Resolved Looking for the HKS Twin Power DLI ignition box manual
curt-s
Supporting Member
3,542
2,402
Dec 21, 2008
Winnipeg, MB, Canada
Trying to find the install manual for this sucker, model "43001-AK001".. if there's a 4g63-specific guide or whatnot. My car came with it but I didn't get pictures of its tie-in with the harness. I removed it at the time because I was troubleshooting lethargic acceleration (which turned out to be a whole host of things).
The best I could find was install instructions by some dude on a 3/S forum. Someone asked if its the same as installing it in a DSM, and this was his response.
I had one and you will find that it is painfully easy to connect.
Take off your entire coil pack from the engine. That's a simple 3 bolt process and unplug it from the wire harness.
Next you will see that the coils have blue wires with colored stripes going to them. Splice a single yellow wire from your HKS harness to each wire with a different color stripe.
You will only use 3 yellow wires, the others are not used, I just cut and taped them off.
Then connect the black wire to a good ground on the engine block!
Last, connect the red wire to the 4th wire on your harness which is common to all the coils. I think that it is blue w/ red stripe and you are finished.
Its a very simple connection. If you have the HKS connected correctly the red power light on the unit should light with your engine on.
Also found a picture of what he meant. It's using 3/S coils but should be the same in theory for a DSM.
Nowhere in any of my searches did that forum even come up. This is a great start!
F*cking found it. I still have the google-fu, just takes WAY more effort now.
Bam. This took awhile but here are the actual install instructions from forever ago. Damn this was hard to find. Lmao.
Dude. I owe you a beer. I've been searching for ages, I just suck at it apparently.
PM me your deets and I'll float you a lager.
Nah. I get my jollies off on helping people. Legitimately makes me feel better than alcohol. Your thanks is enough. I’m a weirdo like that.
