Tallen
- 2,738
- 8
- May 28, 2002
Ashburn,
Virginia
can a ported maf be corrected by adding some sort of screen in?
Originally posted by NOSLO2PT0
How about buying things you NEED first? But then again, you may be one of those people that will forever be stuck in the 14's, so who knows.
Yes at ANY Hp level. No matter how you look at it the GM sensor is a far less restrictive piece than the 2G unit. If a guy goes 10's with a 2G meter on his car how fast do you think he could go with something that really works? Like with all products, time always tells if they are good or not and live up to the hype, we soon shall see.Originally posted by NOSLO2PT0
At ANY hp level? A few guys have gone 10's with a 2G MAS. This is more of something to get when you are close to overrunning the 2G MAS. I think everyone is just jumping on the bandwagon cuz it's something new and cool, not something you can actually take advantage of. But, i digress.
Mike,
Are you saying that the actual design of the unit is different depending on if it's a draw-thru or blow-thru design? I thought we could use it either way with full interchangability. Correct me if I'm wrong.
Mike
Are you supplying custom piping or can we use the stock MAF ends and then just neck down to our IC piping?
Originally posted by peregrine
the latter. i talked to a GN guy that lives close to me and he is running one of these units. said it was night and day too. im on this like flies on shit![]()
Originally posted by ttawd3s
What do you mean ?? The the translator haters think you have to make 1000hp to benifit from this !!
This is the way I explained it to the 3/S guys.
If I told you your factory air box/can was good till 400hp, would you wait till 400HP to upgrade it ? Hell no...
GN guys wouldn't be doing this if it didn't have any benifit. The GM guys have been inproving turbo technoloy for almost 20 years !!!
A lot of things that are sucessfully applied to GNs will translated into the same on other turbo cars, this is one of those things.
peregrine your GN friend is prob. older and wise about turbocharged cars, right ? If a person is crazy enough to drive around in a car that looks like a turbo regal, you KNOW that motor has to bad ass !! ( J/K, I gotta talk smack about the GN b/c there so freaking fast ! )
i mean that im on this like flies on shit because its a great idea
yeah his car is pretty fast
only has 20000 original miles too. keeps it in the garage and only takes it out in the summer. especially around hot august nights.Originally posted by highbooster
Where can I find the LS-1 with 4'' adaptors that flows 1200cfm? My turbo flows +1300cfm. Is there a higher flowing mass I can run?
Lij Allen
strokerimports.com (comming soon)
strokerimports.4t.com (now)
[email protected]
Originally posted by Ramchargers
BTW we make the 4" adaptors
