LS-1 MAF translator vs ARC-2/ VPC
We need more details.
Switch settings,
which MAF are you using
What injectors
DSM link?
other equipment (safc)
Bob
Switch settings,
What injectors
DSM link?
Bob
all the dials on the translator are at 0. i have a 3" lt1 maf out of a caprice. stock injectors. no dsmlink. the 4 little switches in the translator are where they should be. i set it for 2g, 3", remove fuel cut, and im forgetting what the other one was. the two wires that were lose in the harness that came with the translator are not connected. the two plugs are obviously plugged in though. the ic piping is all up to par and all the vaccum lines are plugged in from what i can tell.
ok, well i just ghetto fixed it. i set the idle dial in the translator like 6 clicks over and now it idles at 1000 and drops down to 600 instead of 200. that should get me to school tommorrow.
bob or mike, you wanna meet up sometime at the ramchargers on 12mile... perhaps you guys could help me with this problem in person. ill treat you to lunch..come on...
LOL...the point of a piggyback fuel computer is to change the fuel delivered to the car...
a: why did you buy one if you have no monitoring tools to go by?
b: you have to tune it to make it work. see a:
you didnt ghetto fix it, it should be a few clicks to the right (richer) for idle...to get mine to idle right i adjusted the BISS a lil and adjusted the idle settings a lil. its not gonna magically set itself perfectly.
Myself and others have had this same problem.
Simply set switch #1 to the 3.5" MAF setting and all will be well.
Hal
HOOK UP THE RPM WIRE. For some reason people are starting to think that becasue it works ok without it you don't need to do it. Please use the unit the way it was designed.
Mike
I will meet up with you sometime send me an e-mail
Mike
[email protected]
Originally posted by Ramchargers
HOOK UP THE RPM WIRE. For some reason people are starting to think that becasue it works ok without it you don't need to do it. Please use the unit the way it was designed.Mike
Mike,
I think there some confusion because of several posts like this one:
"The RPM is not needed the unit will function without it. The ranges will change by the backup of airflow. The main thing is that the countored fuel WILL NOT work if you are using the trigger wire since that is RPM dependant. I would recommend hooking it up but it will work fine without it."
If, indeed the RPM signal is REQUIRED for reasons other than "contoured" fuel then yes we ALL need to hook it up.
I have no problem making the connection, but I did not do so based on the above post.
Hal
I am in the same boat as you Hal. Thank you for posting that :thumb:. I'm glad I was not the only one wondering what the RPM wire exactly was for besides contoured fuel. I have no problems hooking it up, I just would like to know how the translator will be affected so I can tune the fuel curves better based on rpm with the PMS.
thanks hal.
Not that this is your problem but make sure the mas plug is in correctly. It is totaly posible to plug it in 180 out. ;) Dont ask how i know.:rolleyes:
This was posted in the yahoo group of the translator by Dave at ramchargers....but I hope this will answer all of your questions on which MAS will work. So off to ebay you go!
3" mafs, gm part #25180303 (213-352 on acdelco.com)
2003 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2003 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2003 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2003 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
2003 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = X
2003 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2003 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2003 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2002 BUICK RENDEZVOUS V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2002 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2002 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2002 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2002 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2002 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2002 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2002 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2001 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2001 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2001 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2001 OLDSMOBILE AURORA V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2001 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2001 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK GT V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC AZTEK V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2001 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2001 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = J
2000 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET IMPALA V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU LS V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
2000 CHEVROLET MONTE CARLO LS V6 3.4L 207cid GAS FI N Engine VIN = E
2000 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
2000 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE ALERO V6 3.4L 207cid GAS FI N Engine VIN = E
2000 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
2000 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
2000 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND AM V6 3.4L 207cid GAS FI N Engine VIN = E
2000 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = J
2000 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1999 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1999 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET ASTRO V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET LUMINA V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = J
1999 CHEVROLET MALIBU V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET MONTE CARLO V6 3.1L 189cid GAS FI N Engine VIN = M
1999 CHEVROLET S10 BLAZER TRAILBLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 BLAZER V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET S10 PICKUP V6 4.3L 262cid GAS FI N Engine VIN = X
