MAFT drawthrough or blowthrough?
btracer
187
Oct 21, 2002
reading, Pennsylvania
just wanderin which is better? if anything. drawthrough where its before turbo or blow through where its on uicp. :talon:
it all depends on what you want. there is no performance gain between the 2. it will be easier to set up the draw-through. blow though will allow you to run an open BOV. the one benifit I have is when you blow off a intercooler pipe it will still run under no boost with the blow though setup. :thumb:
that sums up my questoin.. thanx a lot man, looks like ill do the blowthrough.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
