dsm_stroker
- 0
- Nov 12, 2013
ottawa,
ON, Canada
Looking for abit of input anyone here ran one?
I own one. It's pretty heavy which is a good thing for drag racing and street driving. Pedal pressure is less than that of an ACT2600. Also it is much quieter than all of the twin disks I've heard. There's also no need for any of the band-aid fixes like extended rods or shimming the pivot ball. Awesome clutch, I have zero regrets with spending that kind of coin on
what kind of 60 ft times have you cut with it
The DSM triple starts with an Exedy triple from an Evo X, and then Magnus makes the flywheel and hub to be used on a DSM. The result is a clutch that works flawlessly without the need of bandaid fixes like extended rods, and shimming of the pivot ball! I couldn't be happier with this clutch!
Well I know the Magnus unit has a gear drive hub which is much better for many reasons over the standard multi disk floating hub design that Comp uses in their triple.
I thought it was flywheel as the main part marco designed, nothing wrong with that.
Only thing is I'm curious how it compares to the comp tripple which is almost half the price.
