99dsmGST
- 78
- 1
- Jul 16, 2006
Phoenix,
Arizona
Ok guys, just like the tittle states. I need a good shop in the Phoenix area (near 35th ave & Bethany Home) that can clean, bore and what not to my block.
What do you need to do to your head? Re-surface it, port, polish, or just clean it? I took my head to Brandon Ruiz and he has his own guy that does the work for him. My head looked brand new once it was done. Give him a call @ (602)621-3795.
I just got a block back from B&B machine 2 weeks ago. They did a great job and it cost $55 to clean it and $44 to hone (didnt need to be oversized so I dont know what that will cost).
They're at 936 W. Broadway in Mesa.
I had work done at B&B and I wasn't impressed. I had my head resurfaced for an MLS gasket + ARP Studs install and they told me it will be hold even if the block wasn't decked since the block usually doesn't warp much. As soon as i got to 25PSI I started pushing coolant. The other thing they didn't notice is that my valve guides on cylinder one are messed up and the valves do not seal properly. They said they pressure tested the head and it was fine but 5000 miles later I did a leak down test and I am loosing 50% pressure at 100PSI trough the intake valves.
Another shop (Phoenix Cylinder Head) was recommended to me by a long time Mitsu tech and I will try them next.
They did a good job on the flywheel so I guess I'll roll by and see what they have to say.
. I was just about to convert to E85 before the head gasket blew cause I'm out by Red Mountain High School. It's like 1 mile away.Matt thanks for the info. You must live out by Sosoman and Main because that's the only E85 pump on this side if the valley. I was just about to convert to E85 before the head gasket blew cause I'm out by Red Mountain High School. It's like 1 mile away.
The kid said it would be "just fine".i would have to disagree. I have had 3 sets of 3000gt heads done there. None were done on time. The last set was totally screwed up and had to be redone. I would not and have not used them since. Totally unimpressed by that shop. Take your money elsewhere.
