low idle and bad squeek. safc help
faulkner
191
Apr 22, 2013
spring lake, Michigan
I just installed an apexi safc 2. Now my car idols bad and something squeeks under the hood.
Here's my mods. What settings on the safc should I dial in and what too? Please help!!
New pistons
ARP head studs
Evo 560cc injectors
Evo lifters
New heads
New rods
Evo III 16g turbo
3" turbo back apexi exhaust
Digital air fuel ratio and boost gauge
ACP stage 2 clutch
Evo hood
Here are a few old school links for the safc. The vfaq site has multiple links to some helpful information.
Apexi Super AFC For The Eclipse/EVO
RRE's Super AFC Setting and Adjustment Tips
Visual Frequently Answered Questions - Home Page
I would assume that the squeeking sound is one of the belts; not quite sure how that relates to a safc install though. Did you do anything else other than the safc install? Maybe a belt driven component under the hood is acting up because of some power/wiring issue causing a belt squeek?
As far as the idle, double check your initial safc settings with the links provided. Hopes this helps.
