MAFT basic Q's and RPM wire Q.
whitegst97
199
Sep 16, 2002
Miami, Florida
I just received the MAFT while reading through it something got me a bit confused. When using the AUX/BASE mode then switching to the RPM/WOT FINE TUNE the base corrections are saved. What about if you tune with the rpm and wot fine tuning 3k 4k 5k 6.5k and then switch back to the aux/base mode i assume the fine tuning settings will remain? My next question is about the RPM wire tap. I know you need to tap it off of the CAS or the power transitor. I have a 2G so my CAS only has a the connector a two wires (red,black), which one do i tap? The power transitor is another choice, i beleive is the big wide connector above the injectors, mine has 7 pins, not 8 like i've read others having. Which one do i tap? Any one has pics that they could share. Thanks
does anyone know where iu can find some instructions for the maft..i just got mine in and it didnt have instructions. i dont know what does what or how i could set it for basic operation and start for there?
