Loss of power.
sprfunk
110
Aug 18, 2005
edmonds, Washington
I have a Gsx that got a new clutch recently. I just Noticed something is totally off. Once I push full throttle my car lags out. Now I can go up all the way to redline with less throttle. I know someone recently posted this kind of a problem but because mine is a turbo I thought it might be a different problem. The funny thing is that my car seem to be running fine. Well thanks in advance for your help.
Jay.
Jay.
I'm not sure that I clearly understand what you are saying but if your car feels like it's "lagging" when you get on the throttle while at the same time jumping up to redline it sounds like your clutch is slipping. It might not be adjusted properly. Did you break in the clutch as recommended by the manufacturer? I would take it back to the shop that put in your clutch and describe the problem and have them check the adjustment. Especially if it started right after the new clutch.
If you can be a little more specific about what your car is doing I will try to help more.
