losing pressure
aj7266
35
Jan 25, 2007
davidsonville, Maryland
i installed a walbro fuel pump and afpr and now when i turn off my car my fuel pressure drops and i have to turn my key forward and back a couple of times to get enough pressure to start my car .do i need some sort of check valve? where?if so
What walbro use ? When i put my walbro i have problem with the stock fuel line evry time the fuel pump hose going out.And the car it's runing but with extremly low fuel pressure.
Check you fuel hose inside in your gas tank or you fuel pump it's work good.
What kinde of fuel pressure regulator are you use. Be sure it's right installed.
i have an automotive fpr my pressure is fine while running but when i turn it off i lose it.think the hose in the tank is leaking?
