low ideal and vac is at -10 than dies after 5 mins of running need help!!!
Spooolin!!
Feb 4, 2004
harbor city, California
ok heres what happend my t-belt sliped bent some valves, put a new head cleand all the lifters and stuff before puttuing it on. now when it starts my vac gage reads -10 and ideals really bad shakes alot than dies when running for a few minutes then when i try to start it again it ideals for a few seconds a dies. heres what i replaced plugs, wires, coil packs. if anyone can help that will be great thanks.
hey, i have the same problem, if u figure out whats wrong, lemme know
it runs like crap right?
and doesnt start sometimes?
smoke out of the exhaust?
i think its the ecu, but lemme know
yea it has thos sipmtoms but i already checked my ecu and it looks good. but ill let u know if i fix it soon. thanks
Make sure timing is correct. If you are unsure, get a second opinion from someone who has had experience. Its common for timing to be done incorrectly, and you have a loss of vacuum. Make sure MAF is plugged in and you have no boost leaks.
did timing like 3 times its good, maf is pluged in and did a boost test it was good no leaks.
What ever happened ? Did you guys fix your problems?
Let me know I'm having the same problem vac around -8 -10 with the same problems
Thanks
