sLoGSX
- 58
- 0
- Jan 7, 2004
Elkton,
Maryland
Well, I just put my built 6 bolt in and it has loud tapping. originally thought it was lifters, but i have brand new redesigned lifters. My car literally sounds like a diesel truck right now. I tried driving to get it to go away, but after 30 miles its still there. It seems as though it has actually gotten louder as the time has went by. I swapped out the lifters and put in the old ones and it's just as loud. I am running 20w50 non synthetic and did prime the motor before intial start-up. I even pulled the lifters, cleaned and oiled them according to vfaq and put them back in, before swapping back to the old ones. Below is a list of everything I had done at the shop. Any ideas of what my problem may be would be very useful.
Ross Pistons .30 over on Big Rods
Upgraded Springs & Titanium Retainers
Valves were checked and surface was grinded down slightly
New Valve Seals
Entire Head & Block Hot Tanked and Cleaned
Crank Polished
All ACL Bearings
Rotating assembly was balanced and assembled
BTW, the sound is coming from the top of the motor and is not the sound of a bearing issue. I have spun bearings and this is not the same sound.Thanks.
New Valve Seals
Crank Polished
All ACL Bearings
