Lots of questions, PLEASE HELP
wkulestat
78
Oct 2, 2003
Central City, Kentucky
Okay, I done some research and found that I should get an cooler in line flter from Magnafine or Filtran, and use diamond atf sp transmission fluid. My first question is where do I get these products? And where can I get a shit kit, and how hard is it to install? Also, If I am going to put a synthetic fluid in there,.. and I'm pretty sure it doesn't have synthetic already, can I just do a filter change, or do I need to do a flush? Also, I have seen a few different things on the fluid capacity, what is the totol fluid capacity, and what is the fluid capacity with just a filter change?
wkulestat said:
can no one help me out in any way?
Importperformancetrans.com should have just everything your dsm heart will desire :p
I use mobil Synthetic ATF with a black bottle of lubeguard to add into the mix and can get it all at Autozone...If your gonna change your fluids I would reccommend doing a whole flush if there isnt synthtic fluid in there to begin with mixing fluids doesnt sound like a good idea.
The way I've seen a flush done at my dad's shop is running a T fitting into one of the trans lines, and running fluid through a machine. I'm sure there are easier ways of doing it.
Mike
