MAF-T with stock injectors
suprdave09
42
Sep 19, 2004
Troy, Michigan
If i were to get a maf-t with a safc would i be able to increase the fuel of the stock injectors without hitting fuel cut? Or would that cause it to max out the injectors?
You could always raise the fuel pressure and then lean the maft or safc to reduce fuel cut.
Stock injectors and just afc or maft will not help fuel. You would have to lean the mixture to fool the ecu into thinking it is less airflow which will help with fuel cut. Then, if you do that, you might end up too lean and damage the engine.
