Max AFC Correction on 450s? Tuning q's
TurboGeoff
247
Dec 6, 2003
Redwood City, California
What is the max afc correction i can add on the stock 450s before i max out the injectors?
Currently Iam runnign 12 psi on a B16g with +14% correction in some areas on Hi throttle, how much higher can i go?
Also, since iam still on stock injectors and pump, should i bother tuning the fuel trims and lo-throttle? shoudl i just tune for hi-throttle? any suggestions?
-Geoff
Adding more will bring on fuel cut sooner.
What does the logger say for fuel trims and hi throttle?
Stock pump and injectors usually means 0%'s on an AFC.
Ya i see what you are saying, the only problem is that i have a hacked MAS and even at low boost i get alot of knock with the b16g.
-Geoff
