Datalogs! Advise?
92tsifwd
572
Feb 1, 2004
Hastings, Nebraska
Check out these datalogs after the fmic install. The ic pipes keep blowing off. as you can probably see. Any advise on keeping the ic pipes on and tuning low thr? It seems to be running lean does it not? I cant atach the file because it is a microsoft exel file. If someone can give me there email address I can send the datalogs to them to look at. Thanks for any help. :)
Select the data you want to post with the right mouse button, then copy it. You can then paste it right into your post. It may not look exactly the same, but it will work. As far as the I/C pipe couplers, use t-bolt clamps, they will hold.
TIMA COOL FTRL FTRM FTRH FTO2 O2-R BATT BARO ISC TPS MAFS RPM KNCK INJP --- AIRT O2-F
7° 203.0°F 103.7% 99.8% 99.8% 99.8% 0.45V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.59V
7° 203.0°F 103.7% 99.8% 99.8% 101.4% 0.27V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 103.7% 0.25V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 105.3% 0.27V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
5° 203.0°F 104.5% 99.8% 99.8% 103.0% 0.62V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 101.4% 0.35V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 103.7% 0.43V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.63V
7° 203.0°F 105.3% 99.8% 99.8% 105.3% 0.57V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 102.2% 0.66V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 99.8% 0.59V 10.6% 44.0Hz 813 0 2.30ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 96.7% 0.49V 10.6% 44.0Hz 781 0 2.30ms 1 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 97.5% 0.33V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 99.8% 0.49V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.63V
6° 203.0°F 105.3% 99.8% 99.8% 98.3% 0.68V 10.6% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 95.9% 0.49V 10.6% 44.0Hz 781 0 2.30ms 1 27.5°F 2.61V
10° 203.0°F 104.5% 99.8% 99.8% 95.9% 0.18V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
10° 203.0°F 104.5% 99.8% 99.8% 98.3% 0.12V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.43V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.49V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 97.5% 0.62V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 103.7% 99.8% 99.8% 95.9% 0.21V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.59V
8° 203.0°F 103.7% 99.8% 99.8% 97.5% 0.06V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.59V
7° 203.0°F 103.7% 99.8% 99.8% 99.8% 0.06V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.59V
8° 203.0°F 103.7% 99.8% 99.8% 101.4% 0.23V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
6° 203.0°F 103.7% 99.8% 99.8% 103.7% 0.49V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
6° 203.0°F 104.5% 99.8% 99.8% 100.6% 0.62V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 99.1% 0.29V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 100.6% 0.14V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 103.0% 0.35V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 103.0% 0.62V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.49V 11.0% 44.0Hz 750 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.14V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 101.4% 0.47V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 105.3% 99.8% 99.8% 99.1% 0.66V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.63V
8° 203.0°F 104.5% 99.8% 99.8% 96.7% 0.66V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 95.2% 0.23V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 96.7% 0.16V 11.0% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 99.1% 0.08V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 101.4% 0.06V 10.6% 44.0Hz 781 0 2.56ms 2 26.5°F 2.61V
6° 203.0°F 104.5% 99.8% 99.8% 102.2% 0.53V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.66V 10.6% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 97.5% 0.37V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.20V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 101.4% 0.45V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 99.1% 0.60V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 95.9% 0.47V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 203.0°F 104.5% 99.8% 99.8% 96.7% 0.08V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 203.0°F 103.7% 99.8% 99.8% 99.1% 0.25V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 203.0°F 103.7% 99.8% 99.8% 100.6% 0.51V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 203.0°F 103.7% 99.8% 99.8% 100.6% 0.25V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 203.0°F 104.5% 99.8% 99.8% 101.4% 0.43V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 203.0°F 104.5% 99.8% 99.8% 99.8% 0.57V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 97.5% 0.59V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
9° 206.4°F 104.5% 99.8% 99.8% 96.7% 0.51V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 98.3% 0.18V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
7° 206.4°F 103.7% 99.8% 99.8% 100.6% 0.10V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.59V
9° 206.4°F 103.7% 99.8% 99.8% 102.2% 0.18V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 102.2% 0.60V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 99.1% 0.60V 10.6% 44.0Hz 750 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 99.8% 0.20V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
6° 206.4°F 104.5% 99.8% 99.8% 102.2% 0.39V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 100.6% 0.57V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 99.1% 0.59V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 98.3% 0.51V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 99.8% 0.10V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 101.4% 0.18V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 103.7% 0.45V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
9° 206.4°F 104.5% 99.8% 99.8% 104.5% 0.55V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 102.2% 0.66V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 99.1% 0.57V 11.0% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 97.5% 0.35V 11.0% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 95.9% 0.51V 10.6% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
7° 206.4°F 104.5% 99.8% 99.8% 95.2% 0.39V 11.0% 44.0Hz 813 0 2.30ms 2 27.5°F 2.61V
8° 206.4°F 104.5% 99.8% 99.8% 96.7% 0.14V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 98.3% 0.55V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 97.5% 0.60V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.59V
9° 206.4°F 103.7% 99.8% 99.8% 98.3% 0.23V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 99.8% 0.20V 10.6% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 100.6% 0.47V 11.0% 44.0Hz 781 0 2.56ms 2 27.5°F 2.59V
7° 206.4°F 103.7% 99.8% 99.8% 99.8% 0.47V 11.0% 44.0Hz 813 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 100.6% 0.18V 10.6% 44.0Hz 813 0 2.56ms 2 27.5°F 2.59V
8° 206.4°F 103.7% 99.8% 99.8% 103.0% 0.45V 11.4% 44.0Hz 813 0 2.56ms 2 27.5°F 2.61V
9° 206.4°F 104.5% 99.8% 99.8% 103.7% 0.16V 14.9% 62.9Hz 875 0 3.07ms 2 27.5°F 2.61V
10° 206.4°F 104.5% 99.8% 99.8% 105.3% 0.00V 16.5% 88.1Hz 969 0 3.84ms 3 27.5°F 2.61V
17° 206.4°F 104.5% 99.8% 99.8% 110.0% 0.00V 17.3% 106.9Hz 1219 0 3.84ms 5 27.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 121.7% 0.00V 18.0% 119.5Hz 1313 0 4.10ms 5 26.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 132.6% 0.00V 18.4% 119.5Hz 1250 0 4.35ms 5 26.5°F 2.61V
21° 206.4°F 104.5% 99.8% 99.8% 141.2% 0.06V 18.4% 106.9Hz 1000 0 4.86ms 5 26.5°F 2.61V
13° 206.4°F 104.5% 99.8% 99.8% 149.0% 0.43V 18.8% 100.6Hz 844 0 5.12ms 4 26.5°F 2.61V
11° 206.4°F 104.5% 99.8% 99.8% 143.5% 0.68V 19.2% 119.5Hz 1094 0 4.86ms 5 26.5°F 2.61V
19° 206.4°F 104.5% 99.8% 99.8% 139.6% 0.14V 19.2% 125.8Hz 1250 0 4.61ms 6 26.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 151.3% 0.04V 19.6% 138.4Hz 1406 0 4.61ms 6 26.5°F 2.61V
28° 206.4°F 104.5% 99.8% 99.8% 156.0% 0.74V 19.6% 144.7Hz 1594 0 4.10ms 6 26.5°F 2.61V
29° 206.4°F 104.5% 99.8% 99.8% 142.7% 0.80V 19.6% 151.0Hz 1781 0 3.84ms 7 26.5°F 2.61V
30° 206.4°F 104.5% 99.8% 99.8% 124.0% 0.76V 19.6% 151.0Hz 1906 0 3.58ms 7 26.5°F 2.61V
32° 206.4°F 104.5% 99.8% 99.8% 107.6% 0.68V 19.6% 151.0Hz 2000 0 3.33ms 7 26.5°F 2.61V
33° 206.4°F 104.5% 99.8% 99.8% 117.0% 0.08V 19.6% 151.0Hz 2094 0 3.33ms 7 26.5°F 2.61V
34° 206.4°F 104.5% 99.8% 99.8% 126.4% 0.80V 19.6% 151.0Hz 2219 0 3.07ms 7 25.5°F 2.61V
34° 206.4°F 104.5% 99.8% 99.8% 113.1% 0.70V 19.6% 151.0Hz 2313 0 3.07ms 7 25.5°F 2.61V
35° 206.4°F 104.5% 99.8% 99.8% 113.1% 0.12V 19.6% 151.0Hz 2406 0 3.07ms 7 25.5°F 2.61V
36° 206.4°F 104.5% 99.8% 99.8% 114.7% 0.78V 19.6% 151.0Hz 2438 0 2.82ms 7 25.5°F 2.61V
36° 206.4°F 104.5% 99.8% 99.8% 109.2% 0.16V 19.6% 151.0Hz 2531 0 2.82ms 7 25.5°F 2.61V
36° 206.4°F 104.5% 99.8% 99.8% 118.6% 0.80V 19.6% 144.7Hz 2563 0 2.82ms 7 24.5°F 2.61V
36° 206.4°F 104.5% 99.8% 99.8% 100.6% 0.82V 11.0% 88.1Hz 2594 0 1.54ms 4 24.5°F 2.61V
38° 206.4°F 104.5% 99.8% 99.8% 81.9% 0.90V 11.0% 62.9Hz 2438 0 1.54ms 4 24.5°F 2.61V
38° 206.4°F 104.5% 99.8% 99.8% 66.3% 0.88V 11.0% 62.9Hz 2188 0 1.54ms 3 24.5°F 2.61V
37° 206.4°F 104.5% 99.8% 99.8% 53.0% 0.88V 11.0% 62.9Hz 1938 0 1.54ms 3 24.5°F 2.61V
34° 206.4°F 104.5% 99.8% 99.8% 40.6% 0.84V 11.0% 56.6Hz 1813 0 1.54ms 2 24.5°F 2.61V
38° 206.4°F 104.5% 99.8% 99.8% 33.5% 0.29V 11.0% 62.9Hz 1656 0 1.54ms 2 24.5°F 2.61V
27° 206.4°F 104.5% 99.8% 99.8% 44.5% 0.16V 11.0% 56.6Hz 1500 0 1.79ms 2 24.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 44.5% 0.80V 11.0% 62.9Hz 1438 0 1.79ms 2 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 39.8% 0.18V 11.0% 62.9Hz 1438 0 1.79ms 2 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 48.4% 0.08V 12.2% 69.2Hz 1469 0 2.05ms 3 24.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 56.9% 0.06V 12.5% 75.5Hz 1438 0 2.05ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 66.3% 0.04V 12.5% 75.5Hz 1406 0 2.30ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 77.2% 0.04V 12.9% 75.5Hz 1438 0 2.30ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 85.8% 0.06V 12.9% 75.5Hz 1438 0 2.30ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 94.4% 0.06V 12.9% 75.5Hz 1438 0 2.30ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 99.8% 0.70V 12.9% 75.5Hz 1469 0 2.30ms 3 24.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 90.5% 0.70V 12.9% 75.5Hz 1469 0 2.30ms 3 24.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 91.3% 0.10V 11.4% 75.5Hz 1469 0 2.30ms 3 24.5°F 2.61V
24° 206.4°F 104.5% 99.8% 99.8% 97.5% 0.78V 11.0% 62.9Hz 1438 0 2.05ms 3 24.5°F 2.61V
23° 206.4°F 104.5% 99.8% 99.8% 88.1% 0.88V 11.0% 62.9Hz 1438 0 2.05ms 3 24.5°F 2.59V
22° 206.4°F 103.7% 99.8% 99.8% 79.6% 0.86V 11.0% 56.6Hz 1406 0 1.79ms 2 24.5°F 2.59V
23° 206.4°F 103.7% 99.8% 99.8% 70.2% 0.45V 11.0% 56.6Hz 1438 0 1.79ms 2 24.5°F 2.59V
22° 206.4°F 103.7% 99.8% 99.8% 78.8% 0.10V 11.0% 56.6Hz 1438 0 1.79ms 2 24.5°F 2.59V
22° 206.4°F 103.7% 99.8% 99.8% 87.4% 0.08V 11.0% 56.6Hz 1406 0 2.05ms 3 24.5°F 2.59V
21° 206.4°F 103.0% 99.8% 99.8% 93.6% 0.68V 11.0% 56.6Hz 1406 0 1.79ms 2 24.5°F 2.57V
21° 206.4°F 103.0% 99.8% 99.8% 84.2% 0.80V 11.0% 56.6Hz 1375 0 2.05ms 3 24.5°F 2.57V
22° 206.4°F 103.0% 99.8% 99.8% 82.7% 0.16V 11.0% 62.9Hz 1375 0 2.05ms 3 24.5°F 2.57V
22° 206.4°F 103.0% 99.8% 99.8% 89.7% 0.08V 11.0% 62.9Hz 1375 0 2.05ms 3 24.5°F 2.57V
22° 206.4°F 103.0% 99.8% 99.8% 94.4% 0.72V 11.0% 69.2Hz 1406 0 2.05ms 3 24.5°F 2.55V
22° 206.4°F 102.2% 99.8% 99.8% 86.6% 0.68V 12.5% 69.2Hz 1406 0 2.30ms 3 24.5°F 2.55V
23° 206.4°F 102.2% 99.8% 99.8% 89.7% 0.08V 12.9% 75.5Hz 1438 0 2.30ms 3 23.5°F 2.55V
22° 206.4°F 102.2% 99.8% 99.8% 99.1% 0.04V 15.7% 88.1Hz 1438 0 2.82ms 4 23.5°F 2.55V
25° 206.4°F 102.2% 99.8% 99.8% 110.0% 0.04V 16.9% 106.9Hz 1438 0 3.33ms 5 23.5°F 2.55V
26° 206.4°F 102.2% 99.8% 99.8% 122.5% 0.04V 17.3% 113.2Hz 1438 0 3.58ms 5 23.5°F 2.55V
27° 206.4°F 102.2% 99.8% 99.8% 134.2% 0.08V 17.6% 119.5Hz 1469 0 3.84ms 6 23.5°F 2.55V
27° 206.4°F 102.2% 99.8% 99.8% 132.6% 0.80V 17.6% 119.5Hz 1469 0 3.58ms 5 23.5°F 2.55V
28° 206.4°F 102.2% 99.8% 99.8% 120.1% 0.68V 17.6% 119.5Hz 1531 0 3.58ms 5 23.5°F 2.55V
28° 206.4°F 102.2% 99.8% 99.8% 120.9% 0.14V 18.0% 125.8Hz 1563 0 3.58ms 5 23.5°F 2.55V
29° 206.4°F 102.2% 99.8% 99.8% 134.9% 0.64V 19.2% 138.4Hz 1594 0 3.84ms 6 23.5°F 2.55V
29° 206.4°F 102.2% 99.8% 99.8% 120.1% 0.78V 20.0% 151.0Hz 1656 0 4.10ms 7 23.5°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 104.5% 0.55V 20.0% 157.3Hz 1719 0 4.10ms 7 22.4°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 116.2% 0.27V 20.4% 163.5Hz 1781 0 4.10ms 7 22.4°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 106.9% 0.72V 20.4% 163.5Hz 1813 0 3.84ms 7 22.4°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 107.6% 0.08V 20.4% 163.5Hz 1875 0 4.10ms 8 22.4°F 2.55V
31° 206.4°F 102.2% 99.8% 99.8% 113.9% 0.80V 20.4% 163.5Hz 1938 0 3.84ms 7 22.4°F 2.55V
31° 206.4°F 102.2% 99.8% 99.8% 96.7% 0.68V 20.4% 163.5Hz 1969 0 1.02ms 2 22.4°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 98.3% 0.06V 32.9% 283.1Hz 2031 0 6.14ms 13 22.4°F 2.55V
24° 206.4°F 102.2% 99.8% 99.8% 119.3% 0.04V 36.1% 320.8Hz 2219 0 6.91ms 16 21.4°F 2.55V
24° 206.4°F 102.2% 99.8% 99.8% 122.5% 0.80V 34.5% 352.2Hz 2375 1 6.66ms 16 21.4°F 2.55V
23° 206.4°F 102.2% 99.8% 99.8% 100.6% 0.76V 34.5% 371.1Hz 2500 1 7.42ms 19 21.4°F 2.55V
22° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.88V 58.4% 509.5Hz 2719 0 9.98ms 29 21.4°F 2.55V
19° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.90V 75.7% 641.6Hz 2906 0 12.80ms 39 20.4°F 2.55V
15° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.90V 89.0% 861.7Hz 3219 0 17.41ms 59 20.4°F 2.55V
14° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.90V 91.0% 1163.7Hz 3594 4 19.97ms 76 19.4°F 2.55V
14° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.88V 92.2% 1434.1Hz 4094 4 20.48ms 89 19.4°F 2.55V
16° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.88V 92.5% 1597.7Hz 4750 3 22.78ms 115 18.3°F 2.55V
18° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.88V 96.1% 1604.0Hz 6094 2 23.30ms 151 18.3°F 2.55V
22° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.64V 99.6% 1528.5Hz 4906 2 18.18ms 95 17.2°F 2.55V
16° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.49V 88.2% 1207.7Hz 4656 1 13.31ms 66 17.2°F 2.55V
25° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.66V 10.6% 597.6Hz 4063 0 7.17ms 31 17.2°F 2.55V
29° 206.4°F 102.2% 99.8% 99.8% 86.6% 0.62V 10.6% 452.9Hz 3469 0 5.63ms 20 17.2°F 2.55V
30° 206.4°F 102.2% 99.8% 99.8% 54.6% 0.62V 10.6% 390.0Hz 2906 0 5.38ms 16 18.3°F 2.55V
29° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.60V 10.6% 346.0Hz 2438 0 0.00ms 0 18.3°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.66V 10.6% 301.9Hz 2000 0 0.00ms 0 18.3°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.04V 10.6% 276.8Hz 1563 0 0.00ms 0 18.3°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 195.0Hz 1188 0 0.00ms 0 18.3°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 220.2Hz 1313 0 0.00ms 0 19.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 270.5Hz 1750 0 0.00ms 0 19.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 232.7Hz 1750 0 0.00ms 0 19.4°F 2.55V
11° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 226.4Hz 1656 0 0.00ms 0 19.4°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 226.4Hz 1625 0 0.00ms 0 19.4°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 10.6% 220.2Hz 1625 0 0.00ms 0 19.4°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.00V 21.6% 226.4Hz 1594 0 7.42ms 12 19.4°F 2.55V
18° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.94V 23.1% 264.2Hz 1531 0 8.96ms 14 19.4°F 2.55V
16° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.96V 23.5% 327.1Hz 1531 0 11.26ms 18 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.86V 28.2% 346.0Hz 1469 0 11.26ms 17 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 21.2% 327.1Hz 1469 0 12.03ms 18 19.4°F 2.55V
11° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.62V 29.8% 364.8Hz 1531 0 11.78ms 19 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 33.7% 346.0Hz 1531 0 11.52ms 18 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 33.7% 320.8Hz 1469 0 11.26ms 17 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 27.8% 346.0Hz 1500 0 11.78ms 18 19.4°F 2.55V
11° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.94V 27.8% 364.8Hz 1531 0 11.26ms 18 19.4°F 2.55V
12° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 27.8% 320.8Hz 1375 0 8.96ms 13 19.4°F 2.55V
15° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.96V 28.2% 251.6Hz 1563 0 11.52ms 19 19.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.98V 26.3% 390.0Hz 1438 4 8.45ms 12 19.4°F 2.55V
13° 206.4°F 102.2% 99.8% 99.8% 99.1% 0.99V 11.0% 213.9Hz 1313 6 10.24ms 14 19.4°F 2.55V
3° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.66V 11.0% 346.0Hz 1594 5 10.50ms 17 19.4°F 2.55V
19° 206.4°F 102.2% 99.8% 99.8% 99.8% 0.66V 11.0% 283.1Hz 1313 5 8.45ms 11 19.4°F 2.55V
20° 206.4°F 102.2% 99.8% 99.8% 94.4% 0.66V 11.0% 151.0Hz 906 4 5.89ms 5 19.4°F 2.55V
15° 206.4°F 102.2% 99.8% 99.8% 89.7% 0.66V 11.0% 81.8Hz 563 4 5.63ms 3 19.4°F 2.55V
14° 206.4°F 102.2% 99.8% 99.8% 85.0% 0.66V 11.0% 50.3Hz 375 3 5.38ms 2 19.4°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 82.7% 0.86V 11.0% 56.6Hz 406 3 5.38ms 2 19.4°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 78.8% 0.98V 11.0% 106.9Hz 813 2 5.63ms 4 19.4°F 2.55V
2° 206.4°F 102.2% 99.8% 99.8% 71.8% 0.96V 11.0% 163.5Hz 1000 2 5.89ms 6 19.4°F 2.55V
4° 206.4°F 102.2% 99.8% 99.8% 64.7% 0.90V 11.0% 113.2Hz 750 1 5.38ms 4 19.4°F 2.55V
15° 206.4°F 102.2% 99.8% 99.8% 59.3% 0.98V 11.0% 88.1Hz 625 1 5.12ms 3 19.4°F 2.55V
15° 206.4°F 102.2% 99.8% 99.8% 54.6% 0.98V 11.0% 94.4Hz 688 1 5.38ms 3 19.4°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 49.1% 0.98V 11.0% 106.9Hz 719 0 5.12ms 3 19.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 43.7% 0.98V 11.0% 106.9Hz 688 0 5.12ms 3 19.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 39.0% 0.98V 11.0% 100.6Hz 688 0 5.12ms 3 20.4°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 5.12ms 3 20.4°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 20.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 20.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 719 0 4.86ms 3 20.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 719 0 4.86ms 3 20.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 100.6Hz 688 0 4.86ms 3 20.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 100.6Hz 688 0 4.86ms 3 20.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 100.6Hz 719 0 4.86ms 3 20.4°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 106.9Hz 719 0 4.86ms 3 20.4°F 2.55V
4° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 20.4°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 20.4°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 20.4°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 20.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 20.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 21.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 719 0 4.86ms 3 21.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.98V 11.0% 106.9Hz 750 0 4.86ms 3 21.4°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 21.4°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 688 0 4.86ms 3 21.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 21.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 106.9Hz 719 0 4.86ms 3 21.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 21.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 22.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 22.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 22.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 22.4°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 119.5Hz 750 0 4.86ms 3 22.4°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 22.4°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 750 0 4.86ms 3 23.5°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 23.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 23.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 23.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 24.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 24.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 719 0 4.86ms 3 24.5°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 24.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 781 0 4.86ms 4 24.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 25.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 25.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 25.5°F 2.55V
5° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 106.9Hz 719 0 4.86ms 3 25.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.98V 11.0% 113.2Hz 750 0 4.86ms 3 25.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 26.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 26.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 26.5°F 2.55V
9° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 26.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 26.5°F 2.55V
8° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 26.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 106.9Hz 750 0 4.86ms 3 27.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 27.5°F 2.55V
10° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 113.2Hz 719 0 4.86ms 3 27.5°F 2.55V
7° 206.4°F 102.2% 99.8% 99.8% 31.2% 0.96V 11.0% 113.2Hz 750 0 4.86ms 3 27.5°F 2.55V
6° 206.4°F 102.2% 99.8% 99.8% 32.8% 0.96V 11.0% 119.5Hz 781 0 4.86ms 4 27.5°F 2.55V
I think you can understand that? My ic pipe bew off at 4650rpms at wot. This was creeping to 20psi. What should I do with the low thr settings? I am using a safc2 to tune with. My mods are in my profile. Too many to list. Thanks for the help in advance. :thumb:
just a suggestion on the intercooler piping, i used twice as many clamps to hold on my intercooler piping, so if one gives out then the other is there to hold the piping together, also i sprayed my piping with hairspray to make it stick.
why are you logging so much at one time? Pick just the basics, knock, o2s, timing,TPS, injectors
all the other stuff is not needed and it slows down the data as it is sent to the palm.
When you datalog, and show it on here, please only show the RPM, timing, O2 voltage, and knock. You can show the TPS if you want but not all that shiit you did in the first post.
