ECMlink Map value doesnt match boost gauge
bigdnno98
275
38
Aug 4, 2013
Clarksville, Tennessee
I'm trying to setup my SD tune. I'm having a hard time and I think it's because the MAP value dsm link is logging isn't near what the mechanical boost gauge is reading. I have an ecmtuning sd cable. I cut the gm map connector off and wired it into my AEM 3.5 bar. I started the car with my new v3 ecu and set my map input to baro. It's logging -2.5 in/hg and the boost gauge is reading -15psi. Airflow per rev is .70 mad when I press the gas the car wants to die. Any help would be greatly appreciated.
Thanks. Appreciate it. I've moved the MAP sensor. Car started up much easier. Sounds more healthy too. It still dies after a few seconds of idling but it seems different now. On startup vacuum goes to -10psi but then starts to creep back toward 0. As it does that idle gets worse and the car dies. I'm not sure which one is causing the other but I'll BLT the car again tomorrow. Weather sucks.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
