Maintanence Kit
darkiller_666
477
Feb 19, 2008
Salina, Kansas
Is there a rebuild kit only for maintenance things like Timing belt and tensioner and oil pump and belts water pump and belt? Something kinda like that. Or do i have to buy eerything seperately? Let me know. My car has repeadiatly broken down one things after another for almost a year. Id like to do as much maintenance on it now before i put my clutch in and start drving it again.
You can buy the timing kit in a complete kit and oil pump seperately,I recommend getting your maintenance kit at partsdinosaur,quality parts at low prices
Timing componesnts-http://www.store.partsdinosaur.com/product279.html
Oil pump-http://www.store.partsdinosaur.com/product160.html
or if your a mitsu freak get oem everything LOL
Check out STMDSM.COM i know they have a seal kit for the motor, and all the parts you would need i dont know what other kind of kit they have though.
I am leaning towards these conitechs belt kits, ive seen several under $100 shipped. I plan on completely redoing the hydraulic clutch system clutch fork pivot ball TB kit water pump oil pump and new gaskets everywhere and a new fuel filter. My block is honed, fresh head with decked hot tanked and a new HG. New rear axles, new clutch, new CAS, new power transistor and coil pack, fresh oil and filter fresh coolant, and fresh tranny fluid. New cam seals, lifters, and valves. Is it easy and/or necessary to change the fluid in the transfer case? Im trying to make this damn car reliable for more then a month this time. Let me know on anything else you guys would think i might need to change or do for maintenace. What are you opinions on topline belts?
I found this kit for 350 shipped what do u think?
ncludes:
timing belt
balance shaft belt
water pump with gasket
timing belt tensioner
balance shaft tensioner
timing belt idler
automatic tension adjuster
all accessory drive belts (if your vehicle does not have A/C, contact us and we will supply the correct drive belts)
valve cover gasket
four spark plug tube seals
two camshaft seals
front crankshaft seal
oil pump seal
intermediate shaft seal
quality name brand parts
free same day shipping
returns accepted to 90 days
The timing and balance shaft belts are Contitech. The tensioner, balance shaft tensioner and the idler pulleys are GMB. The automatic tension adjuster is Genuine Mitsubishi. The water pump is GMB. The drive belts are Bando and or Contitech. This kit will service Mitsubishi Eclipse Turbo's with 2.0L, 4G63 engines with a year range of 1996-1999. The production date should be from 8/95-1999.