TIMA COOL FTRL FTRM FTRH FTO2 O2-R BARO ISC TPS MAFS RPM KNCK INJP --- AIRT O2-F
10° 209.8°F 91.3% 99.8% 99.8% 103.0% 0.08V 34 11.0% 37.7Hz 844 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 105.3% 0.25V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 104.5% 0.70V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.30V
10° 209.8°F 92.0% 99.8% 99.8% 101.4% 0.76V 34 11.0% 37.7Hz 844 0 2.05ms 1 75.8°F 2.30V
10° 209.8°F 92.0% 99.8% 99.8% 98.3% 0.72V 34 11.0% 44.0Hz 844 0 2.05ms 1 75.8°F 2.30V
10° 209.8°F 92.0% 99.8% 99.8% 95.2% 0.70V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 93.6% 0.39V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.28V
9° 209.8°F 91.3% 99.8% 99.8% 95.9% 0.14V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.28V
9° 209.8°F 91.3% 99.8% 99.8% 97.5% 0.10V 34 11.0% 37.7Hz 781 0 2.05ms 1 75.8°F 2.28V
9° 209.8°F 91.3% 99.8% 99.8% 99.8% 0.08V 34 11.0% 37.7Hz 813 0 2.05ms 1 75.8°F 2.28V
9° 209.8°F 91.3% 99.8% 99.8% 101.4% 0.10V 34 11.0% 44.0Hz 813 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 103.7% 0.27V 34 11.0% 44.0Hz 844 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 106.1% 0.47V 34 11.0% 44.0Hz 844 0 2.05ms 1 75.8°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 107.6% 0.55V 34 11.0% 44.0Hz 875 0 2.05ms 1 75.8°F 2.30V
10° 209.8°F 92.0% 99.8% 99.8% 104.5% 0.72V 34 11.0% 44.0Hz 875 0 2.05ms 1 75.8°F 2.30V
11° 209.8°F 92.0% 99.8% 99.8% 101.4% 0.68V 34 11.0% 37.7Hz 844 0 2.05ms 1 75.8°F 2.30V
10° 209.8°F 92.0% 99.8% 99.8% 98.3% 0.64V 34 11.0% 37.7Hz 750 0 2.05ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 95.2% 0.64V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 91.3% 99.8% 99.8% 93.6% 0.29V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 93.6% 0.55V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 91.3% 0.66V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 89.7% 0.29V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 91.3% 0.10V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 93.6% 0.06V 34 11.0% 44.0Hz 750 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 95.2% 0.04V 34 11.0% 44.0Hz 750 0 2.05ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 96.7% 0.04V 34 11.0% 37.7Hz 750 0 2.05ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 99.1% 0.04V 34 11.0% 37.7Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 100.6% 0.04V 34 11.0% 37.7Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 102.2% 0.14V 37 12.9% 37.7Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 103.7% 0.53V 49 14.9% 50.3Hz 719 0 2.82ms 2 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 105.3% 0.04V 51 14.9% 62.9Hz 781 0 3.07ms 2 75.8°F 2.26V
9° 209.8°F 90.5% 99.8% 99.8% 107.6% 0.02V 51 14.9% 69.2Hz 875 0 2.82ms 2 75.8°F 2.26V
11° 209.8°F 90.5% 99.8% 99.8% 110.0% 0.00V 51 14.9% 69.2Hz 969 0 2.82ms 2 75.8°F 2.26V
14° 209.8°F 90.5% 99.8% 99.8% 112.3% 0.00V 51 11.0% 69.2Hz 1063 0 2.30ms 2 75.8°F 2.26V
15° 209.8°F 90.5% 99.8% 99.8% 117.8% 0.04V 34 11.0% 44.0Hz 1000 0 2.05ms 2 75.8°F 2.26V
12° 209.8°F 90.5% 99.8% 99.8% 117.0% 0.74V 34 11.0% 37.7Hz 781 0 2.05ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 112.3% 0.80V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 108.4% 0.80V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 103.7% 0.82V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 99.8% 0.82V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 95.9% 0.76V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 92.0% 0.53V 34 11.0% 37.7Hz 625 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 95.9% 0.12V 34 11.0% 44.0Hz 656 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 99.8% 0.06V 34 11.0% 44.0Hz 656 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 103.0% 0.06V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 106.9% 0.20V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 106.9% 0.57V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 103.0% 0.68V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 99.1% 0.64V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 96.7% 0.49V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 97.5% 0.20V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 99.1% 0.20V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 101.4% 0.43V 34 11.0% 44.0Hz 750 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 100.6% 0.53V 34 11.0% 44.0Hz 781 0 2.30ms 1 75.8°F 2.26V
9° 209.8°F 90.5% 99.8% 99.8% 100.6% 0.41V 34 11.0% 37.7Hz 750 0 2.30ms 1 75.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 102.2% 0.20V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 103.7% 0.12V 34 11.0% 37.7Hz 625 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 105.3% 0.20V 34 11.0% 37.7Hz 656 0 2.56ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 106.1% 0.62V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 103.7% 0.74V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 100.6% 0.76V 34 11.0% 44.0Hz 750 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 97.5% 0.70V 34 11.0% 44.0Hz 750 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 96.7% 0.31V 34 11.0% 37.7Hz 719 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 99.1% 0.14V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 100.6% 0.10V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 102.2% 0.10V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 103.7% 0.55V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 100.6% 0.70V 34 11.0% 44.0Hz 719 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 98.3% 0.68V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 91.3% 99.8% 99.8% 95.9% 0.47V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 96.7% 0.10V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 98.3% 0.04V 34 11.0% 37.7Hz 656 0 2.56ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 656 0 2.56ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 102.2% 0.02V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 103.7% 0.25V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 105.3% 0.41V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 105.3% 0.55V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 102.2% 0.60V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 102.2% 0.31V 34 11.0% 37.7Hz 656 0 2.30ms 1 75.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 103.7% 0.14V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 105.3% 0.16V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 106.9% 0.18V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 107.6% 0.57V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 105.3% 0.68V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.32V
8° 209.8°F 93.6% 99.8% 99.8% 103.0% 0.43V 34 11.0% 37.7Hz 656 0 2.56ms 1 75.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.14V 34 11.0% 44.0Hz 688 0 2.56ms 1 75.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 106.1% 0.39V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.72V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 102.2% 0.62V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 100.6% 0.59V 34 11.0% 37.7Hz 656 0 2.56ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 100.6% 0.21V 34 11.0% 44.0Hz 688 0 2.56ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 103.0% 0.21V 34 11.0% 44.0Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 102.2% 0.68V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 99.8% 0.70V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 97.5% 0.55V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 98.3% 0.16V 34 11.0% 37.7Hz 688 0 2.30ms 1 75.8°F 2.36V
8° 213.1°F 95.9% 99.8% 99.8% 94.4% 0.55V 34 11.0% 37.7Hz 656 0 2.30ms 1 76.6°F 2.40V
8° 213.1°F 95.9% 99.8% 99.8% 92.8% 0.59V 34 11.0% 37.7Hz 656 0 2.30ms 1 76.6°F 2.40V
8° 213.1°F 95.9% 99.8% 99.8% 91.3% 0.25V 34 11.0% 37.7Hz 688 0 2.30ms 1 76.6°F 2.40V
8° 213.1°F 95.9% 99.8% 99.8% 93.6% 0.08V 34 11.0% 44.0Hz 656 0 2.30ms 1 76.6°F 2.40V
8° 213.1°F 95.9% 99.8% 99.8% 95.2% 0.06V 34 11.0% 44.0Hz 656 0 2.30ms 1 76.6°F 2.38V
8° 213.1°F 95.2% 99.8% 99.8% 96.7% 0.04V 34 11.0% 44.0Hz 656 0 2.30ms 1 76.6°F 2.38V
8° 213.1°F 95.2% 99.8% 99.8% 98.3% 0.12V 34 11.0% 37.7Hz 656 0 2.30ms 1 76.6°F 2.38V
8° 213.1°F 95.2% 99.8% 99.8% 99.8% 0.59V 34 11.0% 44.0Hz 719 0 2.30ms 1 76.6°F 2.38V
8° 213.1°F 95.2% 99.8% 99.8% 96.7% 0.70V 34 11.0% 44.0Hz 750 0 2.30ms 1 76.6°F 2.38V
8° 213.1°F 95.2% 99.8% 99.8% 94.4% 0.60V 34 11.0% 44.0Hz 750 0 2.30ms 1 76.6°F 2.36V
8° 213.1°F 94.4% 99.8% 99.8% 94.4% 0.35V 34 11.0% 44.0Hz 750 0 2.30ms 1 76.6°F 2.36V
8° 213.1°F 94.4% 99.8% 99.8% 95.9% 0.14V 34 11.0% 37.7Hz 750 0 2.30ms 1 76.6°F 2.36V
8° 213.1°F 94.4% 99.8% 99.8% 97.5% 0.14V 34 11.0% 37.7Hz 719 0 2.30ms 1 76.6°F 2.36V
8° 213.1°F 94.4% 99.8% 99.8% 98.3% 0.64V 34 11.0% 37.7Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 213.1°F 93.6% 99.8% 99.8% 95.2% 0.72V 52 15.7% 50.3Hz 688 0 3.07ms 2 76.6°F 2.34V
8° 213.1°F 93.6% 99.8% 99.8% 93.6% 0.14V 57 16.5% 75.5Hz 844 0 3.07ms 2 76.6°F 2.34V
12° 213.1°F 93.6% 99.8% 99.8% 95.9% 0.02V 63 16.5% 88.1Hz 1031 0 3.07ms 3 76.6°F 2.34V
16° 213.1°F 93.6% 99.8% 99.8% 100.6% 0.00V 72 16.5% 81.8Hz 1156 0 2.82ms 3 76.6°F 2.34V
17° 209.8°F 93.6% 99.8% 99.8% 107.6% 0.00V 69 15.7% 75.5Hz 1094 0 2.82ms 3 76.6°F 2.34V
14° 213.1°F 93.6% 99.8% 99.8% 113.1% 0.00V 49 11.0% 62.9Hz 1031 0 2.30ms 2 76.6°F 2.34V
13° 209.8°F 93.6% 99.8% 99.8% 119.3% 0.49V 41 11.0% 44.0Hz 906 0 2.05ms 1 76.6°F 2.34V
11° 209.8°F 93.6% 99.8% 99.8% 114.7% 0.78V 34 11.0% 44.0Hz 875 0 2.05ms 1 76.6°F 2.34V
10° 209.8°F 93.6% 99.8% 99.8% 110.0% 0.78V 34 11.0% 37.7Hz 813 0 2.05ms 1 76.6°F 2.34V
9° 209.8°F 93.6% 99.8% 99.8% 105.3% 0.78V 34 11.0% 37.7Hz 781 0 2.05ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.78V 34 11.0% 37.7Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 96.7% 0.78V 34 11.0% 37.7Hz 656 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 92.0% 0.78V 34 11.0% 37.7Hz 688 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 88.1% 0.76V 34 11.0% 37.7Hz 656 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 84.2% 0.55V 34 11.0% 44.0Hz 688 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 83.5% 0.33V 34 11.0% 44.0Hz 688 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 87.4% 0.10V 34 11.0% 44.0Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 91.3% 0.06V 34 11.0% 44.0Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 94.4% 0.04V 34 11.0% 44.0Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 98.3% 0.02V 34 11.0% 44.0Hz 750 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 101.4% 0.02V 34 11.0% 44.0Hz 750 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 103.0% 0.04V 38 11.8% 44.0Hz 688 0 2.56ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.31V 47 14.1% 44.0Hz 594 0 3.33ms 2 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.68V 41 11.0% 56.6Hz 688 0 2.82ms 2 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 101.4% 0.80V 34 11.0% 56.6Hz 906 0 2.30ms 2 76.6°F 2.34V
12° 209.8°F 93.6% 99.8% 99.8% 98.3% 0.80V 34 11.0% 50.3Hz 1000 0 2.05ms 2 76.6°F 2.34V
13° 209.8°F 93.6% 99.8% 99.8% 94.4% 0.49V 34 12.2% 44.0Hz 969 0 2.05ms 2 76.6°F 2.34V
12° 209.8°F 93.6% 99.8% 99.8% 95.9% 0.06V 49 14.5% 50.3Hz 813 0 2.56ms 2 76.6°F 2.34V
9° 209.8°F 93.6% 99.8% 99.8% 98.3% 0.00V 49 14.5% 56.6Hz 750 0 2.82ms 2 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.00V 51 14.9% 62.9Hz 750 0 3.07ms 2 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 102.2% 0.00V 43 11.0% 62.9Hz 875 0 2.56ms 2 76.6°F 2.34V
11° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.00V 34 11.0% 50.3Hz 969 0 2.05ms 2 76.6°F 2.34V
13° 209.8°F 93.6% 99.8% 99.8% 106.9% 0.12V 34 11.0% 44.0Hz 969 0 2.05ms 2 76.6°F 2.34V
12° 209.8°F 93.6% 99.8% 99.8% 109.2% 0.10V 34 11.0% 44.0Hz 969 0 2.05ms 2 76.6°F 2.34V
12° 209.8°F 93.6% 99.8% 99.8% 111.5% 0.04V 34 11.0% 44.0Hz 969 0 1.79ms 1 76.6°F 2.34V
12° 209.8°F 93.6% 99.8% 99.8% 113.9% 0.53V 34 11.0% 37.7Hz 844 0 2.05ms 1 76.6°F 2.34V
10° 209.8°F 93.6% 99.8% 99.8% 110.8% 0.70V 39 12.2% 37.7Hz 750 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 107.6% 0.74V 41 12.5% 44.0Hz 750 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 105.3% 0.70V 41 11.8% 44.0Hz 656 0 2.56ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 103.7% 0.53V 34 11.0% 44.0Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 100.6% 0.78V 34 11.0% 44.0Hz 781 0 2.30ms 1 76.6°F 2.34V
9° 209.8°F 93.6% 99.8% 99.8% 97.5% 0.74V 34 11.0% 44.0Hz 781 0 2.05ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 95.2% 0.59V 34 11.0% 37.7Hz 719 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 94.4% 0.21V 34 11.0% 37.7Hz 625 0 2.30ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 95.9% 0.08V 34 11.0% 37.7Hz 625 0 2.56ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 97.5% 0.06V 45 11.0% 37.7Hz 625 0 2.56ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 99.1% 0.06V 49 11.0% 44.0Hz 656 0 2.56ms 1 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.62V 65 19.6% 56.6Hz 688 0 3.84ms 2 76.6°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 98.3% 0.04V 78 21.2% 100.6Hz 938 0 4.10ms 4 76.6°F 2.34V
18° 209.8°F 93.6% 99.8% 99.8% 105.3% 0.00V 83 24.7% 138.4Hz 1250 0 4.35ms 5 75.8°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 116.2% 0.00V 88 29.4% 163.5Hz 1313 0 5.12ms 7 75.8°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 127.1% 0.00V 75 30.2% 169.8Hz 1250 0 5.38ms 7 75.8°F 2.34V
21° 209.8°F 93.6% 99.8% 99.8% 138.1% 0.08V 75 30.2% 138.4Hz 969 0 5.38ms 5 75.0°F 2.34V
14° 209.8°F 93.6% 99.8% 99.8% 134.2% 0.68V 76 31.4% 176.1Hz 1313 0 5.38ms 7 75.0°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 138.1% 0.08V 80 34.5% 220.2Hz 1594 1 5.89ms 10 75.0°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 147.4% 0.70V 82 36.1% 276.8Hz 1906 0 5.89ms 11 74.2°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 127.1% 0.78V 82 36.5% 320.8Hz 2281 0 5.63ms 13 74.2°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 103.7% 0.68V 82 36.5% 377.4Hz 2656 0 5.63ms 15 73.4°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 93.6% 0.21V 82 36.5% 415.1Hz 3031 0 5.63ms 18 72.6°F 2.34V
32° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.66V 79 33.7% 402.6Hz 3375 0 4.86ms 17 71.8°F 2.34V
33° 209.8°F 93.6% 99.8% 99.8% 124.8% 0.12V 79 33.3% 427.7Hz 3688 0 2.30ms 9 71.0°F 2.34V
40° 209.8°F 93.6% 99.8% 99.8% 122.5% 0.84V 60 11.0% 56.6Hz 3313 0 1.28ms 4 71.0°F 2.34V
39° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.66V 37 11.0% 25.2Hz 2844 0 1.28ms 3 71.8°F 2.34V
39° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.62V 53 17.3% 69.2Hz 2406 0 1.54ms 3 71.8°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 112.3% 0.10V 64 21.2% 144.7Hz 2219 0 2.82ms 6 71.8°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 103.7% 0.74V 70 26.3% 220.2Hz 2250 0 4.10ms 9 71.8°F 2.34V
31° 209.8°F 93.6% 99.8% 99.8% 105.3% 0.10V 82 36.5% 314.5Hz 2344 0 5.63ms 14 71.0°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 120.1% 0.78V 82 36.1% 339.7Hz 2438 0 5.63ms 14 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 98.3% 0.47V 83 38.0% 377.4Hz 2625 0 6.14ms 17 69.5°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 128.7% 0.31V 84 39.2% 434.0Hz 2781 0 6.40ms 19 68.7°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 105.3% 0.55V 84 39.6% 478.0Hz 2938 0 6.66ms 20 67.9°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 117.0% 0.68V 85 40.0% 522.1Hz 3125 0 6.91ms 23 67.1°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 124.0% 0.41V 85 40.0% 578.7Hz 3344 0 7.42ms 26 66.3°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 119.3% 0.20V 82 36.1% 566.1Hz 3563 0 6.91ms 26 65.5°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 138.1% 0.43V 81 35.3% 522.1Hz 3719 0 6.66ms 26 64.7°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 159.1% 0.84V 68 11.0% 100.6Hz 3563 0 1.28ms 4 65.5°F 2.34V
40° 209.8°F 93.6% 99.8% 99.8% 133.4% 0.47V 46 11.0% 69.2Hz 3031 0 1.28ms 4 66.3°F 2.34V
39° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.76V 34 11.0% 56.6Hz 2594 0 1.28ms 3 67.1°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 92.0% 0.64V 34 11.0% 44.0Hz 2375 0 1.54ms 3 67.9°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 88.9% 0.64V 34 11.0% 56.6Hz 2406 0 1.28ms 3 67.9°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.76V 34 11.0% 56.6Hz 2375 0 1.28ms 3 68.7°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.62V 34 11.0% 50.3Hz 2344 0 1.28ms 3 69.5°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.64V 34 11.0% 62.9Hz 2344 0 1.54ms 3 69.5°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 93.6% 0.57V 34 11.0% 44.0Hz 2281 0 1.28ms 3 69.5°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.72V 34 11.0% 62.9Hz 2250 0 1.28ms 3 70.3°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 88.1% 0.62V 34 11.0% 44.0Hz 2156 0 1.28ms 2 70.3°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 73.3% 0.66V 34 11.0% 37.7Hz 2063 0 1.28ms 2 70.3°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.68V 34 11.0% 44.0Hz 2000 0 1.28ms 2 71.0°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.66V 34 11.0% 44.0Hz 2000 0 1.28ms 2 71.0°F 2.34V
36° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.59V 34 11.0% 44.0Hz 1938 0 1.28ms 2 71.0°F 2.34V
35° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.25V 34 11.0% 44.0Hz 1906 0 1.28ms 2 71.0°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.10V 34 11.0% 37.7Hz 1906 0 1.28ms 2 71.8°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.06V 34 11.0% 44.0Hz 1875 0 1.28ms 2 71.8°F 2.34V
33° 209.8°F 93.6% 99.8% 99.8% 102.2% 0.04V 57 17.6% 81.8Hz 1875 0 2.05ms 4 71.8°F 2.34V
33° 209.8°F 93.6% 99.8% 99.8% 114.7% 0.68V 70 29.4% 169.8Hz 1875 0 4.61ms 9 71.0°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 104.5% 0.31V 76 31.0% 245.3Hz 1875 0 5.12ms 10 71.0°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 100.6% 0.47V 78 34.1% 264.2Hz 1938 0 5.63ms 11 70.3°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 118.6% 0.10V 84 38.8% 301.9Hz 1969 0 6.14ms 12 69.5°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 103.7% 0.78V 82 36.5% 314.5Hz 2063 0 5.89ms 12 68.7°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 84.2% 0.55V 82 36.5% 320.8Hz 2125 0 5.89ms 13 67.9°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 103.0% 0.21V 83 37.3% 339.7Hz 2188 1 6.40ms 14 67.9°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 91.3% 0.68V 83 38.0% 358.5Hz 2219 0 6.14ms 14 67.1°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 92.0% 0.08V 83 38.0% 371.1Hz 2313 0 6.66ms 16 66.3°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 107.6% 0.76V 84 38.4% 383.7Hz 2375 0 6.40ms 16 66.3°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 99.1% 0.14V 84 38.4% 402.6Hz 2469 0 6.91ms 18 65.5°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 103.0% 0.70V 84 38.8% 421.4Hz 2531 0 6.66ms 18 65.5°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 106.9% 0.06V 84 38.8% 440.3Hz 2625 0 7.17ms 20 64.7°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 113.9% 0.76V 82 36.9% 452.9Hz 2688 0 6.66ms 19 64.7°F 2.34V
13° 209.8°F 93.6% 99.8% 99.8% 97.5% 0.55V 67 11.0% 245.3Hz 2750 0 2.05ms 6 64.7°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 80.3% 0.82V 46 11.0% 56.6Hz 2656 0 1.28ms 3 65.5°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 91.3% 0.64V 34 11.0% 62.9Hz 2594 0 1.54ms 4 66.3°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 72.5% 0.72V 34 11.0% 69.2Hz 2531 0 1.54ms 4 67.1°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 54.6% 0.59V 34 11.0% 56.6Hz 2438 0 1.28ms 3 67.9°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 38.2% 0.72V 34 11.0% 69.2Hz 2313 0 1.28ms 3 67.9°F 2.34V
38° 209.8°F 93.6% 99.8% 99.8% 32.0% 0.72V 34 11.0% 56.6Hz 2219 0 1.28ms 3 68.7°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 32.8% 0.70V 34 11.0% 44.0Hz 2156 0 1.28ms 2 68.7°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 32.0% 0.62V 34 11.0% 50.3Hz 2063 0 1.28ms 2 68.7°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 32.8% 0.74V 34 11.0% 37.7Hz 2000 0 1.28ms 2 69.5°F 2.34V
37° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.60V 34 11.0% 37.7Hz 1969 0 1.28ms 2 69.5°F 2.34V
36° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.33V 34 11.0% 44.0Hz 1938 0 1.28ms 2 69.5°F 2.34V
36° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.37V 34 11.0% 44.0Hz 1969 0 1.28ms 2 70.3°F 2.34V
36° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.27V 34 11.0% 44.0Hz 1906 0 1.28ms 2 70.3°F 2.34V
35° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.62V 34 11.0% 44.0Hz 1906 0 1.28ms 2 70.3°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.23V 34 11.0% 44.0Hz 1906 0 1.28ms 2 70.3°F 2.34V
33° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.14V 34 11.0% 44.0Hz 1844 0 1.28ms 2 70.3°F 2.34V
34° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 1844 0 1.28ms 2 71.0°F 2.34V
33° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 1844 0 1.28ms 2 71.0°F 2.34V
31° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 1781 0 1.28ms 2 71.0°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 1750 0 1.28ms 2 71.0°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 99.8% 0.02V 43 14.9% 56.6Hz 1750 0 1.54ms 2 71.0°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 103.0% 0.80V 54 15.7% 81.8Hz 1750 0 2.05ms 3 71.0°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 91.3% 0.86V 54 15.7% 88.1Hz 1719 0 2.05ms 3 71.0°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 79.6% 0.84V 55 16.1% 81.8Hz 1719 0 1.79ms 3 71.0°F 2.34V
30° 209.8°F 93.6% 99.8% 99.8% 67.9% 0.37V 55 16.1% 81.8Hz 1719 0 2.05ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 67.1% 0.53V 55 16.1% 81.8Hz 1719 0 2.05ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 76.4% 0.02V 55 16.1% 81.8Hz 1719 0 2.05ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 88.1% 0.02V 55 16.1% 81.8Hz 1688 0 2.05ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 99.1% 0.04V 55 16.1% 81.8Hz 1719 0 2.05ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 106.9% 0.72V 54 14.9% 81.8Hz 1719 0 1.79ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 96.7% 0.82V 47 13.7% 69.2Hz 1719 0 1.79ms 3 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 85.0% 0.80V 39 12.2% 56.6Hz 1688 0 1.54ms 2 70.3°F 2.34V
29° 209.8°F 93.6% 99.8% 99.8% 72.5% 0.74V 38 11.8% 50.3Hz 1656 0 1.54ms 2 70.3°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 66.3% 0.16V 38 11.8% 50.3Hz 1656 0 1.54ms 2 70.3°F 2.34V
28° 209.8°F 93.6% 99.8% 99.8% 77.2% 0.02V 38 11.8% 50.3Hz 1656 0 1.54ms 2 70.3°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 85.8% 0.74V 38 11.8% 50.3Hz 1625 0 1.54ms 2 70.3°F 2.34V
27° 209.8°F 93.6% 99.8% 99.8% 76.4% 0.84V 38 11.8% 50.3Hz 1594 0 1.28ms 2 70.3°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 64.7% 0.62V 38 11.8% 50.3Hz 1594 0 1.54ms 2 70.3°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 73.3% 0.02V 38 11.8% 50.3Hz 1594 0 1.54ms 2 71.0°F 2.34V
26° 209.8°F 93.6% 99.8% 99.8% 84.2% 0.12V 38 11.8% 50.3Hz 1563 0 1.54ms 2 71.0°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 85.0% 0.82V 38 11.8% 50.3Hz 1531 0 1.54ms 2 71.0°F 2.34V
25° 209.8°F 93.6% 99.8% 99.8% 75.7% 0.80V 38 11.0% 50.3Hz 1531 0 1.54ms 2 71.0°F 2.34V
24° 209.8°F 93.6% 99.8% 99.8% 65.5% 0.82V 34 11.0% 44.0Hz 1500 0 1.28ms 2 71.0°F 2.32V
24° 209.8°F 92.8% 99.8% 99.8% 64.0% 0.12V 34 11.0% 44.0Hz 1500 0 1.54ms 2 71.0°F 2.32V
23° 209.8°F 92.8% 99.8% 99.8% 73.3% 0.02V 34 11.0% 44.0Hz 1438 0 1.54ms 2 71.0°F 2.32V
23° 209.8°F 92.8% 99.8% 99.8% 83.5% 0.02V 34 11.0% 44.0Hz 1438 0 1.54ms 2 71.0°F 2.32V
23° 209.8°F 92.8% 99.8% 99.8% 92.8% 0.43V 34 11.0% 44.0Hz 1438 0 1.54ms 2 71.0°F 2.32V
22° 209.8°F 92.0% 99.8% 99.8% 94.4% 0.72V 34 11.0% 44.0Hz 1375 0 1.54ms 2 71.0°F 2.30V
21° 209.8°F 92.0% 99.8% 99.8% 85.0% 0.70V 34 11.0% 44.0Hz 1344 0 1.54ms 2 71.0°F 2.30V
20° 209.8°F 92.0% 99.8% 99.8% 76.4% 0.64V 34 11.0% 37.7Hz 1281 0 1.54ms 2 71.0°F 2.30V
19° 209.8°F 92.0% 99.8% 99.8% 79.6% 0.04V 34 11.0% 44.0Hz 1188 0 1.54ms 1 71.0°F 2.30V
17° 209.8°F 92.0% 99.8% 99.8% 85.8% 0.06V 34 11.0% 44.0Hz 1063 0 1.54ms 1 71.0°F 2.28V
14° 209.8°F 91.3% 99.8% 99.8% 82.7% 0.62V 34 11.0% 37.7Hz 875 0 1.79ms 1 71.0°F 2.28V
10° 209.8°F 91.3% 99.8% 99.8% 77.2% 0.78V 34 11.0% 37.7Hz 688 0 2.05ms 1 71.0°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 73.3% 0.76V 34 11.0% 37.7Hz 594 0 2.30ms 1 71.0°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 69.4% 0.80V 34 11.0% 37.7Hz 594 0 2.30ms 1 71.0°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 65.5% 0.53V 34 11.0% 44.0Hz 656 0 2.30ms 1 71.0°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 67.1% 0.10V 34 11.0% 44.0Hz 656 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 71.0% 0.02V 34 11.0% 37.7Hz 656 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 74.1% 0.00V 34 11.0% 37.7Hz 656 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 77.2% 0.00V 34 11.0% 37.7Hz 656 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 81.1% 0.00V 34 11.0% 44.0Hz 656 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 85.0% 0.00V 34 11.0% 44.0Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 88.9% 0.00V 34 11.0% 44.0Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 92.0% 0.00V 34 11.0% 44.0Hz 719 0 2.30ms 1 71.8°F 2.22V
8° 209.8°F 88.9% 99.8% 99.8% 95.9% 0.00V 34 11.0% 44.0Hz 688 0 2.30ms 1 71.8°F 2.22V
8° 209.8°F 88.9% 99.8% 99.8% 99.1% 0.00V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.22V
8° 209.8°F 88.9% 99.8% 99.8% 100.6% 0.00V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.22V
8° 209.8°F 88.9% 99.8% 99.8% 102.2% 0.02V 34 11.0% 44.0Hz 688 0 2.30ms 1 71.8°F 2.22V
8° 209.8°F 88.9% 99.8% 99.8% 103.7% 0.02V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 105.3% 0.02V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 106.9% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 108.4% 0.02V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 110.8% 0.02V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.24V
8° 209.8°F 89.7% 99.8% 99.8% 112.3% 0.06V 34 11.0% 44.0Hz 688 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 113.9% 0.41V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 111.5% 0.47V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 110.0% 0.59V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.26V
8° 209.8°F 90.5% 99.8% 99.8% 110.8% 0.33V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 111.5% 0.43V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 109.2% 0.66V 34 11.0% 44.0Hz 719 0 2.30ms 1 71.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 106.9% 0.68V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.28V
8° 209.8°F 91.3% 99.8% 99.8% 106.1% 0.25V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.28V
8° 209.8°F 92.0% 99.8% 99.8% 107.6% 0.06V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 109.2% 0.00V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 111.5% 0.00V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 113.1% 0.00V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.30V
8° 209.8°F 92.0% 99.8% 99.8% 114.7% 0.02V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 117.0% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 117.8% 0.29V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 117.0% 0.68V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.32V
8° 209.8°F 92.8% 99.8% 99.8% 113.9% 0.74V 34 11.0% 37.7Hz 719 0 2.30ms 1 71.8°F 2.32V
8° 209.8°F 93.6% 99.8% 99.8% 111.5% 0.66V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 108.4% 0.53V 34 11.0% 37.7Hz 688 0 2.30ms 1 71.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 108.4% 0.62V 34 11.0% 37.7Hz 656 0 2.30ms 1 71.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 108.4% 0.29V 34 11.0% 37.7Hz 656 0 2.30ms 1 71.8°F 2.34V
8° 209.8°F 93.6% 99.8% 99.8% 110.0% 0.08V 34 11.8% 37.7Hz 656 0 2.82ms 1 71.8°F 2.36V
8° 209.8°F 94.4% 99.8% 99.8% 111.5% 0.06V 63 22.0% 75.5Hz 750 0 4.61ms 3 71.8°F 2.36V
12° 209.8°F 94.4% 99.8% 99.8% 115.4% 0.00V 91 31.0% 169.8Hz 1313 1 5.38ms 7 71.0°F 2.36V
24° 209.8°F 94.4% 99.8% 99.8% 127.1% 0.04V 91 31.4% 163.5Hz 1156 0 5.63ms 6 70.3°F 2.36V
17° 209.8°F 94.4% 99.8% 99.8% 137.3% 0.04V 84 32.2% 119.5Hz 875 0 5.63ms 5 70.3°F 2.36V
11° 209.8°F 94.4% 99.8% 99.8% 145.9% 0.41V 98 38.8% 176.1Hz 1250 0 5.89ms 7 69.5°F 2.36V
22° 209.8°F 94.4% 99.8% 99.8% 156.0% 0.59V 96 28.2% 207.6Hz 1563 0 5.38ms 8 69.5°F 2.36V
27° 209.8°F 94.4% 99.8% 99.8% 141.2% 0.84V 71 27.1% 207.6Hz 1813 0 4.61ms 8 68.7°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 122.5% 0.70V 72 27.8% 232.7Hz 2094 0 4.61ms 10 68.7°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 118.6% 0.10V 85 34.9% 308.2Hz 2344 0 5.63ms 14 67.9°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 126.4% 0.80V 85 40.8% 390.0Hz 2719 0 6.14ms 17 67.1°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 98.3% 0.64V 86 42.0% 471.8Hz 3063 0 6.14ms 20 66.3°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 106.1% 0.43V 86 40.4% 559.8Hz 3500 0 6.14ms 22 65.5°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 87.4% 0.14V 82 36.9% 566.1Hz 3813 0 6.91ms 28 64.7°F 2.36V
30° 209.8°F 94.4% 99.8% 99.8% 99.8% 0.80V 82 11.4% 377.4Hz 4156 0 1.54ms 6 64.0°F 2.36V
41° 209.8°F 94.4% 99.8% 99.8% 78.0% 0.57V 61 11.0% 100.6Hz 3531 0 1.28ms 4 64.7°F 2.36V
40° 209.8°F 94.4% 99.8% 99.8% 99.8% 0.74V 54 15.7% 56.6Hz 3125 0 1.28ms 4 65.5°F 2.36V
39° 209.8°F 94.4% 99.8% 99.8% 100.6% 0.06V 69 25.1% 188.7Hz 2531 0 3.33ms 9 65.5°F 2.36V
33° 209.8°F 94.4% 99.8% 99.8% 126.4% 0.02V 77 31.8% 301.9Hz 2563 0 5.38ms 14 65.5°F 2.36V
30° 209.8°F 94.4% 99.8% 99.8% 133.4% 0.80V 77 31.8% 320.8Hz 2781 0 4.86ms 14 64.7°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 103.7% 0.55V 77 31.8% 333.4Hz 2844 0 4.86ms 14 64.7°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 130.3% 0.10V 77 32.2% 346.0Hz 2938 0 5.12ms 16 64.0°F 2.36V
33° 209.8°F 94.4% 99.8% 99.8% 116.2% 0.68V 71 11.0% 251.6Hz 3031 0 2.05ms 6 64.0°F 2.36V
39° 209.8°F 94.4% 99.8% 99.8% 99.8% 0.90V 50 11.0% 31.5Hz 2750 0 1.54ms 4 64.7°F 2.36V
38° 209.8°F 94.4% 99.8% 99.8% 94.4% 0.53V 44 11.0% 44.0Hz 2344 0 1.28ms 3 65.5°F 2.36V
37° 209.8°F 94.4% 99.8% 99.8% 78.8% 0.80V 34 11.0% 37.7Hz 1969 0 1.28ms 2 65.5°F 2.36V
37° 209.8°F 94.4% 99.8% 99.8% 65.5% 0.74V 34 11.0% 37.7Hz 1969 0 1.28ms 2 66.3°F 2.36V
36° 209.8°F 94.4% 99.8% 99.8% 51.5% 0.49V 34 11.0% 44.0Hz 1969 0 1.28ms 2 66.3°F 2.36V
35° 209.8°F 94.4% 99.8% 99.8% 64.7% 0.18V 34 11.0% 44.0Hz 1938 0 1.28ms 2 67.1°F 2.36V
35° 209.8°F 94.4% 99.8% 99.8% 77.2% 0.35V 34 11.0% 44.0Hz 1906 0 1.28ms 2 67.1°F 2.36V
34° 209.8°F 94.4% 99.8% 99.8% 90.5% 0.20V 34 11.8% 37.7Hz 1875 0 1.28ms 2 67.9°F 2.36V
34° 209.8°F 94.4% 99.8% 99.8% 104.5% 0.12V 54 15.7% 75.5Hz 1875 0 1.79ms 3 67.9°F 2.36V
34° 209.8°F 94.4% 99.8% 99.8% 107.6% 0.82V 54 15.7% 81.8Hz 1844 0 1.79ms 3 67.9°F 2.36V
33° 209.8°F 94.4% 99.8% 99.8% 95.2% 0.84V 50 14.1% 69.2Hz 1844 0 1.79ms 3 67.9°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 82.7% 0.76V 41 12.5% 56.6Hz 1844 0 1.54ms 3 67.9°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 71.0% 0.39V 58 20.0% 88.1Hz 1813 0 2.30ms 4 67.9°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 84.2% 0.02V 62 20.0% 125.8Hz 1844 0 2.82ms 5 67.9°F 2.36V
31° 209.8°F 94.4% 99.8% 99.8% 97.5% 0.06V 63 20.4% 132.1Hz 1813 0 3.07ms 5 67.9°F 2.36V
31° 209.8°F 94.4% 99.8% 99.8% 93.6% 0.78V 52 12.9% 88.1Hz 1813 0 1.79ms 3 67.9°F 2.36V
33° 209.8°F 94.4% 99.8% 99.8% 80.3% 0.86V 41 12.5% 62.9Hz 1781 0 1.54ms 2 67.9°F 2.36V
32° 209.8°F 94.4% 99.8% 99.8% 71.0% 0.23V 41 12.5% 56.6Hz 1813 0 1.54ms 2 67.9°F 2.36V
32° 206.4°F 94.4% 99.8% 99.8% 82.7% 0.59V 48 16.5% 62.9Hz 1813 0 1.54ms 2 67.9°F 2.36V
31° 206.4°F 94.4% 99.8% 99.8% 85.8% 0.02V 58 16.9% 88.1Hz 1813 0 2.05ms 3 67.9°F 2.36V
29° 209.8°F 94.4% 99.8% 99.8% 98.3% 0.00V 69 27.1% 151.0Hz 1781 0 4.86ms 9 67.9°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 116.2% 0.27V 91 49.0% 283.1Hz 1844 0 6.40ms 12 67.1°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 124.0% 0.76V 92 49.4% 301.9Hz 1938 0 6.40ms 13 66.3°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 105.3% 0.78V 92 49.4% 320.8Hz 1969 0 6.40ms 13 66.3°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 88.9% 0.41V 92 49.4% 339.7Hz 2031 0 6.66ms 14 65.5°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 110.8% 0.37V 91 37.3% 352.2Hz 2094 1 5.89ms 13 64.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.84V 70 17.3% 213.9Hz 2156 0 2.82ms 6 64.7°F 2.36V
35° 206.4°F 94.4% 99.8% 99.8% 74.9% 0.92V 49 11.0% 50.3Hz 2156 0 1.28ms 2 65.5°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.47V 34 11.0% 31.5Hz 2125 0 1.28ms 2 65.5°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.06V 34 11.0% 37.7Hz 2094 0 1.28ms 2 66.3°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 37.7Hz 2063 0 1.28ms 2 66.3°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2031 0 1.28ms 2 67.1°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 1938 0 1.28ms 2 67.1°F 2.36V
36° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 37.7Hz 1875 0 1.28ms 2 67.9°F 2.36V
34° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 1844 0 1.28ms 2 67.9°F 2.36V
32° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1781 0 1.28ms 2 67.9°F 2.36V
32° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 1781 0 1.28ms 2 67.9°F 2.36V
31° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 1781 0 1.28ms 2 68.7°F 2.36V
30° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 1750 0 1.28ms 2 68.7°F 2.36V
30° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.06V 34 11.0% 44.0Hz 1750 0 1.28ms 2 68.7°F 2.36V
29° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.70V 36 11.4% 44.0Hz 1688 0 1.28ms 2 68.7°F 2.36V
