Low vacuum idling, fine after driving.
Whammydill
78
Aug 1, 2005
Mansfield, Ohio
I'm having an issue that cropped up yesterday with my idle. I was at a gas station and started my car back up. Idle is fine at 800-900rpm. Vacuum at 18 or so. I pull out of the station and drive it kind of hard the remaining mile to work. Decel vacuum was normal. All was as it usually is until I get to the parking spot. Idleing my car before I turn it off, it sounded really rough, and my vacuum is steady (very slight flutter) at around 10.5 mm/hg. I didn't have time to deal with it so I went in to work.
I start it up after work and it still idles at 10.5 and is rough, maybe even missing though I'm not totally sure what that sounds like. So I let the car warm up and drive it home. Driving, the car is fine. Shifts fine, pulls fine, like nothing happened. When I get home...my idle is back to 18mm/hg and smooth.
This morning I start my car and it is back to the 10mm/hg deal...
Now, I've read info on low idle vacuum from posts here and elsehwere and it said low steady vacuum at idle can mean valve timing? Do I just take off the timing belt cover and look? How would I know? What is the signifigance of the idle/vacuum being rough, then fine, then rough. Any recommendations? Boost leak test is in the plans as soon as a make/get another tester.
Well, I went and got a compression test kit and some new spark plugs, and wouldn't it figure....rain. So it will have to wait. Meanwhile I have some more info that someone may be able to help figure this out with.
As I said, the car is idling low and rough when I start the car. After I drive the car for a while, it idles just fine and smooth. Today on a whim, I shut my car off after parking it and immediately restarted it and it's idling roughly and low again. That ring any bells?
I don't know if it is related but my waste-gate usually opens at about 10-11psi, but now it is boosting up to 13-14psi.
Also, I'm noticing the exhaust smell in the cab more. It smells a touch rich.
Hopefully I can post some compression numbers after this rain stops and I have the time. I will also try to post a video of whats going on. Thanks in advance tuners.
Sorry I must havemissed that. I think that you have a leak some where, but when it gets warm is swells or something to plug the leak.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
