General MAF-T and SAFC
d4rk13l4de
58
Mar 12, 2005
Wasilla, Alaska
i just got my talon and it has a 2g mass and an s-afc, my question is can i convert it to MAF-T and still use the s-afc for fine tuning after i set the Translator to the correct injector sizing? i am just needing this to work untill i can save up enought to convert to DSMlink. i found a great deal on a 3" gm mas and trans
Yea should work fine, You might want to keep an eye on the safc though. I found I did not need it too much after installing the maft. The corrections were very small and usually only at higher boost levels.