29° 206.4°F 94.4% 99.8% 99.8% 95.9% 0.78V 39 12.2% 50.3Hz 1719 0 1.54ms 2 68.7°F 2.36V
29° 206.4°F 94.4% 99.8% 99.8% 84.2% 0.78V 47 14.1% 62.9Hz 1688 0 1.54ms 2 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 75.7% 0.53V 49 14.5% 62.9Hz 1688 0 1.79ms 3 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 81.9% 0.12V 50 14.9% 69.2Hz 1656 0 1.79ms 3 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.08V 51 14.9% 69.2Hz 1625 0 1.79ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 106.1% 0.14V 51 14.9% 75.5Hz 1656 0 1.79ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 100.6% 0.82V 52 14.9% 69.2Hz 1625 0 1.79ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 89.7% 0.35V 52 15.3% 69.2Hz 1625 0 1.79ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 100.6% 0.06V 52 15.3% 75.5Hz 1594 0 2.05ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 110.8% 0.25V 52 15.3% 75.5Hz 1594 0 2.05ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.78V 52 15.3% 75.5Hz 1594 0 2.05ms 3 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 92.0% 0.59V 52 15.3% 75.5Hz 1594 0 2.05ms 3 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.06V 54 15.7% 75.5Hz 1594 0 2.05ms 3 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 108.4% 0.04V 58 16.9% 81.8Hz 1594 0 2.30ms 3 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 118.6% 0.02V 61 19.2% 106.9Hz 1594 0 2.82ms 4 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 129.5% 0.64V 61 19.2% 119.5Hz 1594 0 3.07ms 5 67.9°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 117.8% 0.90V 46 12.9% 69.2Hz 1594 0 1.79ms 3 67.9°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 106.9% 0.84V 42 12.9% 56.6Hz 1594 0 1.54ms 2 67.9°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.39V 45 13.7% 56.6Hz 1594 0 1.79ms 3 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 108.4% 0.06V 46 13.7% 62.9Hz 1563 0 1.79ms 2 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 109.2% 0.84V 46 13.7% 62.9Hz 1563 0 1.79ms 2 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.74V 46 13.7% 62.9Hz 1531 0 1.79ms 2 68.7°F 2.36V
25° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.16V 46 13.7% 62.9Hz 1531 0 1.79ms 2 68.7°F 2.36V
25° 206.4°F 94.4% 99.8% 99.8% 103.0% 0.06V 46 13.7% 62.9Hz 1531 0 1.79ms 2 68.7°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 103.7% 0.84V 41 11.0% 62.9Hz 1531 0 1.79ms 2 68.7°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.90V 34 11.0% 50.3Hz 1500 0 1.54ms 2 68.7°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 83.5% 0.88V 34 11.0% 44.0Hz 1500 0 1.54ms 2 68.7°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 72.5% 0.84V 34 11.0% 44.0Hz 1469 0 1.54ms 2 68.7°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 64.0% 0.76V 34 11.0% 44.0Hz 1469 0 1.28ms 2 68.7°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 67.1% 0.10V 34 11.0% 44.0Hz 1438 0 1.54ms 2 69.5°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 76.4% 0.02V 34 11.0% 44.0Hz 1406 0 1.54ms 2 69.5°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 85.8% 0.02V 36 11.4% 44.0Hz 1375 0 1.54ms 2 69.5°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 95.2% 0.14V 37 11.8% 44.0Hz 1375 0 1.54ms 2 69.5°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 88.9% 0.70V 39 12.2% 50.3Hz 1375 0 1.54ms 2 69.5°F 2.36V
20° 206.4°F 94.4% 99.8% 99.8% 81.1% 0.72V 42 14.1% 50.3Hz 1344 0 1.79ms 2 69.5°F 2.36V
20° 206.4°F 94.4% 99.8% 99.8% 78.0% 0.04V 58 17.3% 81.8Hz 1375 0 2.30ms 3 69.5°F 2.36V
20° 206.4°F 94.4% 99.8% 99.8% 85.8% 0.00V 67 17.3% 88.1Hz 1313 0 2.56ms 3 69.5°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.00V 70 17.6% 94.4Hz 1344 0 2.56ms 3 68.7°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 101.4% 0.00V 74 17.6% 94.4Hz 1344 0 2.82ms 4 68.7°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 109.2% 0.02V 74 17.6% 94.4Hz 1344 0 2.82ms 4 68.7°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 116.2% 0.02V 69 17.6% 94.4Hz 1344 0 2.82ms 4 68.7°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 124.0% 0.02V 66 18.0% 100.6Hz 1344 0 3.07ms 4 68.7°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 131.8% 0.41V 60 18.4% 100.6Hz 1344 0 3.07ms 4 67.9°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 124.8% 0.62V 60 18.4% 100.6Hz 1344 0 3.07ms 4 67.9°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 127.9% 0.16V 60 18.8% 106.9Hz 1344 0 3.33ms 4 67.9°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 136.5% 0.20V 72 30.2% 151.0Hz 1375 0 5.63ms 8 67.9°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 148.2% 0.25V 80 43.1% 201.3Hz 1406 0 6.66ms 10 67.1°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.88V 90 46.3% 220.2Hz 1469 0 6.66ms 10 66.3°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.88V 90 46.3% 239.0Hz 1563 0 6.66ms 11 66.3°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.88V 90 46.3% 251.6Hz 1625 0 6.66ms 11 65.5°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 90 46.3% 264.2Hz 1656 0 6.91ms 12 65.5°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 90 46.3% 289.3Hz 1750 0 6.91ms 12 64.7°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 90 46.3% 308.2Hz 1844 0 6.40ms 12 64.7°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 85.8% 0.53V 90 46.3% 320.8Hz 1875 0 6.66ms 13 64.7°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 101.4% 0.08V 90 46.3% 333.4Hz 1938 0 6.91ms 14 64.0°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 117.0% 0.72V 90 46.3% 358.5Hz 2031 0 6.91ms 15 64.0°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.53V 90 46.7% 377.4Hz 2125 0 7.17ms 16 63.2°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 115.4% 0.70V 90 46.7% 390.0Hz 2219 0 7.17ms 16 63.2°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 105.3% 0.23V 90 46.7% 408.9Hz 2281 0 7.68ms 18 62.4°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 106.9% 0.66V 90 46.7% 434.0Hz 2375 0 7.42ms 18 62.4°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 120.9% 0.14V 90 46.7% 465.5Hz 2500 0 7.94ms 21 62.4°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 110.0% 0.60V 90 46.7% 490.6Hz 2563 0 7.94ms 21 61.6°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 126.4% 0.23V 90 46.7% 534.7Hz 2688 0 8.45ms 24 61.6°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 108.4% 0.57V 90 46.7% 585.0Hz 2781 0 8.70ms 25 60.8°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 90 46.7% 641.6Hz 2906 0 10.50ms 32 60.8°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 90 46.7% 679.3Hz 3063 0 10.75ms 35 60.0°F 2.36V
22° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.86V 83 36.1% 597.6Hz 3156 4 4.86ms 16 60.0°F 2.36V
25° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.62V 67 23.5% 1409.0Hz 3250 4 15.62ms 54 60.0°F 2.36V
16° 206.4°F 94.4% 99.8% 99.8% 93.6% 0.64V 53 11.0% 132.1Hz 3063 0 1.28ms 4 60.8°F 2.36V
39° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.59V 34 11.0% 56.6Hz 3094 0 1.28ms 4 61.6°F 2.36V
39° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.70V 34 11.0% 44.0Hz 3000 0 1.28ms 4 62.4°F 2.36V
39° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.68V 34 11.0% 50.3Hz 2844 0 1.28ms 3 63.2°F 2.36V
39° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.72V 34 11.0% 37.7Hz 2719 0 1.28ms 3 64.0°F 2.36V
38° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.72V 34 11.0% 44.0Hz 2563 0 1.28ms 3 64.7°F 2.36V
38° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.68V 34 11.0% 50.3Hz 2438 0 1.28ms 3 64.7°F 2.36V
38° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.68V 34 11.0% 44.0Hz 2344 0 1.28ms 3 64.7°F 2.36V
38° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.66V 34 11.0% 44.0Hz 2219 0 1.28ms 3 65.5°F 2.36V
38° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.72V 34 11.0% 44.0Hz 2156 0 1.28ms 2 65.5°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.70V 34 11.0% 44.0Hz 2094 0 1.28ms 2 66.3°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.74V 34 11.0% 37.7Hz 2031 0 1.28ms 2 66.3°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.57V 34 11.0% 44.0Hz 2031 0 1.28ms 2 66.3°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.35V 34 11.0% 44.0Hz 2000 0 1.28ms 2 67.1°F 2.36V
37° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.76V 34 11.0% 44.0Hz 2000 0 0.00ms 0 67.1°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.10V 34 11.0% 44.0Hz 1969 0 0.00ms 0 67.1°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1938 0 0.00ms 0 67.1°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.00V 43 13.3% 50.3Hz 1906 0 1.54ms 3 67.1°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 109.2% 0.00V 46 13.7% 62.9Hz 1844 0 1.54ms 3 67.9°F 2.36V
33° 206.4°F 94.4% 99.8% 99.8% 117.0% 0.74V 46 13.7% 62.9Hz 1844 0 1.54ms 3 67.9°F 2.36V
33° 206.4°F 94.4% 99.8% 99.8% 104.5% 0.82V 47 14.1% 62.9Hz 1844 0 1.54ms 3 67.9°F 2.36V
34° 206.4°F 94.4% 99.8% 99.8% 90.5% 0.76V 43 12.2% 56.6Hz 1844 0 1.54ms 3 67.9°F 2.36V
32° 206.4°F 94.4% 99.8% 99.8% 92.8% 0.04V 34 11.0% 44.0Hz 1813 0 1.28ms 2 67.9°F 2.36V
32° 206.4°F 94.4% 99.8% 99.8% 105.3% 0.04V 34 11.0% 44.0Hz 1813 0 1.28ms 2 67.9°F 2.36V
31° 206.4°F 94.4% 99.8% 99.8% 117.0% 0.04V 34 11.0% 44.0Hz 1813 0 1.28ms 2 67.9°F 2.36V
31° 206.4°F 94.4% 99.8% 99.8% 114.7% 0.64V 34 11.0% 44.0Hz 1781 0 1.28ms 2 67.9°F 2.36V
30° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.70V 34 11.0% 44.0Hz 1781 0 1.28ms 2 67.9°F 2.36V
30° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.20V 34 11.0% 44.0Hz 1750 0 1.28ms 2 67.9°F 2.36V
30° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.80V 34 11.0% 44.0Hz 1719 0 1.28ms 2 68.7°F 2.36V
29° 206.4°F 94.4% 99.8% 99.8% 88.9% 0.25V 34 11.0% 44.0Hz 1719 0 1.28ms 2 68.7°F 2.36V
29° 206.4°F 94.4% 99.8% 99.8% 99.8% 0.08V 34 11.0% 44.0Hz 1688 0 1.28ms 2 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 111.5% 0.33V 34 11.0% 44.0Hz 1656 0 1.28ms 2 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 103.0% 0.72V 34 11.0% 44.0Hz 1656 0 1.28ms 2 68.7°F 2.36V
28° 206.4°F 94.4% 99.8% 99.8% 92.8% 0.55V 34 11.0% 44.0Hz 1656 0 1.28ms 2 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 100.6% 0.16V 34 11.0% 44.0Hz 1625 0 1.28ms 2 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 112.3% 0.55V 34 11.0% 44.0Hz 1625 0 1.28ms 2 68.7°F 2.36V
27° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.80V 34 11.0% 44.0Hz 1594 0 1.28ms 2 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 90.5% 0.59V 34 11.0% 44.0Hz 1563 0 1.28ms 2 68.7°F 2.36V
26° 206.4°F 94.4% 99.8% 99.8% 97.5% 0.08V 34 11.0% 37.7Hz 1531 0 1.28ms 2 68.7°F 2.36V
24° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.60V 34 11.0% 37.7Hz 1438 0 1.54ms 2 69.5°F 2.36V
23° 206.4°F 94.4% 99.8% 99.8% 110.8% 0.59V 34 11.0% 44.0Hz 1406 0 1.54ms 2 69.5°F 2.36V
21° 206.4°F 94.4% 99.8% 99.8% 102.2% 0.82V 34 11.0% 44.0Hz 1313 0 1.54ms 2 69.5°F 2.36V
19° 206.4°F 94.4% 99.8% 99.8% 95.2% 0.84V 34 11.0% 37.7Hz 1219 0 1.54ms 2 69.5°F 2.36V
17° 206.4°F 94.4% 99.8% 99.8% 87.4% 0.82V 34 11.0% 37.7Hz 1156 0 1.54ms 1 69.5°F 2.36V
16° 203.0°F 94.4% 99.8% 99.8% 81.1% 0.43V 34 11.0% 44.0Hz 1125 0 1.79ms 2 69.5°F 2.36V
16° 203.0°F 94.4% 99.8% 99.8% 88.9% 0.08V 34 11.0% 44.0Hz 1125 0 1.79ms 2 69.5°F 2.36V
16° 203.0°F 94.4% 99.8% 99.8% 88.9% 0.82V 34 11.0% 44.0Hz 1125 0 1.79ms 2 69.5°F 2.36V
15° 203.0°F 94.4% 99.8% 99.8% 81.9% 0.78V 46 14.1% 50.3Hz 1094 0 1.79ms 2 69.5°F 2.36V
15° 203.0°F 94.4% 99.8% 99.8% 82.7% 0.06V 47 14.1% 56.6Hz 1125 0 2.05ms 2 69.5°F 2.36V
15° 203.0°F 94.4% 99.8% 99.8% 89.7% 0.00V 51 15.3% 62.9Hz 1125 0 2.30ms 2 69.5°F 2.36V
17° 203.0°F 94.4% 99.8% 99.8% 96.7% 0.00V 63 20.4% 106.9Hz 1125 0 3.58ms 4 68.7°F 2.36V
19° 203.0°F 94.4% 99.8% 99.8% 105.3% 0.00V 66 24.7% 119.5Hz 1063 0 4.61ms 5 68.7°F 2.36V
21° 203.0°F 94.4% 99.8% 99.8% 114.7% 0.00V 71 26.7% 144.7Hz 1156 0 4.86ms 6 67.9°F 2.36V
20° 203.0°F 94.4% 99.8% 99.8% 124.0% 0.00V 81 36.1% 157.3Hz 1188 0 5.63ms 7 67.9°F 2.36V
20° 203.0°F 94.4% 99.8% 99.8% 134.2% 0.02V 77 31.8% 163.5Hz 1219 3 5.63ms 7 67.1°F 2.36V
22° 203.0°F 94.4% 99.8% 99.8% 145.1% 0.43V 77 31.8% 169.8Hz 1281 3 5.63ms 7 67.1°F 2.36V
22° 203.0°F 94.4% 99.8% 99.8% 138.1% 0.60V 77 32.2% 176.1Hz 1313 2 5.38ms 7 66.3°F 2.36V
23° 203.0°F 94.4% 99.8% 99.8% 139.6% 0.21V 77 32.2% 188.7Hz 1375 2 5.63ms 8 66.3°F 2.36V
23° 203.0°F 94.4% 99.8% 99.8% 131.8% 0.66V 78 32.5% 201.3Hz 1406 1 5.63ms 8 65.5°F 2.36V
23° 203.0°F 94.4% 99.8% 99.8% 130.3% 0.31V 78 32.5% 207.6Hz 1469 0 5.89ms 9 65.5°F 2.36V
25° 203.0°F 94.4% 99.8% 99.8% 128.7% 0.70V 78 32.5% 213.9Hz 1531 0 5.63ms 9 64.7°F 2.36V
25° 203.0°F 94.4% 99.8% 99.8% 127.1% 0.18V 78 32.5% 220.2Hz 1594 0 5.89ms 10 64.7°F 2.36V
25° 203.0°F 94.4% 99.8% 99.8% 134.2% 0.72V 78 32.9% 232.7Hz 1625 0 5.63ms 9 64.7°F 2.36V
25° 203.0°F 94.4% 99.8% 99.8% 120.9% 0.33V 78 32.9% 239.0Hz 1688 0 5.89ms 10 64.7°F 2.36V
24° 203.0°F 94.4% 99.8% 99.8% 134.2% 0.68V 78 32.9% 251.6Hz 1750 0 5.38ms 10 64.0°F 2.36V
25° 203.0°F 94.4% 99.8% 99.8% 117.0% 0.74V 73 28.2% 226.4Hz 1781 0 4.86ms 9 64.0°F 2.36V
27° 203.0°F 94.4% 99.8% 99.8% 115.4% 0.08V 73 28.6% 232.7Hz 1844 0 5.38ms 10 64.0°F 2.36V
27° 203.0°F 94.4% 99.8% 99.8% 134.2% 0.51V 73 28.6% 251.6Hz 1906 0 5.38ms 10 64.0°F 2.36V
27° 203.0°F 94.4% 99.8% 99.8% 117.0% 0.80V 80 36.1% 283.1Hz 1969 0 6.40ms 13 64.0°F 2.36V
24° 203.0°F 94.4% 99.8% 99.8% 123.2% 0.06V 84 39.2% 314.5Hz 2031 0 6.66ms 14 63.2°F 2.36V
23° 203.0°F 94.4% 99.8% 99.8% 119.3% 0.80V 84 39.2% 333.4Hz 2063 0 6.40ms 14 63.2°F 2.36V
24° 203.0°F 94.4% 99.8% 99.8% 99.1% 0.57V 84 39.6% 346.0Hz 2156 1 6.66ms 15 63.2°F 2.36V
23° 203.0°F 94.4% 99.8% 99.8% 115.4% 0.70V 78 28.2% 308.2Hz 2219 0 4.61ms 10 62.4°F 2.36V
29° 203.0°F 94.4% 99.8% 99.8% 96.7% 0.88V 62 19.2% 257.9Hz 2250 0 3.07ms 7 63.2°F 2.36V
34° 203.0°F 94.4% 99.8% 99.8% 77.2% 0.90V 55 16.1% 81.8Hz 2250 0 1.54ms 3 63.2°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 75.7% 0.04V 43 11.0% 44.0Hz 2219 0 1.28ms 3 63.2°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 37.7Hz 2219 0 1.28ms 3 64.0°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2219 0 1.28ms 3 64.7°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.33V 34 11.0% 44.0Hz 2188 0 1.28ms 2 64.7°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 2188 0 1.28ms 2 65.5°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 2125 0 1.28ms 2 65.5°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2125 0 1.28ms 2 65.5°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2094 0 1.28ms 2 66.3°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2063 0 1.28ms 2 66.3°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 44.0Hz 2031 0 1.28ms 2 66.3°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 2000 0 1.28ms 2 66.3°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.02V 34 11.0% 44.0Hz 1969 0 1.28ms 2 67.1°F 2.36V
37° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1969 0 1.28ms 2 67.1°F 2.36V
35° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1906 0 1.28ms 2 67.1°F 2.36V
34° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 37.7Hz 1875 0 1.28ms 2 67.1°F 2.36V
33° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1813 0 1.28ms 2 67.1°F 2.36V
31° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1719 0 0.00ms 0 67.9°F 2.36V
16° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1656 0 0.00ms 0 67.9°F 2.36V
14° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.00V 34 11.0% 44.0Hz 1500 0 0.00ms 0 67.9°F 2.36V
10° 203.0°F 94.4% 99.8% 99.8% 103.7% 0.00V 34 11.0% 37.7Hz 1156 0 1.54ms 1 67.9°F 2.36V
15° 203.0°F 94.4% 99.8% 99.8% 110.0% 0.00V 34 11.0% 37.7Hz 938 0 1.79ms 1 67.9°F 2.36V
11° 203.0°F 94.4% 99.8% 99.8% 115.4% 0.02V 34 11.0% 37.7Hz 750 0 2.05ms 1 67.9°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 117.0% 0.70V 34 11.0% 31.5Hz 625 0 2.30ms 1 67.9°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 113.9% 0.80V 34 11.0% 37.7Hz 594 0 2.56ms 1 67.9°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 110.0% 0.82V 34 11.0% 37.7Hz 656 0 2.56ms 1 67.9°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 106.1% 0.80V 34 11.0% 44.0Hz 688 0 2.30ms 1 67.9°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 100.6% 0.78V 34 11.0% 44.0Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 97.5% 0.70V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 96.7% 0.16V 34 11.0% 37.7Hz 656 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 99.8% 0.04V 34 11.0% 37.7Hz 656 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 103.0% 0.02V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 106.9% 0.02V 34 11.0% 44.0Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 110.8% 0.06V 34 11.0% 44.0Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 114.7% 0.16V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 118.6% 0.18V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 119.3% 0.53V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 116.2% 0.74V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 94.4% 99.8% 99.8% 113.9% 0.72V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.36V
