manual cpu and oil coolant system
912g63lp
47
Dec 18, 2006
lincoln park, Michigan
OK to start i have a 91 tsi talon and it has some issues. I get no pull from my turbo and it reads clearly on my gauge... shoots up to 10 psi. I am guessing boost leak or my turbo is gone:notgood: . Second i have no oil coolant system where can i go about getting one and any quick tips on "how to installs".? And finally i have an automatic computer in my car that IS a manual, does this effect me and what is the proper name for this manual (cpu, tranny cpu???) thing. If all of this is going to run my pockets real deap then it my be the end of the road for this dsmer so ###zzz help.
Most likely a boost leak. What kind of boost gauge do you have (or are you speaking of the stock one on the dash)? Did you go thru the freebie mods in the Upgrade Paths section? Is your car blowing smoke out the exhaust?
Shouldn't be a big deal, especially since you are pretty much stock.
Not sure what you are talking about here....
