Mandrel Bends and Welding Question
Yea that is a mandrel bender and I always weld with gas/wire. Once and a while I will do some stick welding on roll cage's but other than that I like wire the best. If you know what you are doing you won't warp the metal at all. No matter how thin it is.
So you use the oxygen acetylene flame welding all the time? Or are you saying you use argon gas and wire in a mig welder?
steve said:
No, a mandrel bender uses special dies inside the tubing to keep the diameter constant as the tubing is bent. That's just a homebrew bender.
steve is right that isn't a mandrel bender but anyway mig welding is great for exhaust and tig is great for intercooler piping and many other applications that you want a sweet small weld on but it takes tallent. :dsm:
I am taking a welding class this semester and have been able to play with mig, tig, stick, and gas welding. I liked gas welding the most because it was relatively easy to do, didn't have to be near an outlet, and seemed like a more controlled process than stick or mig. I researched prices and it is apparently a lot cheaper to pick up a gas welder. So that is where my question is coming from. Would a gas welder be fine for body work, exhaust, intercooler, etc? Or does the heat from the torch make the metal too brittle?
Gas welding works good for welding carbon steel exhaust and intercooler piping. Body work is better left to MIG or TIG. Intercoolers and intake/exhaust manifolds are best done with TIG.
My advice to you is to save up for a small 120V wire feed welder. It is a good idea to buy one that is capable of running solid wire with gas instead of just flux core. With that little welder and a chop saw you can make a lot of good stuff. In addition to the stuff you can do with a torch you can weld stainless, and do body work.
Seth