8° 203.0°F 95.2% 99.8% 99.8% 111.5% 0.59V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.38V
8° 203.0°F 95.2% 99.8% 99.8% 109.2% 0.53V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.38V
8° 203.0°F 95.2% 99.8% 99.8% 108.4% 0.59V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.38V
8° 203.0°F 95.2% 99.8% 99.8% 108.4% 0.16V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.38V
8° 203.0°F 95.2% 99.8% 99.8% 110.8% 0.08V 34 11.0% 44.0Hz 750 0 2.30ms 1 68.7°F 2.40V
8° 203.0°F 95.9% 99.8% 99.8% 111.5% 0.59V 34 11.0% 37.7Hz 750 0 2.30ms 1 68.7°F 2.40V
8° 203.0°F 95.9% 99.8% 99.8% 109.2% 0.70V 34 11.0% 37.7Hz 750 0 2.30ms 1 68.7°F 2.40V
8° 203.0°F 95.9% 99.8% 99.8% 106.1% 0.60V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.40V
8° 203.0°F 95.9% 99.8% 99.8% 103.7% 0.43V 34 11.0% 37.7Hz 750 0 2.30ms 1 68.7°F 2.42V
8° 203.0°F 96.7% 99.8% 99.8% 103.0% 0.47V 34 11.0% 37.7Hz 750 0 2.30ms 1 68.7°F 2.42V
8° 203.0°F 96.7% 99.8% 99.8% 100.6% 0.68V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.42V
8° 203.0°F 96.7% 99.8% 99.8% 100.6% 0.25V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.42V
9° 203.0°F 96.7% 99.8% 99.8% 103.0% 0.14V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.42V
9° 203.0°F 96.7% 99.8% 99.8% 104.5% 0.14V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 106.1% 0.20V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 106.9% 0.74V 34 11.0% 37.7Hz 813 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 103.7% 0.78V 34 11.0% 37.7Hz 813 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 100.6% 0.68V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 97.5% 0.47V 34 11.0% 37.7Hz 750 0 2.05ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 99.1% 0.12V 41 14.5% 37.7Hz 719 0 2.82ms 2 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 100.6% 0.04V 51 14.9% 56.6Hz 719 0 3.07ms 2 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 103.0% 0.02V 54 16.1% 62.9Hz 750 0 3.33ms 2 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 105.3% 0.00V 58 16.9% 75.5Hz 844 0 3.33ms 3 68.7°F 2.44V
12° 203.0°F 97.5% 99.8% 99.8% 107.6% 0.00V 58 16.9% 81.8Hz 969 0 3.33ms 3 67.9°F 2.44V
15° 203.0°F 97.5% 99.8% 99.8% 110.0% 0.00V 58 17.3% 88.1Hz 1031 0 3.07ms 3 67.9°F 2.44V
14° 203.0°F 97.5% 99.8% 99.8% 112.3% 0.00V 58 17.3% 75.5Hz 781 0 3.33ms 2 67.9°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 114.7% 0.00V 58 11.0% 69.2Hz 719 0 3.33ms 2 67.9°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 116.2% 0.04V 40 11.0% 62.9Hz 969 0 2.30ms 2 67.9°F 2.44V
13° 203.0°F 97.5% 99.8% 99.8% 115.4% 0.31V 34 11.0% 50.3Hz 1125 0 2.05ms 2 67.9°F 2.44V
16° 203.0°F 97.5% 99.8% 99.8% 121.7% 0.02V 34 11.0% 44.0Hz 1125 0 1.79ms 2 67.9°F 2.44V
15° 203.0°F 97.5% 99.8% 99.8% 127.9% 0.00V 34 11.0% 37.7Hz 1000 0 1.79ms 1 67.9°F 2.44V
12° 203.0°F 97.5% 99.8% 99.8% 133.4% 0.00V 34 11.0% 37.7Hz 906 0 2.05ms 1 68.7°F 2.44V
11° 203.0°F 97.5% 99.8% 99.8% 135.7% 0.72V 34 11.0% 37.7Hz 813 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 131.8% 0.84V 34 11.0% 37.7Hz 719 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 126.4% 0.86V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 122.5% 0.88V 34 11.0% 37.7Hz 656 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 118.6% 0.88V 34 11.0% 44.0Hz 750 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 113.9% 0.88V 34 11.0% 44.0Hz 781 0 2.30ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 109.2% 0.86V 34 11.0% 44.0Hz 813 0 2.05ms 1 68.7°F 2.44V
10° 203.0°F 97.5% 99.8% 99.8% 103.7% 0.84V 34 11.0% 44.0Hz 844 0 2.05ms 1 68.7°F 2.44V
10° 203.0°F 97.5% 99.8% 99.8% 99.1% 0.76V 34 11.0% 37.7Hz 781 0 2.05ms 1 68.7°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 95.9% 0.39V 34 11.0% 37.7Hz 750 0 2.05ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 99.8% 0.16V 34 11.0% 37.7Hz 688 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 103.7% 0.18V 34 11.0% 37.7Hz 656 0 2.30ms 1 68.7°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 106.1% 0.76V 34 11.0% 37.7Hz 656 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 103.7% 0.82V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 101.4% 0.82V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.46V
8° 203.0°F 98.3% 99.8% 99.8% 98.3% 0.78V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 96.7% 0.33V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 98.3% 0.14V 34 11.0% 37.7Hz 656 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.10V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 101.4% 0.08V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 102.2% 0.64V 34 11.0% 37.7Hz 719 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 99.8% 0.74V 34 11.0% 37.7Hz 719 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 97.5% 0.47V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 96.7% 0.12V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 99.1% 0.06V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 100.6% 0.06V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 102.2% 0.47V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 99.8% 0.66V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 97.5% 0.60V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 95.9% 0.29V 34 11.0% 37.7Hz 656 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 97.5% 0.04V 34 11.0% 37.7Hz 656 0 2.30ms 1 69.5°F 2.42V
8° 203.0°F 96.7% 99.8% 99.8% 99.1% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.42V
8° 206.4°F 96.7% 99.8% 99.8% 100.6% 0.06V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.42V
8° 203.0°F 97.5% 99.8% 99.8% 103.0% 0.10V 34 11.0% 37.7Hz 688 0 2.30ms 1 69.5°F 2.44V
8° 203.0°F 97.5% 99.8% 99.8% 102.2% 0.68V 34 11.0% 44.0Hz 750 0 2.30ms 1 69.5°F 2.44V
8° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.70V 51 18.8% 56.6Hz 781 0 3.58ms 2 69.5°F 2.44V
9° 203.0°F 97.5% 99.8% 99.8% 99.8% 0.00V 61 19.6% 106.9Hz 1031 0 3.84ms 4 69.5°F 2.44V
20° 206.4°F 97.5% 99.8% 99.8% 107.6% 0.00V 68 24.3% 151.0Hz 1406 0 4.35ms 6 68.7°F 2.44V
28° 203.0°F 97.5% 99.8% 99.8% 121.7% 0.00V 68 24.7% 157.3Hz 1469 0 4.61ms 7 68.7°F 2.44V
25° 203.0°F 97.5% 99.8% 99.8% 133.4% 0.02V 80 24.7% 125.8Hz 1031 0 5.12ms 5 67.9°F 2.44V
15° 203.0°F 97.5% 99.8% 99.8% 142.0% 0.08V 79 25.1% 119.5Hz 969 0 5.12ms 5 67.9°F 2.44V
20° 203.0°F 97.5% 99.8% 99.8% 143.5% 0.74V 84 25.1% 144.7Hz 1219 0 4.86ms 6 67.1°F 2.44V
24° 206.4°F 97.5% 99.8% 99.8% 142.7% 0.55V 84 25.5% 169.8Hz 1500 0 4.61ms 7 67.1°F 2.44V
27° 206.4°F 97.5% 99.8% 99.8% 128.7% 0.70V 84 25.5% 188.7Hz 1781 0 4.35ms 8 66.3°F 2.44V
29° 206.4°F 97.5% 99.8% 99.8% 117.0% 0.20V 84 25.5% 207.6Hz 2000 0 4.35ms 9 66.3°F 2.44V
31° 206.4°F 97.5% 99.8% 99.8% 116.2% 0.72V 84 25.5% 213.9Hz 2156 1 3.84ms 8 66.3°F 2.44V
31° 206.4°F 97.5% 99.8% 99.8% 117.8% 0.10V 77 26.7% 220.2Hz 2375 1 4.86ms 12 65.5°F 2.44V
29° 206.4°F 97.5% 99.8% 99.8% 119.3% 0.41V 82 36.9% 364.8Hz 2656 0 5.89ms 16 64.7°F 2.44V
30° 206.4°F 97.5% 99.8% 99.8% 112.3% 0.78V 82 36.9% 421.4Hz 3063 0 5.63ms 18 64.7°F 2.44V
31° 206.4°F 97.5% 99.8% 99.8% 107.6% 0.12V 83 34.9% 471.8Hz 3469 0 5.12ms 18 64.0°F 2.44V
34° 206.4°F 97.5% 99.8% 99.8% 99.1% 0.60V 66 22.4% 157.3Hz 3563 0 2.82ms 10 64.0°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 96.7% 0.82V 59 11.0% 151.0Hz 3500 0 1.28ms 4 64.0°F 2.44V
40° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.82V 38 11.0% 31.5Hz 3125 0 1.28ms 4 64.7°F 2.44V
39° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.68V 34 11.0% 31.5Hz 2719 0 1.28ms 3 65.5°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.68V 34 11.0% 37.7Hz 2250 0 1.28ms 3 65.5°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.57V 34 11.0% 44.0Hz 2125 0 1.28ms 2 66.3°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.68V 34 11.0% 37.7Hz 2125 0 1.28ms 2 66.3°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.57V 34 11.0% 44.0Hz 2094 0 1.28ms 2 67.1°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.72V 34 11.0% 44.0Hz 2094 0 1.28ms 2 67.1°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.70V 36 16.1% 44.0Hz 2000 0 1.79ms 3 67.1°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 89.7% 0.80V 65 22.4% 151.0Hz 2031 0 3.07ms 6 67.1°F 2.44V
33° 206.4°F 97.5% 99.8% 99.8% 74.1% 0.66V 78 32.5% 257.9Hz 2125 0 4.86ms 11 67.1°F 2.44V
28° 206.4°F 97.5% 99.8% 99.8% 95.2% 0.04V 82 36.5% 301.9Hz 2250 1 5.63ms 13 66.3°F 2.44V
28° 206.4°F 97.5% 99.8% 99.8% 113.9% 0.72V 84 39.6% 346.0Hz 2438 0 6.14ms 16 65.5°F 2.44V
28° 206.4°F 97.5% 99.8% 99.8% 120.1% 0.76V 85 40.4% 390.0Hz 2594 0 6.40ms 17 65.5°F 2.44V
28° 206.4°F 97.5% 99.8% 99.8% 99.1% 0.31V 86 42.0% 440.3Hz 2719 0 6.91ms 20 64.7°F 2.44V
28° 206.4°F 97.5% 99.8% 99.8% 115.4% 0.76V 86 42.0% 503.2Hz 2906 0 6.91ms 21 64.0°F 2.44V
27° 206.4°F 97.5% 99.8% 99.8% 110.8% 0.08V 87 42.4% 566.1Hz 3125 0 7.94ms 26 63.2°F 2.44V
27° 206.4°F 97.5% 99.8% 99.8% 120.1% 0.70V 87 42.4% 641.6Hz 3313 0 8.45ms 29 63.2°F 2.44V
26° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.86V 87 42.4% 761.1Hz 3625 0 10.75ms 41 62.4°F 2.44V
25° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.86V 87 42.7% 805.1Hz 3938 0 10.24ms 43 61.6°F 2.44V
26° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.86V 85 36.5% 710.8Hz 4125 0 7.17ms 31 60.8°F 2.44V
30° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.23V 82 17.6% 509.5Hz 4375 0 2.05ms 9 60.8°F 2.44V
42° 206.4°F 97.5% 99.8% 99.8% 84.2% 0.74V 61 11.0% 100.6Hz 3844 0 1.54ms 6 61.6°F 2.44V
40° 206.4°F 97.5% 99.8% 99.8% 53.0% 0.86V 66 26.7% 157.3Hz 3094 0 3.07ms 10 62.4°F 2.44V
35° 206.4°F 97.5% 99.8% 99.8% 53.0% 0.74V 92 49.0% 452.9Hz 2875 0 7.17ms 22 62.4°F 2.44V
27° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.76V 95 54.1% 566.1Hz 3000 0 8.70ms 27 61.6°F 2.44V
25° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.88V 95 54.5% 654.2Hz 3125 0 10.24ms 34 61.6°F 2.44V
23° 206.4°F 97.5% 99.8% 99.8% 99.8% 0.88V 95 54.5% 729.6Hz 3281 0 11.26ms 39 60.8°F 2.44V
24° 206.4°F 97.5% 99.8% 99.8% 90.5% 0.94V 83 11.0% 182.4Hz 3375 0 1.54ms 5 61.6°F 2.44V
40° 206.4°F 97.5% 99.8% 99.8% 64.7% 0.76V 62 13.3% 106.9Hz 3000 0 1.28ms 4 63.2°F 2.44V
39° 206.4°F 97.5% 99.8% 99.8% 42.9% 0.70V 59 18.0% 81.8Hz 2406 0 1.79ms 4 63.2°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 54.6% 0.02V 64 21.6% 182.4Hz 2406 0 2.82ms 7 63.2°F 2.44V
36° 206.4°F 97.5% 99.8% 99.8% 45.2% 0.94V 48 11.0% 94.4Hz 2344 0 1.54ms 3 64.0°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.84V 34 11.0% 81.8Hz 2313 0 1.28ms 3 64.0°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 32.8% 0.82V 34 11.0% 75.5Hz 2281 0 1.28ms 3 64.7°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.76V 34 11.0% 69.2Hz 2281 0 1.28ms 3 64.7°F 2.44V
38° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.84V 34 11.0% 56.6Hz 2188 0 1.54ms 3 65.5°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.72V 34 11.0% 75.5Hz 2125 0 1.28ms 2 65.5°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.78V 34 11.0% 56.6Hz 2000 0 1.28ms 2 65.5°F 2.44V
37° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.86V 34 11.0% 50.3Hz 1969 0 1.28ms 2 66.3°F 2.44V
36° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.78V 34 11.0% 56.6Hz 1906 0 1.28ms 2 66.3°F 2.44V
35° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.78V 34 11.0% 50.3Hz 1938 0 1.28ms 2 66.3°F 2.44V
34° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.86V 34 11.0% 50.3Hz 1906 0 1.28ms 2 66.3°F 2.44V
34° 206.4°F 97.5% 99.8% 99.8% 32.8% 0.80V 34 11.0% 56.6Hz 1875 0 1.54ms 3 67.1°F 2.44V
33° 206.4°F 97.5% 99.8% 99.8% 32.8% 0.80V 34 11.0% 50.3Hz 1813 0 1.54ms 2 67.1°F 2.44V
32° 206.4°F 97.5% 99.8% 99.8% 32.8% 0.86V 34 11.0% 50.3Hz 1781 0 1.54ms 2 67.1°F 2.44V
30° 206.4°F 97.5% 99.8% 99.8% 32.0% 0.84V 34 11.0% 62.9Hz 1719 0 1.28ms 2 67.1°F 2.44V
29° 209.8°F 97.5% 99.8% 99.8% 32.8% 0.86V 34 11.0% 44.0Hz 1688 0 1.28ms 2 67.1°F 2.44V
29° 209.8°F 97.5% 99.8% 99.8% 32.0% 0.57V 34 11.0% 37.7Hz 1656 0 1.28ms 2 67.9°F 2.44V
27° 209.8°F 97.5% 99.8% 99.8% 40.6% 0.04V 34 11.0% 44.0Hz 1656 0 1.28ms 2 67.9°F 2.44V
27° 209.8°F 97.5% 99.8% 99.8% 51.5% 0.00V 34 11.0% 44.0Hz 1625 0 1.28ms 2 67.9°F 2.44V
27° 209.8°F 97.5% 99.8% 99.8% 61.6% 0.00V 34 11.0% 44.0Hz 1594 0 1.28ms 2 67.9°F 2.44V
26° 209.8°F 97.5% 99.8% 99.8% 72.5% 0.02V 34 11.0% 44.0Hz 1531 0 1.54ms 2 67.9°F 2.44V
24° 209.8°F 97.5% 99.8% 99.8% 78.8% 0.74V 34 11.0% 44.0Hz 1438 0 1.28ms 1 67.9°F 2.44V
23° 209.8°F 97.5% 99.8% 99.8% 69.4% 0.68V 34 11.0% 44.0Hz 1375 0 1.54ms 2 67.9°F 2.44V
21° 209.8°F 97.5% 99.8% 99.8% 71.8% 0.20V 34 11.0% 44.0Hz 1313 0 1.54ms 2 67.9°F 2.44V
18° 209.8°F 97.5% 99.8% 99.8% 78.8% 0.31V 34 11.0% 37.7Hz 1219 0 1.54ms 2 67.9°F 2.44V
17° 209.8°F 97.5% 99.8% 99.8% 74.9% 0.82V 34 11.0% 37.7Hz 1063 0 1.54ms 1 67.9°F 2.44V
13° 209.8°F 97.5% 99.8% 99.8% 68.6% 0.72V 34 11.0% 31.5Hz 781 0 1.79ms 1 67.9°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 69.4% 0.06V 34 11.0% 31.5Hz 656 0 2.05ms 1 67.9°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 73.3% 0.02V 34 11.0% 50.3Hz 938 0 2.05ms 2 67.9°F 2.44V
14° 209.8°F 97.5% 99.8% 99.8% 75.7% 0.80V 34 11.0% 50.3Hz 1219 0 1.79ms 2 67.9°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 67.9% 0.64V 34 11.0% 44.0Hz 1188 0 1.54ms 1 67.9°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 73.3% 0.04V 34 11.0% 44.0Hz 1125 0 1.79ms 2 67.9°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 79.6% 0.04V 49 11.0% 44.0Hz 1125 0 1.79ms 2 67.9°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 85.0% 0.10V 49 11.0% 44.0Hz 1125 0 1.79ms 2 67.9°F 2.44V
15° 209.8°F 97.5% 99.8% 99.8% 83.5% 0.82V 49 11.0% 44.0Hz 1063 0 1.79ms 2 67.9°F 2.44V
15° 209.8°F 97.5% 99.8% 99.8% 76.4% 0.80V 49 11.0% 44.0Hz 1063 0 1.79ms 2 67.9°F 2.44V
14° 209.8°F 97.5% 99.8% 99.8% 73.3% 0.16V 59 14.5% 50.3Hz 1063 0 2.05ms 2 67.9°F 2.44V
15° 209.8°F 97.5% 99.8% 99.8% 80.3% 0.06V 69 15.7% 69.2Hz 1094 0 2.56ms 2 67.9°F 2.44V
15° 209.8°F 97.5% 99.8% 99.8% 86.6% 0.04V 61 16.5% 75.5Hz 1031 0 2.82ms 3 67.9°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 92.0% 0.02V 60 18.8% 88.1Hz 1063 0 3.33ms 3 67.1°F 2.44V
17° 209.8°F 97.5% 99.8% 99.8% 101.4% 0.02V 63 20.8% 106.9Hz 1063 0 4.10ms 4 67.1°F 2.44V
18° 209.8°F 97.5% 99.8% 99.8% 110.8% 0.02V 64 21.6% 119.5Hz 1063 0 4.61ms 5 67.1°F 2.44V
19° 209.8°F 97.5% 99.8% 99.8% 119.3% 0.04V 65 22.4% 125.8Hz 1094 0 4.61ms 5 66.3°F 2.44V
19° 209.8°F 97.5% 99.8% 99.8% 130.3% 0.55V 66 23.1% 132.1Hz 1125 0 4.61ms 5 66.3°F 2.44V
20° 209.8°F 97.5% 99.8% 99.8% 120.1% 0.74V 66 23.1% 138.4Hz 1156 0 4.61ms 5 66.3°F 2.44V
22° 209.8°F 97.5% 99.8% 99.8% 110.8% 0.41V 66 23.1% 144.7Hz 1188 0 4.86ms 6 65.5°F 2.44V
23° 209.8°F 97.5% 99.8% 99.8% 112.3% 0.78V 67 23.5% 151.0Hz 1250 0 4.61ms 6 65.5°F 2.44V
24° 209.8°F 97.5% 99.8% 99.8% 101.4% 0.80V 67 23.5% 151.0Hz 1250 0 4.35ms 5 65.5°F 2.44V
24° 209.8°F 97.5% 99.8% 99.8% 90.5% 0.62V 62 19.6% 132.1Hz 1313 0 3.58ms 5 65.5°F 2.44V
25° 209.8°F 97.5% 99.8% 99.8% 86.6% 0.10V 59 18.0% 113.2Hz 1313 0 3.07ms 4 64.7°F 2.44V
23° 209.8°F 97.5% 99.8% 99.8% 98.3% 0.02V 59 17.3% 100.6Hz 1344 0 3.07ms 4 64.7°F 2.44V
23° 209.8°F 97.5% 99.8% 99.8% 106.1% 0.47V 46 11.8% 62.9Hz 1344 0 1.79ms 2 65.5°F 2.44V
20° 209.8°F 97.5% 99.8% 99.8% 97.5% 0.84V 38 11.8% 50.3Hz 1344 0 1.79ms 2 65.5°F 2.44V
20° 209.8°F 97.5% 99.8% 99.8% 88.9% 0.62V 38 11.4% 50.3Hz 1344 0 1.54ms 2 65.5°F 2.44V
19° 209.8°F 97.5% 99.8% 99.8% 87.4% 0.20V 34 11.0% 44.0Hz 1313 0 1.54ms 2 65.5°F 2.44V
20° 209.8°F 97.5% 99.8% 99.8% 94.4% 0.60V 34 11.0% 44.0Hz 1281 0 1.54ms 2 66.3°F 2.44V
19° 209.8°F 97.5% 99.8% 99.8% 87.4% 0.78V 34 11.0% 44.0Hz 1281 0 1.54ms 2 66.3°F 2.44V
18° 209.8°F 97.5% 99.8% 99.8% 78.8% 0.82V 34 11.0% 44.0Hz 1250 0 1.54ms 2 66.3°F 2.44V
18° 209.8°F 97.5% 99.8% 99.8% 71.8% 0.84V 34 11.0% 44.0Hz 1219 0 1.54ms 2 66.3°F 2.44V
18° 209.8°F 97.5% 99.8% 99.8% 64.7% 0.82V 34 11.0% 44.0Hz 1188 0 1.54ms 1 66.3°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 57.7% 0.60V 34 11.0% 44.0Hz 1125 0 1.54ms 1 66.3°F 2.44V
16° 209.8°F 97.5% 99.8% 99.8% 60.1% 0.10V 34 11.0% 44.0Hz 1063 0 1.79ms 2 66.3°F 2.44V
14° 209.8°F 97.5% 99.8% 99.8% 66.3% 0.04V 34 11.0% 37.7Hz 969 0 1.79ms 1 67.1°F 2.44V
12° 209.8°F 97.5% 99.8% 99.8% 71.8% 0.06V 34 11.0% 37.7Hz 875 0 1.79ms 1 67.1°F 2.44V
