loss of low end
racer_210
Jan 15, 2008
montesano, Washington
ok I just bought this car it is a 1990 laser rs turbo....it was a 1 owner car...with only 126000 miles on it ...nothing done to the car at all....
but under 3000 rpms it has no power and it sputters and misses...and it wont idle....already did full tune up ....the old guy was only runnig regular fuel the cars whole life...its gets spark and fuel....what else is there to check?
Do a boost leak test. If you bought anything other than NGK BPR6ES for spark plugs, change them to those, gapped to .028". Get a data logger as soon as you can and see what it tells you.
Please remember to use proper punctuation and capitalization here as much as you can. It does help others understand you and helps facilitate better searches in the future.
