420A Manual trans shifter linkage
Drayton07
Oct 25, 2024
Northport, Alabama
My shifter linkage on my manual 99 Eclipse GS keeps sliding out on its linkage mount bracket that's connected to the transmission. Is there supposed to be a bushing or locknut that holds the shifter in the mount. It keeps backing out when I go to shifter and mis-aligns where the gears are.
Try the classifieds or call one of the vendors on this page. Theyre similar to a brake hose clip. Have you installed one of those?
This the right clip? I know extreme psi a good vendor
If you install a new retaining clip and it comes off again, check my solution in this link:
This solved my problem permanently.
You seem to be missing the clip that locks the cable into the bracket.