10° 209.8°F 97.5% 99.8% 99.8% 75.7% 0.18V 34 11.0% 37.7Hz 688 0 2.05ms 1 67.1°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 75.7% 0.62V 34 11.0% 37.7Hz 625 0 2.30ms 1 67.1°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 74.9% 0.23V 34 11.0% 37.7Hz 563 0 2.56ms 1 67.1°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 78.8% 0.06V 49 11.0% 37.7Hz 594 0 2.56ms 1 67.1°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 81.1% 0.04V 49 11.0% 44.0Hz 656 0 2.56ms 1 67.1°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 85.0% 0.04V 49 11.0% 44.0Hz 688 0 2.56ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 88.9% 0.04V 41 11.0% 44.0Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 92.8% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 96.7% 0.02V 37 11.4% 44.0Hz 719 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 100.6% 0.02V 42 14.1% 44.0Hz 719 0 2.82ms 2 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 104.5% 0.00V 67 15.3% 56.6Hz 750 0 3.07ms 2 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 109.2% 0.00V 52 15.3% 56.6Hz 688 0 3.33ms 2 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 113.1% 0.00V 54 15.7% 69.2Hz 750 0 3.33ms 2 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 115.4% 0.00V 55 16.1% 69.2Hz 781 0 3.33ms 2 67.1°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 117.8% 0.00V 57 16.5% 75.5Hz 844 0 3.33ms 3 67.1°F 2.42V
11° 209.8°F 96.7% 99.8% 99.8% 119.3% 0.00V 57 16.5% 75.5Hz 813 0 3.33ms 2 67.1°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 121.7% 0.00V 57 16.5% 69.2Hz 781 0 3.58ms 2 66.3°F 2.42V
9° 209.8°F 96.7% 99.8% 99.8% 124.0% 0.00V 57 16.5% 75.5Hz 844 0 3.33ms 3 66.3°F 2.42V
12° 209.8°F 96.7% 99.8% 99.8% 126.4% 0.02V 52 15.3% 69.2Hz 875 0 3.07ms 2 66.3°F 2.42V
11° 209.8°F 96.7% 99.8% 99.8% 128.7% 0.02V 52 15.3% 69.2Hz 906 0 3.07ms 2 66.3°F 2.42V
12° 209.8°F 96.7% 99.8% 99.8% 131.0% 0.02V 42 11.0% 56.6Hz 1000 0 2.30ms 2 66.3°F 2.42V
13° 209.8°F 96.7% 99.8% 99.8% 131.0% 0.78V 34 11.0% 50.3Hz 1094 0 2.05ms 2 66.3°F 2.42V
15° 209.8°F 96.7% 99.8% 99.8% 123.2% 0.82V 34 11.0% 44.0Hz 1063 0 1.79ms 2 66.3°F 2.42V
14° 209.8°F 96.7% 99.8% 99.8% 117.8% 0.70V 34 11.0% 37.7Hz 969 0 1.79ms 1 66.3°F 2.42V
12° 209.8°F 96.7% 99.8% 99.8% 118.6% 0.57V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.1°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 113.9% 0.84V 34 11.0% 37.7Hz 750 0 2.05ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 109.2% 0.86V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 105.3% 0.86V 34 11.0% 37.7Hz 656 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 101.4% 0.84V 34 11.0% 37.7Hz 656 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 97.5% 0.84V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 93.6% 0.78V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 90.5% 0.29V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 93.6% 0.08V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 97.5% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.1°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 100.6% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 105.3% 0.06V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 108.4% 0.04V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 112.3% 0.10V 34 11.0% 37.7Hz 719 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 113.9% 0.20V 34 11.0% 37.7Hz 688 0 2.30ms 1 67.9°F 2.42V
8° 209.8°F 96.7% 99.8% 99.8% 115.4% 0.12V 34 11.0% 44.0Hz 750 0 2.30ms 1 67.9°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 117.0% 0.45V 34 11.0% 44.0Hz 750 0 2.30ms 1 67.9°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 116.2% 0.60V 34 11.0% 44.0Hz 781 0 2.30ms 1 67.9°F 2.44V
8° 209.8°F 97.5% 99.8% 99.8% 113.1% 0.68V 34 11.0% 37.7Hz 781 0 2.30ms 1 67.9°F 2.44V
9° 209.8°F 97.5% 99.8% 99.8% 112.3% 0.14V 34 11.0% 44.0Hz 813 0 2.30ms 2 67.9°F 2.44V
9° 209.8°F 98.3% 99.8% 99.8% 114.7% 0.04V 34 11.0% 44.0Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 117.0% 0.04V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 118.6% 0.06V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 120.1% 0.59V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 117.0% 0.82V 34 11.0% 44.0Hz 906 0 2.05ms 1 67.9°F 2.48V
11° 209.8°F 99.1% 99.8% 99.8% 113.9% 0.84V 34 11.0% 44.0Hz 938 0 2.05ms 2 67.9°F 2.48V
12° 209.8°F 99.1% 99.8% 99.8% 110.0% 0.80V 34 11.0% 44.0Hz 938 0 1.79ms 1 67.9°F 2.48V
12° 209.8°F 99.1% 99.8% 99.8% 106.1% 0.80V 34 11.0% 37.7Hz 938 0 1.79ms 1 67.9°F 2.48V
12° 209.8°F 99.1% 99.8% 99.8% 102.2% 0.76V 34 11.0% 37.7Hz 938 0 1.79ms 1 67.9°F 2.50V
11° 209.8°F 99.8% 99.8% 99.8% 99.1% 0.64V 34 11.0% 37.7Hz 906 0 1.79ms 1 67.9°F 2.48V
11° 209.8°F 99.1% 99.8% 99.8% 100.6% 0.41V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.50V
11° 209.8°F 99.8% 99.8% 99.8% 99.1% 0.74V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.48V
11° 209.8°F 99.1% 99.8% 99.8% 95.2% 0.84V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.48V
10° 209.8°F 99.1% 99.8% 99.8% 92.8% 0.82V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.48V
10° 209.8°F 99.1% 99.8% 99.8% 88.9% 0.80V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.48V
10° 209.8°F 99.1% 99.8% 99.8% 85.8% 0.76V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.48V
10° 209.8°F 98.3% 99.8% 99.8% 84.2% 0.41V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 86.6% 0.10V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 88.9% 0.08V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 90.5% 0.08V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.46V
10° 209.8°F 98.3% 99.8% 99.8% 92.8% 0.08V 34 11.0% 44.0Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 95.2% 0.08V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 96.7% 0.08V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 99.1% 0.06V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 101.4% 0.23V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 99.8% 0.76V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 96.7% 0.80V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
11° 209.8°F 97.5% 99.8% 99.8% 92.8% 0.70V 34 11.0% 37.7Hz 875 0 2.05ms 1 67.9°F 2.44V
10° 209.8°F 96.7% 99.8% 99.8% 92.0% 0.33V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 94.4% 0.14V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 96.7% 0.23V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 95.9% 0.68V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.42V
10° 209.8°F 96.7% 99.8% 99.8% 92.8% 0.57V 34 11.0% 37.7Hz 844 0 2.05ms 1 67.9°F 2.40V
Ok, I still dont know if I am lean or rich and I need someone to help me. I am rich at times and lean at others so I am lost. The car has little botom end power because of it running so rich. I need to figure this out because I don't know wether to richen or lean low throtle? Espeshaly 800rpms to 4200rpms. My adjusting points with the safc2 are 800 1600 2200 3200 4200 Just tell me which way and how much to adjust. Thanks.
TIMA FTRL FTRM FTRH FTO2 O2-R TPS RPM KNCK
10° 91.3% 99.8% 99.8% 103.0% 0.08V 11.0% 844 0
10° 91.3% 99.8% 99.8% 105.3% 0.25V 11.0% 813 0
10° 91.3% 99.8% 99.8% 104.5% 0.70V 11.0% 813 0
10° 92.0% 99.8% 99.8% 101.4% 0.76V 11.0% 844 0
10° 92.0% 99.8% 99.8% 98.3% 0.72V 11.0% 844 0
10° 92.0% 99.8% 99.8% 95.2% 0.70V 11.0% 813 0
10° 91.3% 99.8% 99.8% 93.6% 0.39V 11.0% 813 0
9° 91.3% 99.8% 99.8% 95.9% 0.14V 11.0% 813 0
9° 91.3% 99.8% 99.8% 97.5% 0.10V 11.0% 781 0
9° 91.3% 99.8% 99.8% 99.8% 0.08V 11.0% 813 0
9° 91.3% 99.8% 99.8% 101.4% 0.10V 11.0% 813 0
10° 91.3% 99.8% 99.8% 103.7% 0.27V 11.0% 844 0
10° 91.3% 99.8% 99.8% 106.1% 0.47V 11.0% 844 0
10° 91.3% 99.8% 99.8% 107.6% 0.55V 11.0% 875 0
10° 92.0% 99.8% 99.8% 104.5% 0.72V 11.0% 875 0
11° 92.0% 99.8% 99.8% 101.4% 0.68V 11.0% 844 0
10° 92.0% 99.8% 99.8% 98.3% 0.64V 11.0% 750 0
8° 92.0% 99.8% 99.8% 95.2% 0.64V 11.0% 688 0
8° 91.3% 99.8% 99.8% 93.6% 0.29V 11.0% 656 0
8° 91.3% 99.8% 99.8% 93.6% 0.55V 11.0% 656 0
8° 91.3% 99.8% 99.8% 91.3% 0.66V 11.0% 656 0
8° 91.3% 99.8% 99.8% 89.7% 0.29V 11.0% 688 0
8° 91.3% 99.8% 99.8% 91.3% 0.10V 11.0% 719 0
8° 90.5% 99.8% 99.8% 93.6% 0.06V 11.0% 750 0
8° 90.5% 99.8% 99.8% 95.2% 0.04V 11.0% 750 0
8° 90.5% 99.8% 99.8% 96.7% 0.04V 11.0% 750 0
8° 90.5% 99.8% 99.8% 99.1% 0.04V 11.0% 719 0
8° 90.5% 99.8% 99.8% 100.6% 0.04V 11.0% 719 0
8° 90.5% 99.8% 99.8% 102.2% 0.14V 12.9% 719 0
8° 90.5% 99.8% 99.8% 103.7% 0.53V 14.9% 719 0
8° 90.5% 99.8% 99.8% 105.3% 0.04V 14.9% 781 0
9° 90.5% 99.8% 99.8% 107.6% 0.02V 14.9% 875 0
11° 90.5% 99.8% 99.8% 110.0% 0.00V 14.9% 969 0
14° 90.5% 99.8% 99.8% 112.3% 0.00V 11.0% 1063 0
15° 90.5% 99.8% 99.8% 117.8% 0.04V 11.0% 1000 0
12° 90.5% 99.8% 99.8% 117.0% 0.74V 11.0% 781 0
8° 90.5% 99.8% 99.8% 112.3% 0.80V 11.0% 688 0
8° 90.5% 99.8% 99.8% 108.4% 0.80V 11.0% 688 0
8° 90.5% 99.8% 99.8% 103.7% 0.82V 11.0% 688 0
8° 90.5% 99.8% 99.8% 99.8% 0.82V 11.0% 688 0
8° 90.5% 99.8% 99.8% 95.9% 0.76V 11.0% 656 0
8° 90.5% 99.8% 99.8% 92.0% 0.53V 11.0% 625 0
8° 90.5% 99.8% 99.8% 95.9% 0.12V 11.0% 656 0
8° 90.5% 99.8% 99.8% 99.8% 0.06V 11.0% 656 0
8° 90.5% 99.8% 99.8% 103.0% 0.06V 11.0% 688 0
8° 90.5% 99.8% 99.8% 106.9% 0.20V 11.0% 719 0
8° 90.5% 99.8% 99.8% 106.9% 0.57V 11.0% 719 0
8° 90.5% 99.8% 99.8% 103.0% 0.68V 11.0% 719 0
8° 90.5% 99.8% 99.8% 99.1% 0.64V 11.0% 688 0
8° 90.5% 99.8% 99.8% 96.7% 0.49V 11.0% 688 0
8° 90.5% 99.8% 99.8% 97.5% 0.20V 11.0% 719 0
8° 90.5% 99.8% 99.8% 99.1% 0.20V 11.0% 719 0
8° 90.5% 99.8% 99.8% 101.4% 0.43V 11.0% 750 0
8° 90.5% 99.8% 99.8% 100.6% 0.53V 11.0% 781 0
9° 90.5% 99.8% 99.8% 100.6% 0.41V 11.0% 750 0
8° 90.5% 99.8% 99.8% 102.2% 0.20V 11.0% 688 0
8° 91.3% 99.8% 99.8% 103.7% 0.12V 11.0% 625 0
8° 91.3% 99.8% 99.8% 105.3% 0.20V 11.0% 656 0
8° 91.3% 99.8% 99.8% 106.1% 0.62V 11.0% 688 0
8° 91.3% 99.8% 99.8% 103.7% 0.74V 11.0% 719 0
8° 92.0% 99.8% 99.8% 100.6% 0.76V 11.0% 750 0
8° 92.0% 99.8% 99.8% 97.5% 0.70V 11.0% 750 0
8° 91.3% 99.8% 99.8% 96.7% 0.31V 11.0% 719 0
8° 91.3% 99.8% 99.8% 99.1% 0.14V 11.0% 688 0
8° 91.3% 99.8% 99.8% 100.6% 0.10V 11.0% 656 0
8° 91.3% 99.8% 99.8% 102.2% 0.10V 11.0% 656 0
8° 91.3% 99.8% 99.8% 103.7% 0.55V 11.0% 688 0
8° 92.0% 99.8% 99.8% 100.6% 0.70V 11.0% 719 0
8° 92.0% 99.8% 99.8% 98.3% 0.68V 11.0% 688 0
8° 91.3% 99.8% 99.8% 95.9% 0.47V 11.0% 656 0
8° 91.3% 99.8% 99.8% 96.7% 0.10V 11.0% 656 0
8° 91.3% 99.8% 99.8% 98.3% 0.04V 11.0% 656 0
8° 91.3% 99.8% 99.8% 99.8% 0.02V 11.0% 656 0
8° 91.3% 99.8% 99.8% 102.2% 0.02V 11.0% 688 0
8° 91.3% 99.8% 99.8% 103.7% 0.25V 11.0% 688 0
8° 91.3% 99.8% 99.8% 105.3% 0.41V 11.0% 688 0
8° 92.0% 99.8% 99.8% 105.3% 0.55V 11.0% 688 0
8° 92.0% 99.8% 99.8% 102.2% 0.60V 11.0% 688 0
8° 92.0% 99.8% 99.8% 102.2% 0.31V 11.0% 656 0
8° 92.0% 99.8% 99.8% 103.7% 0.14V 11.0% 688 0
8° 92.8% 99.8% 99.8% 105.3% 0.16V 11.0% 688 0
8° 92.8% 99.8% 99.8% 106.9% 0.18V 11.0% 688 0
8° 92.8% 99.8% 99.8% 107.6% 0.57V 11.0% 688 0
8° 92.8% 99.8% 99.8% 105.3% 0.68V 11.0% 688 0
8° 93.6% 99.8% 99.8% 103.0% 0.43V 11.0% 656 0
8° 93.6% 99.8% 99.8% 104.5% 0.14V 11.0% 688 0
8° 93.6% 99.8% 99.8% 106.1% 0.39V 11.0% 688 0
8° 93.6% 99.8% 99.8% 104.5% 0.72V 11.0% 688 0
8° 93.6% 99.8% 99.8% 102.2% 0.62V 11.0% 688 0
8° 94.4% 99.8% 99.8% 100.6% 0.59V 11.0% 656 0
8° 94.4% 99.8% 99.8% 100.6% 0.21V 11.0% 688 0
8° 94.4% 99.8% 99.8% 103.0% 0.21V 11.0% 688 0
8° 94.4% 99.8% 99.8% 102.2% 0.68V 11.0% 688 0
8° 94.4% 99.8% 99.8% 99.8% 0.70V 11.0% 688 0
8° 94.4% 99.8% 99.8% 97.5% 0.55V 11.0% 688 0
8° 94.4% 99.8% 99.8% 98.3% 0.16V 11.0% 688 0
8° 95.9% 99.8% 99.8% 94.4% 0.55V 11.0% 656 0
8° 95.9% 99.8% 99.8% 92.8% 0.59V 11.0% 656 0
8° 95.9% 99.8% 99.8% 91.3% 0.25V 11.0% 688 0
8° 95.9% 99.8% 99.8% 93.6% 0.08V 11.0% 656 0
8° 95.9% 99.8% 99.8% 95.2% 0.06V 11.0% 656 0
8° 95.2% 99.8% 99.8% 96.7% 0.04V 11.0% 656 0
8° 95.2% 99.8% 99.8% 98.3% 0.12V 11.0% 656 0
8° 95.2% 99.8% 99.8% 99.8% 0.59V 11.0% 719 0
8° 95.2% 99.8% 99.8% 96.7% 0.70V 11.0% 750 0
8° 95.2% 99.8% 99.8% 94.4% 0.60V 11.0% 750 0
8° 94.4% 99.8% 99.8% 94.4% 0.35V 11.0% 750 0
8° 94.4% 99.8% 99.8% 95.9% 0.14V 11.0% 750 0
8° 94.4% 99.8% 99.8% 97.5% 0.14V 11.0% 719 0
8° 94.4% 99.8% 99.8% 98.3% 0.64V 11.0% 719 0
8° 93.6% 99.8% 99.8% 95.2% 0.72V 15.7% 688 0
8° 93.6% 99.8% 99.8% 93.6% 0.14V 16.5% 844 0
12° 93.6% 99.8% 99.8% 95.9% 0.02V 16.5% 1031 0
16° 93.6% 99.8% 99.8% 100.6% 0.00V 16.5% 1156 0
17° 93.6% 99.8% 99.8% 107.6% 0.00V 15.7% 1094 0
14° 93.6% 99.8% 99.8% 113.1% 0.00V 11.0% 1031 0
13° 93.6% 99.8% 99.8% 119.3% 0.49V 11.0% 906 0
11° 93.6% 99.8% 99.8% 114.7% 0.78V 11.0% 875 0
10° 93.6% 99.8% 99.8% 110.0% 0.78V 11.0% 813 0
9° 93.6% 99.8% 99.8% 105.3% 0.78V 11.0% 781 0
8° 93.6% 99.8% 99.8% 99.8% 0.78V 11.0% 719 0
8° 93.6% 99.8% 99.8% 96.7% 0.78V 11.0% 656 0
8° 93.6% 99.8% 99.8% 92.0% 0.78V 11.0% 688 0
8° 93.6% 99.8% 99.8% 88.1% 0.76V 11.0% 656 0
8° 93.6% 99.8% 99.8% 84.2% 0.55V 11.0% 688 0
8° 93.6% 99.8% 99.8% 83.5% 0.33V 11.0% 688 0
8° 93.6% 99.8% 99.8% 87.4% 0.10V 11.0% 719 0
8° 93.6% 99.8% 99.8% 91.3% 0.06V 11.0% 719 0
8° 93.6% 99.8% 99.8% 94.4% 0.04V 11.0% 719 0
8° 93.6% 99.8% 99.8% 98.3% 0.02V 11.0% 750 0
8° 93.6% 99.8% 99.8% 101.4% 0.02V 11.0% 750 0
8° 93.6% 99.8% 99.8% 103.0% 0.04V 11.8% 688 0
8° 93.6% 99.8% 99.8% 104.5% 0.31V 14.1% 594 0
8° 93.6% 99.8% 99.8% 104.5% 0.68V 11.0% 688 0
8° 93.6% 99.8% 99.8% 101.4% 0.80V 11.0% 906 0
12° 93.6% 99.8% 99.8% 98.3% 0.80V 11.0% 1000 0
13° 93.6% 99.8% 99.8% 94.4% 0.49V 12.2% 969 0
12° 93.6% 99.8% 99.8% 95.9% 0.06V 14.5% 813 0
9° 93.6% 99.8% 99.8% 98.3% 0.00V 14.5% 750 0
8° 93.6% 99.8% 99.8% 99.8% 0.00V 14.9% 750 0
8° 93.6% 99.8% 99.8% 102.2% 0.00V 11.0% 875 0
11° 93.6% 99.8% 99.8% 104.5% 0.00V 11.0% 969 0
13° 93.6% 99.8% 99.8% 106.9% 0.12V 11.0% 969 0
12° 93.6% 99.8% 99.8% 109.2% 0.10V 11.0% 969 0
12° 93.6% 99.8% 99.8% 111.5% 0.04V 11.0% 969 0
12° 93.6% 99.8% 99.8% 113.9% 0.53V 11.0% 844 0
10° 93.6% 99.8% 99.8% 110.8% 0.70V 12.2% 750 0
8° 93.6% 99.8% 99.8% 107.6% 0.74V 12.5% 750 0
8° 93.6% 99.8% 99.8% 105.3% 0.70V 11.8% 656 0
8° 93.6% 99.8% 99.8% 103.7% 0.53V 11.0% 719 0
8° 93.6% 99.8% 99.8% 100.6% 0.78V 11.0% 781 0
9° 93.6% 99.8% 99.8% 97.5% 0.74V 11.0% 781 0
8° 93.6% 99.8% 99.8% 95.2% 0.59V 11.0% 719 0
8° 93.6% 99.8% 99.8% 94.4% 0.21V 11.0% 625 0
8° 93.6% 99.8% 99.8% 95.9% 0.08V 11.0% 625 0
8° 93.6% 99.8% 99.8% 97.5% 0.06V 11.0% 625 0
8° 93.6% 99.8% 99.8% 99.1% 0.06V 11.0% 656 0
8° 93.6% 99.8% 99.8% 99.8% 0.62V 19.6% 688 0
8° 93.6% 99.8% 99.8% 98.3% 0.04V 21.2% 938 0
18° 93.6% 99.8% 99.8% 105.3% 0.00V 24.7% 1250 0
24° 93.6% 99.8% 99.8% 116.2% 0.00V 29.4% 1313 0
24° 93.6% 99.8% 99.8% 127.1% 0.00V 30.2% 1250 0
21° 93.6% 99.8% 99.8% 138.1% 0.08V 30.2% 969 0
14° 93.6% 99.8% 99.8% 134.2% 0.68V 31.4% 1313 0
24° 93.6% 99.8% 99.8% 138.1% 0.08V 34.5% 1594 1
24° 93.6% 99.8% 99.8% 147.4% 0.70V 36.1% 1906 0
26° 93.6% 99.8% 99.8% 127.1% 0.78V 36.5% 2281 0
28° 93.6% 99.8% 99.8% 103.7% 0.68V 36.5% 2656 0
30° 93.6% 99.8% 99.8% 93.6% 0.21V 36.5% 3031 0
32° 93.6% 99.8% 99.8% 104.5% 0.66V 33.7% 3375 0
33° 93.6% 99.8% 99.8% 124.8% 0.12V 33.3% 3688 0
40° 93.6% 99.8% 99.8% 122.5% 0.84V 11.0% 3313 0
39° 93.6% 99.8% 99.8% 99.8% 0.66V 11.0% 2844 0
39° 93.6% 99.8% 99.8% 99.8% 0.62V 17.3% 2406 0
38° 93.6% 99.8% 99.8% 112.3% 0.10V 21.2% 2219 0
34° 93.6% 99.8% 99.8% 103.7% 0.74V 26.3% 2250 0
31° 93.6% 99.8% 99.8% 105.3% 0.10V 36.5% 2344 0
28° 93.6% 99.8% 99.8% 120.1% 0.78V 36.1% 2438 0
29° 93.6% 99.8% 99.8% 98.3% 0.47V 38.0% 2625 0
29° 93.6% 99.8% 99.8% 128.7% 0.31V 39.2% 2781 0
28° 93.6% 99.8% 99.8% 105.3% 0.55V 39.6% 2938 0
29° 93.6% 99.8% 99.8% 117.0% 0.68V 40.0% 3125 0
28° 93.6% 99.8% 99.8% 124.0% 0.41V 40.0% 3344 0
27° 93.6% 99.8% 99.8% 119.3% 0.20V 36.1% 3563 0
29° 93.6% 99.8% 99.8% 138.1% 0.43V 35.3% 3719 0
34° 93.6% 99.8% 99.8% 159.1% 0.84V 11.0% 3563 0
40° 93.6% 99.8% 99.8% 133.4% 0.47V 11.0% 3031 0
39° 93.6% 99.8% 99.8% 99.8% 0.76V 11.0% 2594 0
38° 93.6% 99.8% 99.8% 92.0% 0.64V 11.0% 2375 0
38° 93.6% 99.8% 99.8% 88.9% 0.64V 11.0% 2406 0
38° 93.6% 99.8% 99.8% 99.8% 0.76V 11.0% 2375 0
38° 93.6% 99.8% 99.8% 99.8% 0.62V 11.0% 2344 0
38° 93.6% 99.8% 99.8% 99.8% 0.64V 11.0% 2344 0
38° 93.6% 99.8% 99.8% 93.6% 0.57V 11.0% 2281 0
38° 93.6% 99.8% 99.8% 99.8% 0.72V 11.0% 2250 0
37° 93.6% 99.8% 99.8% 88.1% 0.62V 11.0% 2156 0
37° 93.6% 99.8% 99.8% 73.3% 0.66V 11.0% 2063 0
37° 93.6% 99.8% 99.8% 99.8% 0.68V 11.0% 2000 0
37° 93.6% 99.8% 99.8% 99.8% 0.66V 11.0% 2000 0
36° 93.6% 99.8% 99.8% 99.8% 0.59V 11.0% 1938 0
35° 93.6% 99.8% 99.8% 99.8% 0.25V 11.0% 1906 0
34° 93.6% 99.8% 99.8% 99.8% 0.10V 11.0% 1906 0
34° 93.6% 99.8% 99.8% 99.8% 0.06V 11.0% 1875 0
33° 93.6% 99.8% 99.8% 102.2% 0.04V 17.6% 1875 0
33° 93.6% 99.8% 99.8% 114.7% 0.68V 29.4% 1875 0
28° 93.6% 99.8% 99.8% 104.5% 0.31V 31.0% 1875 0
27° 93.6% 99.8% 99.8% 100.6% 0.47V 34.1% 1938 0
26° 93.6% 99.8% 99.8% 118.6% 0.10V 38.8% 1969 0
25° 93.6% 99.8% 99.8% 103.7% 0.78V 36.5% 2063 0
25° 93.6% 99.8% 99.8% 84.2% 0.55V 36.5% 2125 0
25° 93.6% 99.8% 99.8% 103.0% 0.21V 37.3% 2188 1
24° 93.6% 99.8% 99.8% 91.3% 0.68V 38.0% 2219 0
26° 93.6% 99.8% 99.8% 92.0% 0.08V 38.0% 2313 0
25° 93.6% 99.8% 99.8% 107.6% 0.76V 38.4% 2375 0
26° 93.6% 99.8% 99.8% 99.1% 0.14V 38.4% 2469 0
27° 93.6% 99.8% 99.8% 103.0% 0.70V 38.8% 2531 0
27° 93.6% 99.8% 99.8% 106.9% 0.06V 38.8% 2625 0
27° 93.6% 99.8% 99.8% 113.9% 0.76V 36.9% 2688 0
13° 93.6% 99.8% 99.8% 97.5% 0.55V 11.0% 2750 0
38° 93.6% 99.8% 99.8% 80.3% 0.82V 11.0% 2656 0
38° 93.6% 99.8% 99.8% 91.3% 0.64V 11.0% 2594 0
38° 93.6% 99.8% 99.8% 72.5% 0.72V 11.0% 2531 0
38° 93.6% 99.8% 99.8% 54.6% 0.59V 11.0% 2438 0
38° 93.6% 99.8% 99.8% 38.2% 0.72V 11.0% 2313 0
38° 93.6% 99.8% 99.8% 32.0% 0.72V 11.0% 2219 0
37° 93.6% 99.8% 99.8% 32.8% 0.70V 11.0% 2156 0
37° 93.6% 99.8% 99.8% 32.0% 0.62V 11.0% 2063 0
