Looking to replace stock speakers in a '93
93||Talon
73
Oct 20, 2002
ATL, Georgia
I'm looking to replace the rear speakers in my 93 NT. I know the 6.5 will fit, but will the 5x7 or the 6x9 fit without needing any custom work? The reason I ask is because on circuitcity.com it shows that the only speakers that fit my Talon are 6.5.
Thanks :talon:
That only means that circuit dity doesn't have any 6x9's that will work. Try www.crutchfield.com. They list 4 6x9's that will fit (you're talking rear speakers, right?) It's hard to find 6x9s that mount flush, that's why so few models will fit.
Almost any 6x9 should fit if you use the grill that comes with the speaker, but it won't mount flsh and will stick up a bit, which might be annoying if you have a lot of back seat passengers.
93 DSMs usually have 6.5" in the back, my 90 had 6"x9" in the back. Don't always trust what Circuit City or Crutchfield tells you. Double check yourself.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
