manual to auto engine swap?
He's talking about the engine.
Yes they are the same. Only thing you need if taking an engine from a manual to put in an auto is the crankshaft spacer.
Just switch starter plates and remove that bearing that sits in the crank on the auto and put it i the manual engine, Its a bi*** to remove but that would be about it. I believe injector sizes are different so you might have to change as well as the turbo's.