37° 93.6% 99.8% 99.8% 32.8% 0.74V 11.0% 2000 0
37° 93.6% 99.8% 99.8% 99.8% 0.60V 11.0% 1969 0
36° 93.6% 99.8% 99.8% 99.8% 0.33V 11.0% 1938 0
36° 93.6% 99.8% 99.8% 99.8% 0.37V 11.0% 1969 0
36° 93.6% 99.8% 99.8% 99.8% 0.27V 11.0% 1906 0
35° 93.6% 99.8% 99.8% 99.8% 0.62V 11.0% 1906 0
34° 93.6% 99.8% 99.8% 99.8% 0.23V 11.0% 1906 0
33° 93.6% 99.8% 99.8% 99.8% 0.14V 11.0% 1844 0
34° 93.6% 99.8% 99.8% 99.8% 0.04V 11.0% 1844 0
33° 93.6% 99.8% 99.8% 99.8% 0.04V 11.0% 1844 0
31° 93.6% 99.8% 99.8% 99.8% 0.02V 11.0% 1781 0
30° 93.6% 99.8% 99.8% 99.8% 0.04V 11.0% 1750 0
30° 93.6% 99.8% 99.8% 99.8% 0.02V 14.9% 1750 0
30° 93.6% 99.8% 99.8% 103.0% 0.80V 15.7% 1750 0
30° 93.6% 99.8% 99.8% 91.3% 0.86V 15.7% 1719 0
29° 93.6% 99.8% 99.8% 79.6% 0.84V 16.1% 1719 0
30° 93.6% 99.8% 99.8% 67.9% 0.37V 16.1% 1719 0
29° 93.6% 99.8% 99.8% 67.1% 0.53V 16.1% 1719 0
29° 93.6% 99.8% 99.8% 76.4% 0.02V 16.1% 1719 0
29° 93.6% 99.8% 99.8% 88.1% 0.02V 16.1% 1688 0
29° 93.6% 99.8% 99.8% 99.1% 0.04V 16.1% 1719 0
29° 93.6% 99.8% 99.8% 106.9% 0.72V 14.9% 1719 0
29° 93.6% 99.8% 99.8% 96.7% 0.82V 13.7% 1719 0
29° 93.6% 99.8% 99.8% 85.0% 0.80V 12.2% 1688 0
29° 93.6% 99.8% 99.8% 72.5% 0.74V 11.8% 1656 0
28° 93.6% 99.8% 99.8% 66.3% 0.16V 11.8% 1656 0
28° 93.6% 99.8% 99.8% 77.2% 0.02V 11.8% 1656 0
27° 93.6% 99.8% 99.8% 85.8% 0.74V 11.8% 1625 0
27° 93.6% 99.8% 99.8% 76.4% 0.84V 11.8% 1594 0
26° 93.6% 99.8% 99.8% 64.7% 0.62V 11.8% 1594 0
26° 93.6% 99.8% 99.8% 73.3% 0.02V 11.8% 1594 0
26° 93.6% 99.8% 99.8% 84.2% 0.12V 11.8% 1563 0
25° 93.6% 99.8% 99.8% 85.0% 0.82V 11.8% 1531 0
25° 93.6% 99.8% 99.8% 75.7% 0.80V 11.0% 1531 0
24° 93.6% 99.8% 99.8% 65.5% 0.82V 11.0% 1500 0
24° 92.8% 99.8% 99.8% 64.0% 0.12V 11.0% 1500 0
23° 92.8% 99.8% 99.8% 73.3% 0.02V 11.0% 1438 0
23° 92.8% 99.8% 99.8% 83.5% 0.02V 11.0% 1438 0
23° 92.8% 99.8% 99.8% 92.8% 0.43V 11.0% 1438 0
22° 92.0% 99.8% 99.8% 94.4% 0.72V 11.0% 1375 0
21° 92.0% 99.8% 99.8% 85.0% 0.70V 11.0% 1344 0
20° 92.0% 99.8% 99.8% 76.4% 0.64V 11.0% 1281 0
19° 92.0% 99.8% 99.8% 79.6% 0.04V 11.0% 1188 0
17° 92.0% 99.8% 99.8% 85.8% 0.06V 11.0% 1063 0
14° 91.3% 99.8% 99.8% 82.7% 0.62V 11.0% 875 0
10° 91.3% 99.8% 99.8% 77.2% 0.78V 11.0% 688 0
8° 91.3% 99.8% 99.8% 73.3% 0.76V 11.0% 594 0
8° 91.3% 99.8% 99.8% 69.4% 0.80V 11.0% 594 0
8° 90.5% 99.8% 99.8% 65.5% 0.53V 11.0% 656 0
8° 90.5% 99.8% 99.8% 67.1% 0.10V 11.0% 656 0
8° 90.5% 99.8% 99.8% 71.0% 0.02V 11.0% 656 0
8° 90.5% 99.8% 99.8% 74.1% 0.00V 11.0% 656 0
8° 89.7% 99.8% 99.8% 77.2% 0.00V 11.0% 656 0
8° 89.7% 99.8% 99.8% 81.1% 0.00V 11.0% 656 0
8° 89.7% 99.8% 99.8% 85.0% 0.00V 11.0% 688 0
8° 89.7% 99.8% 99.8% 88.9% 0.00V 11.0% 688 0
8° 89.7% 99.8% 99.8% 92.0% 0.00V 11.0% 719 0
8° 88.9% 99.8% 99.8% 95.9% 0.00V 11.0% 688 0
8° 88.9% 99.8% 99.8% 99.1% 0.00V 11.0% 688 0
8° 88.9% 99.8% 99.8% 100.6% 0.00V 11.0% 688 0
8° 88.9% 99.8% 99.8% 102.2% 0.02V 11.0% 688 0
8° 88.9% 99.8% 99.8% 103.7% 0.02V 11.0% 688 0
8° 89.7% 99.8% 99.8% 105.3% 0.02V 11.0% 688 0
8° 89.7% 99.8% 99.8% 106.9% 0.04V 11.0% 688 0
8° 89.7% 99.8% 99.8% 108.4% 0.02V 11.0% 688 0
8° 89.7% 99.8% 99.8% 110.8% 0.02V 11.0% 688 0
8° 89.7% 99.8% 99.8% 112.3% 0.06V 11.0% 688 0
8° 90.5% 99.8% 99.8% 113.9% 0.41V 11.0% 719 0
8° 90.5% 99.8% 99.8% 111.5% 0.47V 11.0% 688 0
8° 90.5% 99.8% 99.8% 110.0% 0.59V 11.0% 688 0
8° 90.5% 99.8% 99.8% 110.8% 0.33V 11.0% 719 0
8° 91.3% 99.8% 99.8% 111.5% 0.43V 11.0% 719 0
8° 91.3% 99.8% 99.8% 109.2% 0.66V 11.0% 719 0
8° 91.3% 99.8% 99.8% 106.9% 0.68V 11.0% 719 0
8° 91.3% 99.8% 99.8% 106.1% 0.25V 11.0% 719 0
8° 92.0% 99.8% 99.8% 107.6% 0.06V 11.0% 719 0
8° 92.0% 99.8% 99.8% 109.2% 0.00V 11.0% 688 0
8° 92.0% 99.8% 99.8% 111.5% 0.00V 11.0% 688 0
8° 92.0% 99.8% 99.8% 113.1% 0.00V 11.0% 719 0
8° 92.0% 99.8% 99.8% 114.7% 0.02V 11.0% 719 0
8° 92.8% 99.8% 99.8% 117.0% 0.04V 11.0% 688 0
8° 92.8% 99.8% 99.8% 117.8% 0.29V 11.0% 719 0
8° 92.8% 99.8% 99.8% 117.0% 0.68V 11.0% 719 0
8° 92.8% 99.8% 99.8% 113.9% 0.74V 11.0% 719 0
8° 93.6% 99.8% 99.8% 111.5% 0.66V 11.0% 688 0
8° 93.6% 99.8% 99.8% 108.4% 0.53V 11.0% 688 0
8° 93.6% 99.8% 99.8% 108.4% 0.62V 11.0% 656 0
8° 93.6% 99.8% 99.8% 108.4% 0.29V 11.0% 656 0
8° 93.6% 99.8% 99.8% 110.0% 0.08V 11.8% 656 0
8° 94.4% 99.8% 99.8% 111.5% 0.06V 22.0% 750 0
12° 94.4% 99.8% 99.8% 115.4% 0.00V 31.0% 1313 1
24° 94.4% 99.8% 99.8% 127.1% 0.04V 31.4% 1156 0
17° 94.4% 99.8% 99.8% 137.3% 0.04V 32.2% 875 0
11° 94.4% 99.8% 99.8% 145.9% 0.41V 38.8% 1250 0
22° 94.4% 99.8% 99.8% 156.0% 0.59V 28.2% 1563 0
27° 94.4% 99.8% 99.8% 141.2% 0.84V 27.1% 1813 0
29° 94.4% 99.8% 99.8% 122.5% 0.70V 27.8% 2094 0
29° 94.4% 99.8% 99.8% 118.6% 0.10V 34.9% 2344 0
29° 94.4% 99.8% 99.8% 126.4% 0.80V 40.8% 2719 0
29° 94.4% 99.8% 99.8% 98.3% 0.64V 42.0% 3063 0
29° 94.4% 99.8% 99.8% 106.1% 0.43V 40.4% 3500 0
29° 94.4% 99.8% 99.8% 87.4% 0.14V 36.9% 3813 0
30° 94.4% 99.8% 99.8% 99.8% 0.80V 11.4% 4156 0
41° 94.4% 99.8% 99.8% 78.0% 0.57V 11.0% 3531 0
40° 94.4% 99.8% 99.8% 99.8% 0.74V 15.7% 3125 0
39° 94.4% 99.8% 99.8% 100.6% 0.06V 25.1% 2531 0
33° 94.4% 99.8% 99.8% 126.4% 0.02V 31.8% 2563 0
30° 94.4% 99.8% 99.8% 133.4% 0.80V 31.8% 2781 0
32° 94.4% 99.8% 99.8% 103.7% 0.55V 31.8% 2844 0
32° 94.4% 99.8% 99.8% 130.3% 0.10V 32.2% 2938 0
33° 94.4% 99.8% 99.8% 116.2% 0.68V 11.0% 3031 0
39° 94.4% 99.8% 99.8% 99.8% 0.90V 11.0% 2750 0
38° 94.4% 99.8% 99.8% 94.4% 0.53V 11.0% 2344 0
37° 94.4% 99.8% 99.8% 78.8% 0.80V 11.0% 1969 0
37° 94.4% 99.8% 99.8% 65.5% 0.74V 11.0% 1969 0
36° 94.4% 99.8% 99.8% 51.5% 0.49V 11.0% 1969 0
35° 94.4% 99.8% 99.8% 64.7% 0.18V 11.0% 1938 0
35° 94.4% 99.8% 99.8% 77.2% 0.35V 11.0% 1906 0
34° 94.4% 99.8% 99.8% 90.5% 0.20V 11.8% 1875 0
34° 94.4% 99.8% 99.8% 104.5% 0.12V 15.7% 1875 0
34° 94.4% 99.8% 99.8% 107.6% 0.82V 15.7% 1844 0
33° 94.4% 99.8% 99.8% 95.2% 0.84V 14.1% 1844 0
32° 94.4% 99.8% 99.8% 82.7% 0.76V 12.5% 1844 0
32° 94.4% 99.8% 99.8% 71.0% 0.39V 20.0% 1813 0
32° 94.4% 99.8% 99.8% 84.2% 0.02V 20.0% 1844 0
31° 94.4% 99.8% 99.8% 97.5% 0.06V 20.4% 1813 0
31° 94.4% 99.8% 99.8% 93.6% 0.78V 12.9% 1813 0
33° 94.4% 99.8% 99.8% 80.3% 0.86V 12.5% 1781 0
32° 94.4% 99.8% 99.8% 71.0% 0.23V 12.5% 1813 0
32° 94.4% 99.8% 99.8% 82.7% 0.59V 16.5% 1813 0
31° 94.4% 99.8% 99.8% 85.8% 0.02V 16.9% 1813 0
29° 94.4% 99.8% 99.8% 98.3% 0.00V 27.1% 1781 0
26° 94.4% 99.8% 99.8% 116.2% 0.27V 49.0% 1844 0
23° 94.4% 99.8% 99.8% 124.0% 0.76V 49.4% 1938 0
23° 94.4% 99.8% 99.8% 105.3% 0.78V 49.4% 1969 0
23° 94.4% 99.8% 99.8% 88.9% 0.41V 49.4% 2031 0
22° 94.4% 99.8% 99.8% 110.8% 0.37V 37.3% 2094 1
26° 94.4% 99.8% 99.8% 93.6% 0.84V 17.3% 2156 0
35° 94.4% 99.8% 99.8% 74.9% 0.92V 11.0% 2156 0
37° 94.4% 99.8% 99.8% 99.8% 0.47V 11.0% 2125 0
37° 94.4% 99.8% 99.8% 99.8% 0.06V 11.0% 2094 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2063 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2031 0
37° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 1938 0
36° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 1875 0
34° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 1844 0
32° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1781 0
32° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 1781 0
31° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 1781 0
30° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 1750 0
30° 94.4% 99.8% 99.8% 99.8% 0.06V 11.0% 1750 0
29° 94.4% 99.8% 99.8% 99.8% 0.70V 11.4% 1688 0
29° 94.4% 99.8% 99.8% 95.9% 0.78V 12.2% 1719 0
29° 94.4% 99.8% 99.8% 84.2% 0.78V 14.1% 1688 0
28° 94.4% 99.8% 99.8% 75.7% 0.53V 14.5% 1688 0
28° 94.4% 99.8% 99.8% 81.9% 0.12V 14.9% 1656 0
28° 94.4% 99.8% 99.8% 93.6% 0.08V 14.9% 1625 0
27° 94.4% 99.8% 99.8% 106.1% 0.14V 14.9% 1656 0
27° 94.4% 99.8% 99.8% 100.6% 0.82V 14.9% 1625 0
27° 94.4% 99.8% 99.8% 89.7% 0.35V 15.3% 1625 0
27° 94.4% 99.8% 99.8% 100.6% 0.06V 15.3% 1594 0
27° 94.4% 99.8% 99.8% 110.8% 0.25V 15.3% 1594 0
27° 94.4% 99.8% 99.8% 102.2% 0.78V 15.3% 1594 0
26° 94.4% 99.8% 99.8% 92.0% 0.59V 15.3% 1594 0
26° 94.4% 99.8% 99.8% 97.5% 0.06V 15.7% 1594 0
26° 94.4% 99.8% 99.8% 108.4% 0.04V 16.9% 1594 0
27° 94.4% 99.8% 99.8% 118.6% 0.02V 19.2% 1594 0
28° 94.4% 99.8% 99.8% 129.5% 0.64V 19.2% 1594 0
27° 94.4% 99.8% 99.8% 117.8% 0.90V 12.9% 1594 0
26° 94.4% 99.8% 99.8% 106.9% 0.84V 12.9% 1594 0
27° 94.4% 99.8% 99.8% 97.5% 0.39V 13.7% 1594 0
26° 94.4% 99.8% 99.8% 108.4% 0.06V 13.7% 1563 0
26° 94.4% 99.8% 99.8% 109.2% 0.84V 13.7% 1563 0
26° 94.4% 99.8% 99.8% 97.5% 0.74V 13.7% 1531 0
25° 94.4% 99.8% 99.8% 93.6% 0.16V 13.7% 1531 0
25° 94.4% 99.8% 99.8% 103.0% 0.06V 13.7% 1531 0
24° 94.4% 99.8% 99.8% 103.7% 0.84V 11.0% 1531 0
24° 94.4% 99.8% 99.8% 93.6% 0.90V 11.0% 1500 0
24° 94.4% 99.8% 99.8% 83.5% 0.88V 11.0% 1500 0
24° 94.4% 99.8% 99.8% 72.5% 0.84V 11.0% 1469 0
23° 94.4% 99.8% 99.8% 64.0% 0.76V 11.0% 1469 0
22° 94.4% 99.8% 99.8% 67.1% 0.10V 11.0% 1438 0
23° 94.4% 99.8% 99.8% 76.4% 0.02V 11.0% 1406 0
22° 94.4% 99.8% 99.8% 85.8% 0.02V 11.4% 1375 0
21° 94.4% 99.8% 99.8% 95.2% 0.14V 11.8% 1375 0
21° 94.4% 99.8% 99.8% 88.9% 0.70V 12.2% 1375 0
20° 94.4% 99.8% 99.8% 81.1% 0.72V 14.1% 1344 0
20° 94.4% 99.8% 99.8% 78.0% 0.04V 17.3% 1375 0
20° 94.4% 99.8% 99.8% 85.8% 0.00V 17.3% 1313 0
22° 94.4% 99.8% 99.8% 93.6% 0.00V 17.6% 1344 0
22° 94.4% 99.8% 99.8% 101.4% 0.00V 17.6% 1344 0
22° 94.4% 99.8% 99.8% 109.2% 0.02V 17.6% 1344 0
22° 94.4% 99.8% 99.8% 116.2% 0.02V 17.6% 1344 0
22° 94.4% 99.8% 99.8% 124.0% 0.02V 18.0% 1344 0
23° 94.4% 99.8% 99.8% 131.8% 0.41V 18.4% 1344 0
23° 94.4% 99.8% 99.8% 124.8% 0.62V 18.4% 1344 0
23° 94.4% 99.8% 99.8% 127.9% 0.16V 18.8% 1344 0
23° 94.4% 99.8% 99.8% 136.5% 0.20V 30.2% 1375 0
24° 94.4% 99.8% 99.8% 148.2% 0.25V 43.1% 1406 0
23° 94.4% 99.8% 99.8% 99.8% 0.88V 46.3% 1469 0
23° 94.4% 99.8% 99.8% 99.8% 0.88V 46.3% 1563 0
23° 94.4% 99.8% 99.8% 99.8% 0.88V 46.3% 1625 0
22° 94.4% 99.8% 99.8% 99.8% 0.86V 46.3% 1656 0
22° 94.4% 99.8% 99.8% 99.8% 0.86V 46.3% 1750 0
21° 94.4% 99.8% 99.8% 99.8% 0.86V 46.3% 1844 0
21° 94.4% 99.8% 99.8% 85.8% 0.53V 46.3% 1875 0
21° 94.4% 99.8% 99.8% 101.4% 0.08V 46.3% 1938 0
22° 94.4% 99.8% 99.8% 117.0% 0.72V 46.3% 2031 0
22° 94.4% 99.8% 99.8% 97.5% 0.53V 46.7% 2125 0
23° 94.4% 99.8% 99.8% 115.4% 0.70V 46.7% 2219 0
23° 94.4% 99.8% 99.8% 105.3% 0.23V 46.7% 2281 0
23° 94.4% 99.8% 99.8% 106.9% 0.66V 46.7% 2375 0
24° 94.4% 99.8% 99.8% 120.9% 0.14V 46.7% 2500 0
23° 94.4% 99.8% 99.8% 110.0% 0.60V 46.7% 2563 0
23° 94.4% 99.8% 99.8% 126.4% 0.23V 46.7% 2688 0
22° 94.4% 99.8% 99.8% 108.4% 0.57V 46.7% 2781 0
22° 94.4% 99.8% 99.8% 99.8% 0.86V 46.7% 2906 0
22° 94.4% 99.8% 99.8% 99.8% 0.86V 46.7% 3063 0
22° 94.4% 99.8% 99.8% 99.8% 0.86V 36.1% 3156 4
25° 94.4% 99.8% 99.8% 99.8% 0.62V 23.5% 3250 4
16° 94.4% 99.8% 99.8% 93.6% 0.64V 11.0% 3063 0
39° 94.4% 99.8% 99.8% 99.8% 0.59V 11.0% 3094 0
39° 94.4% 99.8% 99.8% 99.8% 0.70V 11.0% 3000 0
39° 94.4% 99.8% 99.8% 99.8% 0.68V 11.0% 2844 0
39° 94.4% 99.8% 99.8% 99.8% 0.72V 11.0% 2719 0
38° 94.4% 99.8% 99.8% 99.8% 0.72V 11.0% 2563 0
38° 94.4% 99.8% 99.8% 99.8% 0.68V 11.0% 2438 0
38° 94.4% 99.8% 99.8% 99.8% 0.68V 11.0% 2344 0
38° 94.4% 99.8% 99.8% 99.8% 0.66V 11.0% 2219 0
38° 94.4% 99.8% 99.8% 99.8% 0.72V 11.0% 2156 0
37° 94.4% 99.8% 99.8% 99.8% 0.70V 11.0% 2094 0
37° 94.4% 99.8% 99.8% 99.8% 0.74V 11.0% 2031 0
37° 94.4% 99.8% 99.8% 99.8% 0.57V 11.0% 2031 0
37° 94.4% 99.8% 99.8% 99.8% 0.35V 11.0% 2000 0
37° 94.4% 99.8% 99.8% 99.8% 0.76V 11.0% 2000 0
23° 94.4% 99.8% 99.8% 99.8% 0.10V 11.0% 1969 0
23° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1938 0
21° 94.4% 99.8% 99.8% 99.8% 0.00V 13.3% 1906 0
23° 94.4% 99.8% 99.8% 109.2% 0.00V 13.7% 1844 0
33° 94.4% 99.8% 99.8% 117.0% 0.74V 13.7% 1844 0
33° 94.4% 99.8% 99.8% 104.5% 0.82V 14.1% 1844 0
34° 94.4% 99.8% 99.8% 90.5% 0.76V 12.2% 1844 0
32° 94.4% 99.8% 99.8% 92.8% 0.04V 11.0% 1813 0
32° 94.4% 99.8% 99.8% 105.3% 0.04V 11.0% 1813 0
31° 94.4% 99.8% 99.8% 117.0% 0.04V 11.0% 1813 0
31° 94.4% 99.8% 99.8% 114.7% 0.64V 11.0% 1781 0
30° 94.4% 99.8% 99.8% 102.2% 0.70V 11.0% 1781 0
30° 94.4% 99.8% 99.8% 102.2% 0.20V 11.0% 1750 0
30° 94.4% 99.8% 99.8% 97.5% 0.80V 11.0% 1719 0
29° 94.4% 99.8% 99.8% 88.9% 0.25V 11.0% 1719 0
29° 94.4% 99.8% 99.8% 99.8% 0.08V 11.0% 1688 0
28° 94.4% 99.8% 99.8% 111.5% 0.33V 11.0% 1656 0
28° 94.4% 99.8% 99.8% 103.0% 0.72V 11.0% 1656 0
28° 94.4% 99.8% 99.8% 92.8% 0.55V 11.0% 1656 0
27° 94.4% 99.8% 99.8% 100.6% 0.16V 11.0% 1625 0
27° 94.4% 99.8% 99.8% 112.3% 0.55V 11.0% 1625 0
27° 94.4% 99.8% 99.8% 102.2% 0.80V 11.0% 1594 0
26° 94.4% 99.8% 99.8% 90.5% 0.59V 11.0% 1563 0
26° 94.4% 99.8% 99.8% 97.5% 0.08V 11.0% 1531 0
24° 94.4% 99.8% 99.8% 102.2% 0.60V 11.0% 1438 0
23° 94.4% 99.8% 99.8% 110.8% 0.59V 11.0% 1406 0
21° 94.4% 99.8% 99.8% 102.2% 0.82V 11.0% 1313 0
19° 94.4% 99.8% 99.8% 95.2% 0.84V 11.0% 1219 0
17° 94.4% 99.8% 99.8% 87.4% 0.82V 11.0% 1156 0
16° 94.4% 99.8% 99.8% 81.1% 0.43V 11.0% 1125 0
16° 94.4% 99.8% 99.8% 88.9% 0.08V 11.0% 1125 0
16° 94.4% 99.8% 99.8% 88.9% 0.82V 11.0% 1125 0
15° 94.4% 99.8% 99.8% 81.9% 0.78V 14.1% 1094 0
15° 94.4% 99.8% 99.8% 82.7% 0.06V 14.1% 1125 0
15° 94.4% 99.8% 99.8% 89.7% 0.00V 15.3% 1125 0
17° 94.4% 99.8% 99.8% 96.7% 0.00V 20.4% 1125 0
19° 94.4% 99.8% 99.8% 105.3% 0.00V 24.7% 1063 0
21° 94.4% 99.8% 99.8% 114.7% 0.00V 26.7% 1156 0
20° 94.4% 99.8% 99.8% 124.0% 0.00V 36.1% 1188 0
20° 94.4% 99.8% 99.8% 134.2% 0.02V 31.8% 1219 3
22° 94.4% 99.8% 99.8% 145.1% 0.43V 31.8% 1281 3
22° 94.4% 99.8% 99.8% 138.1% 0.60V 32.2% 1313 2
23° 94.4% 99.8% 99.8% 139.6% 0.21V 32.2% 1375 2
23° 94.4% 99.8% 99.8% 131.8% 0.66V 32.5% 1406 1
23° 94.4% 99.8% 99.8% 130.3% 0.31V 32.5% 1469 0
25° 94.4% 99.8% 99.8% 128.7% 0.70V 32.5% 1531 0
25° 94.4% 99.8% 99.8% 127.1% 0.18V 32.5% 1594 0
25° 94.4% 99.8% 99.8% 134.2% 0.72V 32.9% 1625 0
25° 94.4% 99.8% 99.8% 120.9% 0.33V 32.9% 1688 0
24° 94.4% 99.8% 99.8% 134.2% 0.68V 32.9% 1750 0
25° 94.4% 99.8% 99.8% 117.0% 0.74V 28.2% 1781 0
27° 94.4% 99.8% 99.8% 115.4% 0.08V 28.6% 1844 0
27° 94.4% 99.8% 99.8% 134.2% 0.51V 28.6% 1906 0
27° 94.4% 99.8% 99.8% 117.0% 0.80V 36.1% 1969 0
24° 94.4% 99.8% 99.8% 123.2% 0.06V 39.2% 2031 0
23° 94.4% 99.8% 99.8% 119.3% 0.80V 39.2% 2063 0
24° 94.4% 99.8% 99.8% 99.1% 0.57V 39.6% 2156 1
23° 94.4% 99.8% 99.8% 115.4% 0.70V 28.2% 2219 0
29° 94.4% 99.8% 99.8% 96.7% 0.88V 19.2% 2250 0
34° 94.4% 99.8% 99.8% 77.2% 0.90V 16.1% 2250 0
37° 94.4% 99.8% 99.8% 75.7% 0.04V 11.0% 2219 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2219 0
37° 94.4% 99.8% 99.8% 99.8% 0.33V 11.0% 2188 0
37° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 2188 0
37° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 2125 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2125 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2094 0
37° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 2031 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 2000 0
37° 94.4% 99.8% 99.8% 99.8% 0.02V 11.0% 1969 0
37° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1969 0
35° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1906 0
34° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1875 0
33° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1813 0
31° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1719 0
16° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1656 0
14° 94.4% 99.8% 99.8% 99.8% 0.00V 11.0% 1500 0
10° 94.4% 99.8% 99.8% 103.7% 0.00V 11.0% 1156 0
15° 94.4% 99.8% 99.8% 110.0% 0.00V 11.0% 938 0
11° 94.4% 99.8% 99.8% 115.4% 0.02V 11.0% 750 0
8° 94.4% 99.8% 99.8% 117.0% 0.70V 11.0% 625 0
8° 94.4% 99.8% 99.8% 113.9% 0.80V 11.0% 594 0
8° 94.4% 99.8% 99.8% 110.0% 0.82V 11.0% 656 0
8° 94.4% 99.8% 99.8% 106.1% 0.80V 11.0% 688 0
8° 94.4% 99.8% 99.8% 100.6% 0.78V 11.0% 719 0
8° 94.4% 99.8% 99.8% 97.5% 0.70V 11.0% 719 0
8° 94.4% 99.8% 99.8% 96.7% 0.16V 11.0% 656 0
8° 94.4% 99.8% 99.8% 99.8% 0.04V 11.0% 656 0
8° 94.4% 99.8% 99.8% 103.0% 0.02V 11.0% 688 0
8° 94.4% 99.8% 99.8% 106.9% 0.02V 11.0% 719 0
8° 94.4% 99.8% 99.8% 110.8% 0.06V 11.0% 719 0
8° 94.4% 99.8% 99.8% 114.7% 0.16V 11.0% 719 0
8° 94.4% 99.8% 99.8% 118.6% 0.18V 11.0% 688 0
8° 94.4% 99.8% 99.8% 119.3% 0.53V 11.0% 688 0
8° 94.4% 99.8% 99.8% 116.2% 0.74V 11.0% 688 0
8° 94.4% 99.8% 99.8% 113.9% 0.72V 11.0% 719 0
8° 95.2% 99.8% 99.8% 111.5% 0.59V 11.0% 688 0
8° 95.2% 99.8% 99.8% 109.2% 0.53V 11.0% 688 0
8° 95.2% 99.8% 99.8% 108.4% 0.59V 11.0% 719 0
8° 95.2% 99.8% 99.8% 108.4% 0.16V 11.0% 688 0
8° 95.2% 99.8% 99.8% 110.8% 0.08V 11.0% 750 0
8° 95.9% 99.8% 99.8% 111.5% 0.59V 11.0% 750 0
8° 95.9% 99.8% 99.8% 109.2% 0.70V 11.0% 750 0
8° 95.9% 99.8% 99.8% 106.1% 0.60V 11.0% 719 0
8° 95.9% 99.8% 99.8% 103.7% 0.43V 11.0% 750 0
8° 96.7% 99.8% 99.8% 103.0% 0.47V 11.0% 750 0
8° 96.7% 99.8% 99.8% 100.6% 0.68V 11.0% 781 0
8° 96.7% 99.8% 99.8% 100.6% 0.25V 11.0% 781 0
9° 96.7% 99.8% 99.8% 103.0% 0.14V 11.0% 781 0
9° 96.7% 99.8% 99.8% 104.5% 0.14V 11.0% 781 0
9° 97.5% 99.8% 99.8% 106.1% 0.20V 11.0% 781 0
9° 97.5% 99.8% 99.8% 106.9% 0.74V 11.0% 813 0
9° 97.5% 99.8% 99.8% 103.7% 0.78V 11.0% 813 0
9° 97.5% 99.8% 99.8% 100.6% 0.68V 11.0% 781 0
8° 97.5% 99.8% 99.8% 97.5% 0.47V 11.0% 750 0
8° 97.5% 99.8% 99.8% 99.1% 0.12V 14.5% 719 0
