Low Clutch Pressure
cola
163
3
Feb 24, 2011
Chicago, Illinois
It started one day on the highway, I was cruising in 5th gear for about twenty minutes and when I headed for the off ramp I had no clutch pressure and it was nearly impossible to shift.
I started pumping the clutch and eventually just enough pressure came back to limp home, making hard shifts at stops and while parking. I bled the clutch fluid, the problem went away.
A month later its back, I tried bleeding it but that only lasts for 15 minutes of driving and if I go any faster than 40 it looses all pressure.
this is the closest problem to mine I found with no answer..
http://www.dsmtuners.com/forums/drivetrain-tech/387165-weird-trouble-shifting.html
Make sure you have enough fluid and got all the air out of the system. Check for no leaks along the pressure lines.
I had close to a similar situation. Either your master or your clutch starting to go out. But at the moment your symptoms seems like the master. My problem was when I would come to a stop my clutch pedal would just sink down and I could not build pressure. I change the master and the problem went away. You might not see leaks but the master is on it's way to heaven for sure. My buddy had a leaking master to no problems so it works both ways.
I'm 100% sure it's your master!
Thanks, I have a FWD cylinder around...is there a difference between the AWD and FWD master cylinder?
While I agree with the others that it is probably your master cylinder, it cant hurt to check your lines as well. Have a buddy pump the clutch with the car off and get under the hook and watch all the connections. This happened to me a while back and it turned out that i had a small crack in my clutch line where the line fed into the slave banjo bolt. When the clutch was depressed, you could see a small mist of fluid.
I'd start at the slave cylinder and work my way up the clutch line, looking for drips and misting. It could be a crack in a line or a loose fitting. While it sounds like the master cylinder to me, It cant hurt to check your lines!
