420A Max psi with my Hahn setup
eclipseman99
77
Jun 29, 2003
How much boost can I run with my setup.Hahn stage 2 turbo kit with fmic and built bottom end.8:8 je pistons and eagle rods.
wrong answer.... definitely not as much as you want...
it depends on ALOT of different factors...
what fuel mods do you have? injector size? fpr? fuel control? pump?
this question isnt answerable until you give us more info. even if you have a built motor, running lean = BOOM.
sarcasm is hard to detect over the internet, so be carefull, cause some people might actually say "oohhhh he said as much as i want!" and then give the ole mbc a few twists, run 28 lbs on 310cc injectors and no fpr, and the go BOOM!!!!
