Maintenance Plan - Help
PHL
Nov 23, 2008
São Paulo, South America
Hi everyone,
First of all please forgive my grammar mistakes. I am from Brazil and therefore have limited English skills. :)
I've just got a 2G GS-T 95. This car will not be used daily, I will be using it in the weekends for traveling and for fun.
Here, in Brazil, all parts are very expensive but I often travel to US, so I will be getting some parts there. So far I have no upgrades in mind, I just want to exchange some old parts for safety, and to make sure the car will be running fine.
The car is running just fine, no boost leaking. The only think I need to repair is a small leak in the Valve Cover.
Having said that, I have made a "small" list of parts I will be buying now, in January since I will be in NYC.
Please, tell me if I am missing anything of if I am buying something I actually wouldn't need to.
OEM Valve Cover Gasket Set:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Valve Cover Gasket Set : Mitsubishi Eclipse 90-99
OEM A/C Belt OEM:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM A/C Belt OEM : Mitsubishi Eclipse 90-99
OEM Alternator Belt
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Alternator Belt : Mitsubishi Eclipse 90-99
OEM Power Steering Belt
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Power Steering Belt : Mitsubishi Ecilpse 90-99
BOV 1G
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Bypass Valve (BOV) : Mitsubishi Eclipse 90-94
OEM Water Pump Assembly
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Water Pump Assembly : Mitsubishi Eclipse 90-99
OEM Blowoff charge pipe
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Blowoff Charge Pipe: Mitsubishi Eclipse 90-94
(Do I need this to use BOV 1G?)
OEM Radiator Cap
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Radiator Cap : Mitsubishi Eclipse 90-99
(Just in case)
OEM Heater hose kit:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Heater Hose Kit : Mitsubishi Eclipse 95-99
Fuel Injector O-RING Replacement
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Fuel Injector O-Ring Replacement Set
OEM Fuel Filter
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Fuel Filter : Mitsubishi Eclipse 95-99
(I have already bought an Walbro 255, so I don't know if I get this filter or if there is another one more appropriate)
OEM 4G63 Balance Shaft Belt
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM 4G63 Balance Shaft Belt : Mitsubishi Eclipse 90-99
OEM 4G63 Timing Belt
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM 4G63 Timing Belt : Mitsubishi Eclipse 90-99
OEM Timing Belt Tensioner Pulley
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Timing Belt Tensioner Pulley : Mitsubishi Eclipse 95-99
OEM Balancer Tensioner Pulley
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Balancer Tensioner Pulley: Mitsubishi Eclipse 95-99
OEM Timing Belt Tensioner Adjuster
EXTREME PSI : Your #1 Source for In Stock Performance Parts - OEM Timing Belt Tensioner Adjuster : Mitsubishi Eclipse 95-99
I think that is all (OEM) that I have in my least. The Radiator hose I am still deciding if I will buy OEM or an aftermarket one.
I have done a little research about the 1G BOV and what I need to buy in order to make it work in the 2G. This forum has a LOT of info - great job.
Thanks guys - and Happy New Year! ;)
Paulo
In regards to your overall parts list I think that you're being very detailed but a lot of those parts you can buy cheaper and just as reliable at a normal parts store like AutoZone, Advance Auto Parts, or Oreilles auto parts. Now as far as the timing components go I think I can safely speak for most of us on this board and say that you getting them OEM is the only way to go. It must suck to be out of country and prices are higher but as long as you make each trip to the U.S. count I think you can do it at our cost as well. Good luck
In regards to your overall parts list I think that you’re being very detailed but a lot of those parts you can buy cheaper and just as reliable at a normal parts store like AutoZone, Advance Auto Parts, or Oreilles auto parts. Now as far as the timing components go I think I can safely speak for most of us on this board and say that you getting them OEM is the only way to go. It must suck to be out of country and prices are higher but as long as you make each trip to the U.S. count I think you can do it at our cost as well. Good luck
You are right, but last time I had problems trying to explain what I wanted at the store - you can imagine how it went. That is why my plan was to buy in the internet and have it delivered at some of my friend's house, or even at my hotel. The prices are that different?
Thanks!
Paulo
You don't need the charge pipe for the 1G BOV - you would just need a 1G BOV adapter if you plan on using the stock pipe. :thumb:
Thanks!
Paulo
You can buy over the internet at those places websites and get all of the items you want shipped to the store nearest to where you are going to be next. Yes you will see up to 50% differences in some cases but yes over all the prices are that much better. As I said above, get things like timing belt and everything related to that OEM but things like gaskets, power steering belt, and other common parts at the places I mentioned.
Thanks man, good advice!
Thanks, so I will remove that item from my list! :thumb:
PL
Do you guys think I should buy any clutch component such as: OEM Clutch Slave Cylinder Assembly?
I thought about the oil pump but I guess this would be too much, since there is no sign my oil pump is bad..
Thanks,
PL
If you install that 255 fuel pump you will need an afpr.
I will search for details on this one. Thank you.
Just a quick question, if I don't get an afpr, what could happen?
PL
PL
You'll overrun your stock fuel pressure regulator and will run rich. It will hinder performance and gas mileage.
Thanks for answering.
Since I am not going for any upgrade yet, I still ask myself if I should really replace the stock pump.
:confused:
PL
When was the timing belt last changed??? trust me if u dont know replace that as well as the balance shaft belt which lies behind the timing belt... i learned that the hard way!! my belts broke on a casual drive to work and i ended up getting a salvaged motor! i couldve had the cylinder head rebuilt but i didnt have the time becuase its my work car and my other vehicle was out of commission at the moment
It is already in my list! :thumb:
Thanks
PL
:confused:
PL
You don't need it now if you are just doing maintenance. Installing the fuel pump is a totally separate project from the engine maintenance you plan on doing. If you want to order it now, that's fine, but you will also need an AFPR. If you wanted, you could just rewire the current fuel pump for better flow.
I followed this and it works just fine.
2g Fuel Pump Rewire
Yes, I guess I will just the rewire for now, and keep the Walbro for whenever I have to exchange the current pump.
Thanks
PL
Hi,
I already bought the parts, there is one I can't find:
"Purge control solenoid"
Do you guys know where I can find it online? I don't know if there is another name, but using this name I was unable to find it online. :(
Thanks
PL
Ok - so far I got everything from the list and additionally the Energy Suspension kit and the Dejon Air intake + UICP kit.
Still didn't find the "Purge control solenoid"...
Thanks,
PL