1999 CHEVROLET VENTURE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 GMC S15 JIMMY V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC S15 SONOMA V6 4.3L 262cid GAS FI N Engine VIN = X
1999 GMC SAFARI V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE ALERO V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 OLDSMOBILE BRAVADA V6 4.3L 262cid GAS FI N Engine VIN = W
1999 OLDSMOBILE CUTLASS V6 3.1L 189cid GAS FI N Engine VIN = M
1999 OLDSMOBILE INTRIGUE V6 3.5L 214cid GAS FI N Engine VIN = H
1999 OLDSMOBILE SILHOUETTE V6 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND AM V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1999 PONTIAC GRAND PRIX V6 3.1L 189cid GAS FI N Engine VIN = M
1999 PONTIAC MONTANA V6 3.4L 207cid GAS FI N Engine VIN = E
1998 BUICK CENTURY CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK CENTURY LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 BUICK SKYLARK V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET LUMINA LTZ V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 JIMMY ENVOY V6 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1998 GMC SAFARI V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE ACHIEVA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE BRAVADA REGIONAL V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1998 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND AM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC GRAND PRIX V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1998 PONTIAC TRANS SPORT MONTANA V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1998 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 BUICK CENTURY CUSTOM V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK CENTURY LIMITED V6 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET LUMINA LTZ V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET MALIBU LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MALIBU V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1997 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 CHEVROLET VENTURE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1997 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1997 OLDSMOBILE CUTLASS GLS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1997 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1997 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER LIMITED WAGON V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 BUICK SKYLARK CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK GRAN SPORT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 BUICK SKYLARK LIMITED V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET ASTRO V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET BERETTA Z26 V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET BERETTA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1996 CHEVROLET CORSICA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1996 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET LUMINA APV V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 CHEVROLET S10 BLAZER V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 CHEVROLET S10 PICKUP V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC S15 JIMMY V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 GMC S15 SONOMA V6 LF6 4.3L 262cid GAS FI N Engine VIN = X
1996 GMC SAFARI XT V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE ACHIEVA SC V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE ACHIEVA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE BRAVADA V6 L35 4.3L 262cid GAS FI N Engine VIN = W
1996 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 OLDSMOBILE SILHOUETTE V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1996 PONTIAC GRAND AM GT V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND AM SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1996 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1996 PONTIAC TRANS SPORT V6 LA1 3.4L 207cid GAS FI N Engine VIN = E
1995 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK REGAL GRAN SPORT V6 3.1L 189cid GAS FI N Engine VIN = M
1995 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD BROUGHAM V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CADILLAC FLEETWOOD V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1995 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1995 CHEVROLET LUMINA LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET LUMINA LS V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 CHEVROLET MONTE CARLO LS V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 CHEVROLET MONTE CARLO Z34 V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 OLDSMOBILE CUTLASS SUPREME SL V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX SE V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1995 PONTIAC GRAND PRIX GT V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1995 PONTIAC GRAND PRIX GTP V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 BUICK REGAL CUSTOM V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 BUICK ROADMASTER ESTATE V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER LIMITED V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 BUICK ROADMASTER V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE LS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET CAPRICE CLASSIC V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET CAPRICE CLASSIC LS V8 4.3L 265cid GAS FI N Engine VIN = W
1994 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
1994 CHEVROLET LUMINA EURO V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS CIERA SL V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME V6 L82 3.1L 189cid GAS FI N Engine VIN = M
1994 OLDSMOBILE CUTLASS SUPREME S V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 OLDSMOBILE CUTLASS SUPREME V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 LQ1 3.4L 207cid GAS FI N Engine VIN = X
1994 PONTIAC GRAND PRIX SE V6 3.1L 189cid GAS FI N Engine VIN = M
3.5" mafs, gm part #25179711 (213-353 acdelco.com)
