short route kit. :hellyeah:
If you are referring about the stock srt4 front mount, it won't work. The end tanks face inwards and the outlets have a oval-like shape. It will not work with your 1g at all.
You're better off getting an ebay core and fabbing up some pipes or getting a kit made for your car.
They're highly recommended by dsmers but I see srt4 front mounts go all day on craigslist for 50 dollars, I was thinking about getting one. Has to be better than my smic
So, you think ebay will be good enough to run 18 psi? I heard the cores are bad for cooling sometimes
The ebay cores are usually good for up to 25-30 psi. As for cooling issues, it applies to all fmic kits, get yourself some slim fans and it will help with the temps.
