ECMlink logging advise
Rsawd95dsm
1,180
11
Feb 21, 2008
Zeeland, Michigan
Did my first log while just idling at operating temp and just want smart people to look over it and give tips and advise. thanks And a throttle adjust
what size injectors do you have? the air flow per rev looked decently good fluxuating from .28 to .25, but your combined fueltrims where way off. I would bump your global dead time up a little bit until you get your fuel trims. to be -/+ 5 percent. once you get that about right double check your air flow per rev if its not close to .25 you have to adjust your maf settings. if its higher then .25 change your 0hz and 50hz slider to higher if its lower then .25 adjust them down.
