M/T trans problems
JBDdsmer610
508
8
Mar 4, 2006
easton, Pennsylvania
ok well the other day i was having slave cylinder issues i replaced it and the problem was fixed. so today i leave for work tranny shifts fine. went out on my lunch break and the trans shiftted fine. i get in my car at about 5pm start it up let it warm up for 5 to 10 min and i push in the clutch and it grinds into 1st and reverse. once i finally got it in gear i noticed it was real notchy into second then it grinded into 3rd. now i go shift into 4th and it is notchy. My clutch engaugement is good. Could my trans have low fluid levels and be causing it to grind?:confused:
Possibly. More than likely air got into the system. Try re bleeding the clutch and check the pedal adjustment and make sure it's good. Should have 1/2" of play at the top of the pedal before you feel it start to engage.
I'm going to assume air in the system.
TOO MUCH or TOO LITTLE fluid will give you issues.
Is your clutch hydraulic system properly adjusted?
Are your tranny bolts all the way in? All four of them?
Also, this happened to me, but it's rare. You're clutch springs could be blown out. Lol.
The clutch only has about 5000 miles on it just an oem replacement. and i do have about a 1/2in of play at the top ill bleed it tomorrow and put more gear oil in it and see what happenes. and when i stand next to my car on the passenger side i can hear everything in the tranny spinning. and it is kinda loud guess that cant be good
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
