Low Vacume?
SFRacingGST
235
May 4, 2004
Warren, Rhode Island
During my idle, on the boost guage it read about 20 most of the time but sometimes it goes up to as low as 15. I don't know if this is because it lost vacume pressure with the boost guage, boost controler, BOV??? I have alot of extras on it could this be the reason of low vacume or do you think i have a problem more than that.
don't worry about it unless it drops much below 15"
vaccuum can vary
possible problem would be boost/vacuum leaks
Your vacuum readings will vary depending on RPM as well, so a lower idle will make for a lower vacuum readings.
Also, build an intake tester and check for boost/vacuum leaks :thumb:
I have tested for leaks, and have none, at the same time, my guage at idle reads 14vacume, if I am under load(in gear while costing) it sits at 20vac, but as soon as I take it out of gear, and it comes back to idle, it goes right back to 14, this is my second DSM and they both varied, so far I don't see any problems with it....I think as your getting a decent vacume(10-20psi) then you should be fine
