stock alarm wont work
as if you can't tell we are being sarcastic....we need more information to diagnose your problem...is the remote not locking the doors, when you try to open them does the horn not go off, when you arm it does the green security light not come on? you need to be a bit more specific
LOL sorry bout that well the alarm doesnt do anything it doesnt lock its doesnt arm at all could it be the remote.... i have to lock the car with the key for the light to turn on
The battery in your fob is dead. If the green security light comes on when you manually lock the door, then the alarm is probably ok.
if the battery doesn't work then you might have somehow lost the frequency...try recoding the alarm.
To reprogram your keyless entry system for a new key fob:
1) Turn ignition to OFF.
2) Ground pin 1 of the Data Link Connector (black 16-pin connector under
dash driver's side). Pin 4 of this connector is a ground, so placing a
jumper wire between pins 1 & 4 will accomplish this. Grounding pin 1
tells the system you are getting ready to reprogram it.
3) Close all the doors.
4) Turn the key to ACC, then back to OFF. The power locks will
lock/unlock. The system is now ready to be programmed.
5) Press a button on your key fob 3 times.
6) The doors will lock/unlock to signal that the codes were received.
7) If you have two key fobs, press a button on the second fob within 1
minute of pressing a button on the first one 3 times. Both must be programmed at
the same time.
8) The doors will lock/unlock to signal that the codes were received.
9) Remove the connection between pins 1 & 4.
