Maxing out Injectors?
siceclipse
1,681
12
Jun 26, 2003
FFLD County, Connecticut
Hey guys whats up. My friend is getting a SR swap done to his 240SX, and the motor is the S13, so it has the T-25 and tiny 370cc injectors.
#1: can the 370's support 10psi on the T-25?
#2: If any of you know, can we put my 450's in it when i get my 550's. Do the swap right over or would the plug ins be different?
Thanks guys.
I don't believe that you can swap your old 450's into a 240 conversion. I asked a while back because a buddy of mine just did the same engine swap and was told it wouldn't work.
Sr20 are side fed injectors. Not DSM injectors won't bolt on.
Z32TT injectors will bolt on.
Correct, SR20's are side fed. If he wants to upgrade his injectors, I would strongly recommend going with a top feed setup. The extra money that large side feeds costs could be spent towards a top feed setup.
great info guys, thanks a lot. does anyone have any clue about the first question tho?
Well 10 psi will be fine my friend had his @ 14 and spikes to 16 for the whole summer/race season. at the end he melted a piston LOL so I wouldnt go over 10-12 psi those 370s blow.
