Marker lights wont work and popups wont work on the 91
Should be in the fuse box on the passenger side. I believe it is a 30amp pink fuse.
If you can just buy one 30amp fuse and try replacing one fuse at a time of the 30amp ones with the new one until you see the pop ups working, then you will know.
Try going to a junk yard and look for fuse box covers, i can get you one if you want. If interested let me know.
A bad or disconnected dimmer switch will also do this. Not the "flash to pass" high beam indicator, but the one on the left on the dash by the instrument cluster.
