Manuals WRONG! Torque Specs for Rod and Main?!
yoyo13131
75
Feb 5, 2010
Santa Clara, California
As I've found out today the Haynes Manual is COMPLETELY wrong for the main and rod bearing torque specs, (broke off a rod stud loosening nut for plastagauging :banghead:)
Does anyone know the correct torque specs for a 6 Bolt 1993 2.0 non-turbo Eclipse? (for Main bearing caps, and Rod Nuts)
36ft lbs for Rod nuts?
49ft lbs for Main bearing caps?
Sorry for asking but I've spent over an hour trying to find this answer....
Oh and whats the spec length for the Main bearing cap bolts? (so I can see if I need to replace them since they were over torqued)
Thank you for all your help guys, the torque specs are correct and I have .002 clearance on my main and rod bearings =] (all standard sizes)
It's weird that the FSM says the torque for a 2G is 20NM or 14.5 ft/lbs plus 90 degrees. That's a big difference from 38ft/lbs on the 1G.