2002 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2002 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2002 CHEVROLET EXPRESS 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET EXPRESS 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 CHEVROLET EXPRESS 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 CHEVROLET EXPRESS 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 CHEVROLET EXPRESS 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 CHEVROLET EXPRESS 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2002 GMC SAVANA 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 GMC SAVANA 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 GMC SAVANA 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2002 GMC SAVANA 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2002 GMC SAVANA 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2002 GMC SAVANA 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2002 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2001 CHEVROLET EXPRESS 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET EXPRESS 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 CHEVROLET EXPRESS 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 CHEVROLET EXPRESS 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 CHEVROLET EXPRESS 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 CHEVROLET EXPRESS 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2001 GMC SAVANA 1500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAVANA 1500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 GMC SAVANA 1500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 2500 V6 4.3L 262cid GAS FI N Engine VIN = W
2001 GMC SAVANA 2500 V8 5.0L 305cid GAS FI N Engine VIN = M
2001 GMC SAVANA 2500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 3500 V8 5.7L 350cid GAS FI N Engine VIN = R
2001 GMC SAVANA 3500 V8 8.1L 496cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
2001 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = G
2000 CHEVROLET KODIAK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
2000 CHEVROLET MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
2000 GMC MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
2000 GMC TOPKICK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
2000 GMC TOPKICK 6X4 C 2WD V8 7.4L G MFI Engine VIN = D
2000 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO SS V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CAMARO Z28 V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET CORVETTE V8 5.7L 350cid GAS FI N Engine VIN = G
1999 CHEVROLET KODIAK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
1999 CHEVROLET MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
1999 CHEVROLET P30 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1999 CHEVROLET P30 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1999 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1999 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1999 GMC MD BUS CHASSIS V8 7.4L G MFI Engine VIN = D
1999 GMC P35/P3500 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1999 GMC P35/P3500 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1999 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1999 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1999 GMC TOPKICK 4X2 C 2WD V8 7.4L G MFI Engine VIN = D
1999 GMC TOPKICK 6X4 C 2WD V8 7.4L G MFI Engine VIN = D
1999 PONTIAC FIREBIRD FORMULA V8 5.7L 350cid GAS FI N Engine VIN = G
1999 PONTIAC FIREBIRD TRANS AM V8 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO SS V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CAMARO Z28 V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET CORVETTE V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 CHEVROLET P30 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1998 CHEVROLET P30 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1998 CHEVROLET P30 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1998 GMC P35/P3500 VAN V6 4.3L 262cid GAS FI N Engine VIN = W
1998 GMC P35/P3500 VAN V8 5.7L 350cid GAS FI N Engine VIN = R
1998 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = B
1998 GMC P35/P3500 VAN V8 7.4L 454cid GAS FI N Engine VIN = J
1998 PONTIAC FIREBIRD FIREHAWK V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD FORMULA V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1998 PONTIAC FIREBIRD TRANS AM V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1997 CHEVROLET CORVETTE V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
1997 CHEVROLET MD ISUZU TRUCK TILTMAST Any
1997 GMC MD DUTY ISUZU TRUCK FORWARD Any
__________________
endless oportunities for improvement and endless places to start looking for the problems that occur...ain't DSMs GREAT!
Originally posted by Formz
Yea I put the link up to the list like 6 pages back.
woops, sorry, I just thought it would be easier to view the whole list instead of clicking through 13 different pages o the ac delco website...anywho, im going into my corner now.
Do not go into your corner now! Come out and get a heros welcome :)
this is a great list! I knew the Mafs off of those sorta other cars would work! I work around lots of late model GM cars/trucks and they all look the same.
Great stuff.
Any vendors should have this list on thier sites as well.
ya, thats what Im talking about, you cant own a dsm and not use ebay....it just doesnt happen...its like Peanut butter to jelly, or beans to rice, or dsm tailights to V-8s....the list goes on
ok, I'm sure this question has been previously asked but I just could not bring myself to read all 24 pages of this thread in fear that I might lose my sanity, so can anybody tell me which translater the 2nd gen guys should buy? or do they even have it yet? thanks for any replies:thumb:
  • Wanted 2gb OEM front bumpercover
    Looking for a unicorn part. I want a OEM front bumper cover. I prefer black but will take any...
    • Xarzor
  • For sale 2g Rear brake rotors and pads for FWD
    Brand new EBC rotors and ProStop Platinum pads. Very good quality OE spec parts. Accidentally...
    • 2GbTalonGuy
  • Wanted 2g black hood
    Does anyone have preferably a black hood for sale let me know need to buy one by this week
    • DSM-kiezerz
  • For sale JMF Coil Pack Bracket
    JMF Coil Pack Bracket. Buyer pays fees/shipping to the lower 48 states. You must be registered...
    • elocneas
  • For sale 2g Eagle talon headlights set
    Talon headlight set no broken tabs
    • Lonestardsm