8° 97.5% 99.8% 99.8% 100.6% 0.04V 14.9% 719 0
8° 97.5% 99.8% 99.8% 103.0% 0.02V 16.1% 750 0
8° 97.5% 99.8% 99.8% 105.3% 0.00V 16.9% 844 0
12° 97.5% 99.8% 99.8% 107.6% 0.00V 16.9% 969 0
15° 97.5% 99.8% 99.8% 110.0% 0.00V 17.3% 1031 0
14° 97.5% 99.8% 99.8% 112.3% 0.00V 17.3% 781 0
8° 97.5% 99.8% 99.8% 114.7% 0.00V 11.0% 719 0
8° 97.5% 99.8% 99.8% 116.2% 0.04V 11.0% 969 0
13° 97.5% 99.8% 99.8% 115.4% 0.31V 11.0% 1125 0
16° 97.5% 99.8% 99.8% 121.7% 0.02V 11.0% 1125 0
15° 97.5% 99.8% 99.8% 127.9% 0.00V 11.0% 1000 0
12° 97.5% 99.8% 99.8% 133.4% 0.00V 11.0% 906 0
11° 97.5% 99.8% 99.8% 135.7% 0.72V 11.0% 813 0
9° 97.5% 99.8% 99.8% 131.8% 0.84V 11.0% 719 0
8° 97.5% 99.8% 99.8% 126.4% 0.86V 11.0% 688 0
8° 97.5% 99.8% 99.8% 122.5% 0.88V 11.0% 656 0
8° 97.5% 99.8% 99.8% 118.6% 0.88V 11.0% 750 0
8° 97.5% 99.8% 99.8% 113.9% 0.88V 11.0% 781 0
9° 97.5% 99.8% 99.8% 109.2% 0.86V 11.0% 813 0
10° 97.5% 99.8% 99.8% 103.7% 0.84V 11.0% 844 0
10° 97.5% 99.8% 99.8% 99.1% 0.76V 11.0% 781 0
9° 97.5% 99.8% 99.8% 95.9% 0.39V 11.0% 750 0
8° 97.5% 99.8% 99.8% 99.8% 0.16V 11.0% 688 0
8° 97.5% 99.8% 99.8% 103.7% 0.18V 11.0% 656 0
8° 97.5% 99.8% 99.8% 106.1% 0.76V 11.0% 656 0
8° 97.5% 99.8% 99.8% 103.7% 0.82V 11.0% 688 0
8° 97.5% 99.8% 99.8% 101.4% 0.82V 11.0% 688 0
8° 98.3% 99.8% 99.8% 98.3% 0.78V 11.0% 688 0
8° 97.5% 99.8% 99.8% 96.7% 0.33V 11.0% 688 0
8° 97.5% 99.8% 99.8% 98.3% 0.14V 11.0% 656 0
8° 97.5% 99.8% 99.8% 99.8% 0.10V 11.0% 688 0
8° 97.5% 99.8% 99.8% 101.4% 0.08V 11.0% 688 0
8° 97.5% 99.8% 99.8% 102.2% 0.64V 11.0% 719 0
8° 97.5% 99.8% 99.8% 99.8% 0.74V 11.0% 719 0
8° 97.5% 99.8% 99.8% 97.5% 0.47V 11.0% 688 0
8° 97.5% 99.8% 99.8% 96.7% 0.12V 11.0% 688 0
8° 97.5% 99.8% 99.8% 99.1% 0.06V 11.0% 688 0
8° 97.5% 99.8% 99.8% 100.6% 0.06V 11.0% 688 0
8° 97.5% 99.8% 99.8% 102.2% 0.47V 11.0% 688 0
8° 97.5% 99.8% 99.8% 99.8% 0.66V 11.0% 688 0
8° 97.5% 99.8% 99.8% 97.5% 0.60V 11.0% 688 0
8° 97.5% 99.8% 99.8% 95.9% 0.29V 11.0% 656 0
8° 97.5% 99.8% 99.8% 97.5% 0.04V 11.0% 656 0
8° 96.7% 99.8% 99.8% 99.1% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 100.6% 0.06V 11.0% 688 0
8° 97.5% 99.8% 99.8% 103.0% 0.10V 11.0% 688 0
8° 97.5% 99.8% 99.8% 102.2% 0.68V 11.0% 750 0
8° 97.5% 99.8% 99.8% 99.8% 0.70V 18.8% 781 0
9° 97.5% 99.8% 99.8% 99.8% 0.00V 19.6% 1031 0
20° 97.5% 99.8% 99.8% 107.6% 0.00V 24.3% 1406 0
28° 97.5% 99.8% 99.8% 121.7% 0.00V 24.7% 1469 0
25° 97.5% 99.8% 99.8% 133.4% 0.02V 24.7% 1031 0
15° 97.5% 99.8% 99.8% 142.0% 0.08V 25.1% 969 0
20° 97.5% 99.8% 99.8% 143.5% 0.74V 25.1% 1219 0
24° 97.5% 99.8% 99.8% 142.7% 0.55V 25.5% 1500 0
27° 97.5% 99.8% 99.8% 128.7% 0.70V 25.5% 1781 0
29° 97.5% 99.8% 99.8% 117.0% 0.20V 25.5% 2000 0
31° 97.5% 99.8% 99.8% 116.2% 0.72V 25.5% 2156 1
31° 97.5% 99.8% 99.8% 117.8% 0.10V 26.7% 2375 1
29° 97.5% 99.8% 99.8% 119.3% 0.41V 36.9% 2656 0
30° 97.5% 99.8% 99.8% 112.3% 0.78V 36.9% 3063 0
31° 97.5% 99.8% 99.8% 107.6% 0.12V 34.9% 3469 0
34° 97.5% 99.8% 99.8% 99.1% 0.60V 22.4% 3563 0
38° 97.5% 99.8% 99.8% 96.7% 0.82V 11.0% 3500 0
40° 97.5% 99.8% 99.8% 99.8% 0.82V 11.0% 3125 0
39° 97.5% 99.8% 99.8% 99.8% 0.68V 11.0% 2719 0
38° 97.5% 99.8% 99.8% 99.8% 0.68V 11.0% 2250 0
37° 97.5% 99.8% 99.8% 99.8% 0.57V 11.0% 2125 0
37° 97.5% 99.8% 99.8% 99.8% 0.68V 11.0% 2125 0
37° 97.5% 99.8% 99.8% 99.8% 0.57V 11.0% 2094 0
37° 97.5% 99.8% 99.8% 99.8% 0.72V 11.0% 2094 0
37° 97.5% 99.8% 99.8% 99.8% 0.70V 16.1% 2000 0
37° 97.5% 99.8% 99.8% 89.7% 0.80V 22.4% 2031 0
33° 97.5% 99.8% 99.8% 74.1% 0.66V 32.5% 2125 0
28° 97.5% 99.8% 99.8% 95.2% 0.04V 36.5% 2250 1
28° 97.5% 99.8% 99.8% 113.9% 0.72V 39.6% 2438 0
28° 97.5% 99.8% 99.8% 120.1% 0.76V 40.4% 2594 0
28° 97.5% 99.8% 99.8% 99.1% 0.31V 42.0% 2719 0
28° 97.5% 99.8% 99.8% 115.4% 0.76V 42.0% 2906 0
27° 97.5% 99.8% 99.8% 110.8% 0.08V 42.4% 3125 0
27° 97.5% 99.8% 99.8% 120.1% 0.70V 42.4% 3313 0
26° 97.5% 99.8% 99.8% 99.8% 0.86V 42.4% 3625 0
25° 97.5% 99.8% 99.8% 99.8% 0.86V 42.7% 3938 0
26° 97.5% 99.8% 99.8% 99.8% 0.86V 36.5% 4125 0
30° 97.5% 99.8% 99.8% 99.8% 0.23V 17.6% 4375 0
42° 97.5% 99.8% 99.8% 84.2% 0.74V 11.0% 3844 0
40° 97.5% 99.8% 99.8% 53.0% 0.86V 26.7% 3094 0
35° 97.5% 99.8% 99.8% 53.0% 0.74V 49.0% 2875 0
27° 97.5% 99.8% 99.8% 99.8% 0.76V 54.1% 3000 0
25° 97.5% 99.8% 99.8% 99.8% 0.88V 54.5% 3125 0
23° 97.5% 99.8% 99.8% 99.8% 0.88V 54.5% 3281 0
24° 97.5% 99.8% 99.8% 90.5% 0.94V 11.0% 3375 0
40° 97.5% 99.8% 99.8% 64.7% 0.76V 13.3% 3000 0
39° 97.5% 99.8% 99.8% 42.9% 0.70V 18.0% 2406 0
37° 97.5% 99.8% 99.8% 54.6% 0.02V 21.6% 2406 0
36° 97.5% 99.8% 99.8% 45.2% 0.94V 11.0% 2344 0
38° 97.5% 99.8% 99.8% 32.0% 0.84V 11.0% 2313 0
38° 97.5% 99.8% 99.8% 32.8% 0.82V 11.0% 2281 0
38° 97.5% 99.8% 99.8% 32.0% 0.76V 11.0% 2281 0
38° 97.5% 99.8% 99.8% 32.0% 0.84V 11.0% 2188 0
37° 97.5% 99.8% 99.8% 32.0% 0.72V 11.0% 2125 0
37° 97.5% 99.8% 99.8% 32.0% 0.78V 11.0% 2000 0
37° 97.5% 99.8% 99.8% 32.0% 0.86V 11.0% 1969 0
36° 97.5% 99.8% 99.8% 32.0% 0.78V 11.0% 1906 0
35° 97.5% 99.8% 99.8% 32.0% 0.78V 11.0% 1938 0
34° 97.5% 99.8% 99.8% 32.0% 0.86V 11.0% 1906 0
34° 97.5% 99.8% 99.8% 32.8% 0.80V 11.0% 1875 0
33° 97.5% 99.8% 99.8% 32.8% 0.80V 11.0% 1813 0
32° 97.5% 99.8% 99.8% 32.8% 0.86V 11.0% 1781 0
30° 97.5% 99.8% 99.8% 32.0% 0.84V 11.0% 1719 0
29° 97.5% 99.8% 99.8% 32.8% 0.86V 11.0% 1688 0
29° 97.5% 99.8% 99.8% 32.0% 0.57V 11.0% 1656 0
27° 97.5% 99.8% 99.8% 40.6% 0.04V 11.0% 1656 0
27° 97.5% 99.8% 99.8% 51.5% 0.00V 11.0% 1625 0
27° 97.5% 99.8% 99.8% 61.6% 0.00V 11.0% 1594 0
26° 97.5% 99.8% 99.8% 72.5% 0.02V 11.0% 1531 0
24° 97.5% 99.8% 99.8% 78.8% 0.74V 11.0% 1438 0
23° 97.5% 99.8% 99.8% 69.4% 0.68V 11.0% 1375 0
21° 97.5% 99.8% 99.8% 71.8% 0.20V 11.0% 1313 0
18° 97.5% 99.8% 99.8% 78.8% 0.31V 11.0% 1219 0
17° 97.5% 99.8% 99.8% 74.9% 0.82V 11.0% 1063 0
13° 97.5% 99.8% 99.8% 68.6% 0.72V 11.0% 781 0
8° 97.5% 99.8% 99.8% 69.4% 0.06V 11.0% 656 0
8° 97.5% 99.8% 99.8% 73.3% 0.02V 11.0% 938 0
14° 97.5% 99.8% 99.8% 75.7% 0.80V 11.0% 1219 0
16° 97.5% 99.8% 99.8% 67.9% 0.64V 11.0% 1188 0
16° 97.5% 99.8% 99.8% 73.3% 0.04V 11.0% 1125 0
16° 97.5% 99.8% 99.8% 79.6% 0.04V 11.0% 1125 0
16° 97.5% 99.8% 99.8% 85.0% 0.10V 11.0% 1125 0
15° 97.5% 99.8% 99.8% 83.5% 0.82V 11.0% 1063 0
15° 97.5% 99.8% 99.8% 76.4% 0.80V 11.0% 1063 0
14° 97.5% 99.8% 99.8% 73.3% 0.16V 14.5% 1063 0
15° 97.5% 99.8% 99.8% 80.3% 0.06V 15.7% 1094 0
15° 97.5% 99.8% 99.8% 86.6% 0.04V 16.5% 1031 0
16° 97.5% 99.8% 99.8% 92.0% 0.02V 18.8% 1063 0
17° 97.5% 99.8% 99.8% 101.4% 0.02V 20.8% 1063 0
18° 97.5% 99.8% 99.8% 110.8% 0.02V 21.6% 1063 0
19° 97.5% 99.8% 99.8% 119.3% 0.04V 22.4% 1094 0
19° 97.5% 99.8% 99.8% 130.3% 0.55V 23.1% 1125 0
20° 97.5% 99.8% 99.8% 120.1% 0.74V 23.1% 1156 0
22° 97.5% 99.8% 99.8% 110.8% 0.41V 23.1% 1188 0
23° 97.5% 99.8% 99.8% 112.3% 0.78V 23.5% 1250 0
24° 97.5% 99.8% 99.8% 101.4% 0.80V 23.5% 1250 0
24° 97.5% 99.8% 99.8% 90.5% 0.62V 19.6% 1313 0
25° 97.5% 99.8% 99.8% 86.6% 0.10V 18.0% 1313 0
23° 97.5% 99.8% 99.8% 98.3% 0.02V 17.3% 1344 0
23° 97.5% 99.8% 99.8% 106.1% 0.47V 11.8% 1344 0
20° 97.5% 99.8% 99.8% 97.5% 0.84V 11.8% 1344 0
20° 97.5% 99.8% 99.8% 88.9% 0.62V 11.4% 1344 0
19° 97.5% 99.8% 99.8% 87.4% 0.20V 11.0% 1313 0
20° 97.5% 99.8% 99.8% 94.4% 0.60V 11.0% 1281 0
19° 97.5% 99.8% 99.8% 87.4% 0.78V 11.0% 1281 0
18° 97.5% 99.8% 99.8% 78.8% 0.82V 11.0% 1250 0
18° 97.5% 99.8% 99.8% 71.8% 0.84V 11.0% 1219 0
18° 97.5% 99.8% 99.8% 64.7% 0.82V 11.0% 1188 0
16° 97.5% 99.8% 99.8% 57.7% 0.60V 11.0% 1125 0
16° 97.5% 99.8% 99.8% 60.1% 0.10V 11.0% 1063 0
14° 97.5% 99.8% 99.8% 66.3% 0.04V 11.0% 969 0
12° 97.5% 99.8% 99.8% 71.8% 0.06V 11.0% 875 0
10° 97.5% 99.8% 99.8% 75.7% 0.18V 11.0% 688 0
8° 97.5% 99.8% 99.8% 75.7% 0.62V 11.0% 625 0
8° 97.5% 99.8% 99.8% 74.9% 0.23V 11.0% 563 0
8° 97.5% 99.8% 99.8% 78.8% 0.06V 11.0% 594 0
8° 97.5% 99.8% 99.8% 81.1% 0.04V 11.0% 656 0
8° 97.5% 99.8% 99.8% 85.0% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 88.9% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 92.8% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 96.7% 0.02V 11.4% 719 0
8° 96.7% 99.8% 99.8% 100.6% 0.02V 14.1% 719 0
8° 96.7% 99.8% 99.8% 104.5% 0.00V 15.3% 750 0
8° 96.7% 99.8% 99.8% 109.2% 0.00V 15.3% 688 0
8° 96.7% 99.8% 99.8% 113.1% 0.00V 15.7% 750 0
8° 96.7% 99.8% 99.8% 115.4% 0.00V 16.1% 781 0
10° 96.7% 99.8% 99.8% 117.8% 0.00V 16.5% 844 0
11° 96.7% 99.8% 99.8% 119.3% 0.00V 16.5% 813 0
10° 96.7% 99.8% 99.8% 121.7% 0.00V 16.5% 781 0
9° 96.7% 99.8% 99.8% 124.0% 0.00V 16.5% 844 0
12° 96.7% 99.8% 99.8% 126.4% 0.02V 15.3% 875 0
11° 96.7% 99.8% 99.8% 128.7% 0.02V 15.3% 906 0
12° 96.7% 99.8% 99.8% 131.0% 0.02V 11.0% 1000 0
13° 96.7% 99.8% 99.8% 131.0% 0.78V 11.0% 1094 0
15° 96.7% 99.8% 99.8% 123.2% 0.82V 11.0% 1063 0
14° 96.7% 99.8% 99.8% 117.8% 0.70V 11.0% 969 0
12° 96.7% 99.8% 99.8% 118.6% 0.57V 11.0% 875 0
10° 96.7% 99.8% 99.8% 113.9% 0.84V 11.0% 750 0
8° 96.7% 99.8% 99.8% 109.2% 0.86V 11.0% 688 0
8° 96.7% 99.8% 99.8% 105.3% 0.86V 11.0% 656 0
8° 96.7% 99.8% 99.8% 101.4% 0.84V 11.0% 656 0
8° 96.7% 99.8% 99.8% 97.5% 0.84V 11.0% 688 0
8° 96.7% 99.8% 99.8% 93.6% 0.78V 11.0% 688 0
8° 96.7% 99.8% 99.8% 90.5% 0.29V 11.0% 688 0
8° 96.7% 99.8% 99.8% 93.6% 0.08V 11.0% 688 0
8° 96.7% 99.8% 99.8% 97.5% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 100.6% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 105.3% 0.06V 11.0% 688 0
8° 96.7% 99.8% 99.8% 108.4% 0.04V 11.0% 688 0
8° 96.7% 99.8% 99.8% 112.3% 0.10V 11.0% 719 0
8° 96.7% 99.8% 99.8% 113.9% 0.20V 11.0% 688 0
8° 96.7% 99.8% 99.8% 115.4% 0.12V 11.0% 750 0
8° 97.5% 99.8% 99.8% 117.0% 0.45V 11.0% 750 0
8° 97.5% 99.8% 99.8% 116.2% 0.60V 11.0% 781 0
8° 97.5% 99.8% 99.8% 113.1% 0.68V 11.0% 781 0
9° 97.5% 99.8% 99.8% 112.3% 0.14V 11.0% 813 0
9° 98.3% 99.8% 99.8% 114.7% 0.04V 11.0% 844 0
10° 98.3% 99.8% 99.8% 117.0% 0.04V 11.0% 844 0
10° 98.3% 99.8% 99.8% 118.6% 0.06V 11.0% 844 0
10° 98.3% 99.8% 99.8% 120.1% 0.59V 11.0% 844 0
10° 98.3% 99.8% 99.8% 117.0% 0.82V 11.0% 906 0
11° 99.1% 99.8% 99.8% 113.9% 0.84V 11.0% 938 0
12° 99.1% 99.8% 99.8% 110.0% 0.80V 11.0% 938 0
12° 99.1% 99.8% 99.8% 106.1% 0.80V 11.0% 938 0
12° 99.1% 99.8% 99.8% 102.2% 0.76V 11.0% 938 0
11° 99.8% 99.8% 99.8% 99.1% 0.64V 11.0% 906 0
11° 99.1% 99.8% 99.8% 100.6% 0.41V 11.0% 875 0
11° 99.8% 99.8% 99.8% 99.1% 0.74V 11.0% 875 0
11° 99.1% 99.8% 99.8% 95.2% 0.84V 11.0% 844 0
10° 99.1% 99.8% 99.8% 92.8% 0.82V 11.0% 844 0
10° 99.1% 99.8% 99.8% 88.9% 0.80V 11.0% 844 0
10° 99.1% 99.8% 99.8% 85.8% 0.76V 11.0% 844 0
10° 98.3% 99.8% 99.8% 84.2% 0.41V 11.0% 844 0
10° 98.3% 99.8% 99.8% 86.6% 0.10V 11.0% 844 0
10° 98.3% 99.8% 99.8% 88.9% 0.08V 11.0% 844 0
10° 98.3% 99.8% 99.8% 90.5% 0.08V 11.0% 844 0
10° 98.3% 99.8% 99.8% 92.8% 0.08V 11.0% 875 0
11° 97.5% 99.8% 99.8% 95.2% 0.08V 11.0% 875 0
11° 97.5% 99.8% 99.8% 96.7% 0.08V 11.0% 875 0
11° 97.5% 99.8% 99.8% 99.1% 0.06V 11.0% 875 0
11° 97.5% 99.8% 99.8% 101.4% 0.23V 11.0% 875 0
11° 97.5% 99.8% 99.8% 99.8% 0.76V 11.0% 875 0
11° 97.5% 99.8% 99.8% 96.7% 0.80V 11.0% 875 0
11° 97.5% 99.8% 99.8% 92.8% 0.70V 11.0% 875 0
10° 96.7% 99.8% 99.8% 92.0% 0.33V 11.0% 844 0
10° 96.7% 99.8% 99.8% 94.4% 0.14V 11.0% 844 0
10° 96.7% 99.8% 99.8% 96.7% 0.23V 11.0% 844 0
10° 96.7% 99.8% 99.8% 95.9% 0.68V 11.0% 844 0
10° 96.7% 99.8% 99.8% 92.8% 0.57V 11.0% 844 0
That might be easier to understand. Like I said above I need help tuning low throttle only. I have solved the creep problem and wot is tuned prety good. My problems are on low thr settings.
How can I get my low end torqe back? Can I lean the low throttle settings out some? It seems to me that I am running rich, am I wrong? Every once in a while my fto2 jumps up out of no where and that is what confuses me. :( Can sombody shed some light on this for me?
Here's an example of how to post a log, yours are completely unreadable. You'll never get any help with log posting like that.
RPM Knock Timing O2 Inj P/W TPS
4156 0 23 0.75 11.538 100
4344 0 17 0.78 15.385 100
4625 0 14 0.8 16.41 100
4844 0 15 0.8 16.41 100
4906 0 15 0.8 16.154 100
5094 0 16 0.8 16.154 100
5281 0 17 0.8 16.154 100
5438 0 18 0.8 16.154 100
5625 0 18 0.8 16.154 100
5750 0 19 0.8 16.154 100
5875 0 20 0.8 15.897 100
6000 0 20 0.8 15.897 100
6125 0 21 0.8 15.641 100
6250 0 21 0.8 15.385 100
6375 0 23 0.8 14.872 100
6469 0 23 0.8 14.615 100
6625 0 23 0.8 14.103 100
6781 0 24 0.8 13.59 100
6844 0 24 0.8 13.59 100
nice logs ;)
Tima Fto2 O2-r Tps Rpm Knck Injp
12° 98.3% 0.14v 10.6% 938 0
12° 99.1% 0.16v 10.6% 938 0
12° 99.8% 0.29v 10.6% 938 0
12° 101.4% 0.41v 10.6% 938 0
12° 101.4% 0.39v 10.6% 969 0
12° 100.6% 0.51v 10.6% 969 0
12° 99.1% 0.53v 10.6% 938 0
12° 97.5% 0.47v 10.6% 938 0
12° 97.5% 0.45v 10.6% 938 0
12° 96.7% 0.45v 10.6% 938 0
12° 96.7% 0.41v 10.6% 938 0
12° 97.5% 0.27v 10.6% 906 0
11° 98.3% 0.20v 10.6% 906 0
11° 99.8% 0.10v 10.6% 906 0
11° 100.6% 0.06v 10.6% 906 0
11° 101.4% 0.10v 10.6% 906 0
11° 102.2% 0.18v 10.6% 906 0
11° 103.0% 0.45v 10.6% 906 0
11° 103.0% 0.60v 10.6% 938 0
11° 101.4% 0.64v 10.6% 938 0
12° 99.8% 0.64v 10.6% 938 0
12° 98.3% 0.64v 10.6% 938 0
12° 96.7% 0.64v 10.6% 938 0
12° 95.2% 0.62v 10.6% 938 0
12° 93.6% 0.57v 10.6% 938 0
12° 92.0% 0.59v 10.6% 938 0
12° 91.3% 0.39v 10.6% 938 0
12° 92.8% 0.20v 10.6% 938 0
11° 93.6% 0.08v 10.6% 906 0
11° 94.4% 0.02v 10.6% 906 0
11° 95.9% 0.00v 10.6% 906 0
11° 96.7% 0.00v 10.6% 906 0
11° 97.5% 0.00v 10.6% 906 0
11° 98.3% 0.00v 10.6% 906 0
11° 99.8% 0.00v 10.6% 938 0
11° 100.6% 0.00v 10.6% 938 0
12° 101.4% 0.12v 10.6% 938 0
12° 103.0% 0.45v 10.6% 938 0
12° 102.2% 0.57v 10.6% 938 0
12° 100.6% 0.60v 10.6% 969 0
12° 98.3% 0.60v 10.6% 969 0
12° 97.5% 0.59v 10.6% 969 0
12° 95.9% 0.53v 10.6% 938 0
12° 94.4% 0.41v 10.6% 938 0
12° 95.9% 0.33v 10.6% 938 0
12° 96.7% 0.29v 10.6% 938 0
12° 97.5% 0.16v 10.6% 938 0
12° 99.1% 0.18v 10.6% 938 0
12° 99.8% 0.23v 10.6% 938 0
12° 100.6% 0.21v 10.6% 938 0
12° 102.2% 0.33v 10.6% 938 0
12° 103.0% 0.43v 10.6% 938 0
12° 102.2% 0.57v 10.6% 969 0
12° 99.1% 0.60v 10.6% 969 0
12° 95.9% 0.59v 10.6% 938 0
12° 93.6% 0.59v 10.6% 938 0
12° 92.8% 0.59v 10.6% 938 0
12° 92.8% 0.49v 10.6% 938 0
12° 93.6% 0.31v 10.6% 938 0
12° 94.4% 0.18v 10.6% 938 0
12° 95.2% 0.12v 10.6% 969 0
12° 96.7% 0.08v 10.6% 969 0
12° 97.5% 0.06v 10.6% 938 0
12° 99.1% 0.04v 10.6% 938 0
12° 99.8% 0.02v 10.6% 969 0
12° 100.6% 0.02v 10.6% 969 0
12° 102.2% 0.08v 10.6% 938 0
12° 103.0% 0.08v 10.6% 938 0
12° 103.7% 0.14v 10.6% 906 0
11° 105.3% 0.27v 10.6% 875 0
10° 106.1% 0.41v 10.6% 844 0
10° 106.1% 0.51v 10.6% 813 0
9° 104.5% 0.60v 10.6% 813 0
9° 103.7% 0.64v 10.6% 813 0
9° 102.2% 0.66v 10.6% 813 0
9° 100.6% 0.66v 10.6% 813 0
9° 99.8% 0.66v 10.6% 813 0
10° 98.3% 0.64v 10.6% 844 0
10° 96.7% 0.64v 10.6% 875 0
11° 95.2% 0.64v 10.6% 906 0
11° 93.6% 0.62v 10.6% 906 0
11° 92.8% 0.64v 10.6% 906 0
11° 90.5% 0.64v 10.6% 938 0
12° 89.7% 0.57v 10.6% 938 0
12° 88.1% 0.57v 10.6% 938 0
11° 88.1% 0.39v 10.6% 906 0
11° 89.7% 0.20v 10.6% 906 0
11° 90.5% 0.10v 10.6% 875 0
11° 91.3% 0.04v 10.6% 875 0
11° 92.8% 0.02v 10.6% 875 0
11° 93.6% 0.00v 10.6% 875 0
11° 94.4% 0.02v 10.6% 875 0
11° 95.2% 0.18v 10.6% 875 0
11° 95.9% 0.49v 10.6% 906 0
11° 95.2% 0.59v 10.6% 875 0
11° 93.6% 0.59v 10.6% 875 0
11° 92.0% 0.59v 10.6% 844 0
10° 91.3% 0.53v 10.6% 844 0
10° 89.7% 0.45v 10.6% 813 0
10° 90.5% 0.43v 10.6% 813 0
9° 91.3% 0.23v 10.6% 781 0
9° 92.0% 0.18v 10.6% 781 0
9° 92.8% 0.14v 10.6% 781 0
9° 93.6% 0.06v 10.6% 750 0
8° 94.4% 0.02v 10.6% 750 0
8° 95.2% 0.00v 10.6% 719 0
8° 95.9% 0.00v 10.6% 719 0
8° 96.7% 0.00v 11.4% 719 0
8° 97.5% 0.00v 14.5% 688 0
8° 98.3% 0.06v 15.7% 719 0
8° 99.1% 0.00v 16.1% 750 0
9° 100.6% 0.00v 16.5% 875 0
13° 101.4% 0.00v 16.5% 1000 0
16° 102.2% 0.00v 16.5% 1125 0
18° 106.9% 0.00v 16.5% 1188 0
20° 110.0% 0.00v 16.5% 1250 0
21° 113.1% 0.12v 16.5% 1250 0
20° 117.0% 0.43v 16.5% 1250 0
20° 119.3% 0.51v 11.4% 1219 0
19° 116.2% 0.60v 11.0% 1156 0
17° 113.1% 0.68v 11.0% 1125 0
16° 110.0% 0.70v 11.0% 1188 0
16° 106.9% 0.70v 11.0% 1188 0
17° 103.7% 0.70v 11.0% 1188 0
16° 100.6% 0.68v 11.0% 1156 0
16° 97.5% 0.68v 11.0% 1094 0
15° 94.4% 0.66v 11.0% 1031 0
14° 91.3% 0.60v 11.0% 969 0
12° 90.5% 0.43v 11.0% 906 0
11° 92.8% 0.21v 11.0% 875 0
10° 95.2% 0.14v 11.0% 813 0
9° 96.7% 0.27v 11.0% 781 0
9° 97.5% 0.59v 11.0% 750 0
8° 95.9% 0.64v 11.0% 719 0
8° 93.6% 0.66v 11.0% 719 0
8° 92.0% 0.66v 11.0% 719 0
8° 90.5% 0.66v 11.0% 719 0
8° 88.1% 0.60v 11.0% 719 0
8° 86.6% 0.55v 11.0% 719 0
8° 85.0% 0.45v 11.0% 719 0
8° 86.6% 0.16v 11.0% 719 0
8° 88.1% 0.04v 11.0% 719 0
8° 89.7% 0.00v 11.0% 750 0
8° 91.3% 0.00v 11.0% 719 0
8° 93.6% 0.00v 11.0% 750 0
8° 95.2% 0.00v 11.0% 750 0
8° 96.7% 0.00v 11.0% 750 0
8° 99.1% 0.00v 11.0% 750 0
8° 100.6% 0.00v 11.0% 750 0
8° 103.0% 0.00v 11.0% 781 0
8° 104.5% 0.00v 11.0% 750 0
8° 106.1% 0.00v 11.0% 781 0
8° 108.4% 0.00v 11.0% 781 0
9° 110.0% 0.00v 11.0% 813 0
9° 112.3% 0.00v 11.0% 813 0
10° 113.9% 0.41v 11.0% 844 0
10° 114.7% 0.55v 11.0% 875 0
10° 112.3% 0.59v 12.2% 875 0
11° 110.0% 0.59v 13.3% 875 0
11° 109.2% 0.45v 13.3% 938 0
11° 110.0% 0.60v 13.7% 969 0
13° 108.4% 0.66v 14.1% 1031 0
14° 106.1% 0.66v 14.5% 1094 0
16° 104.5% 0.62v 14.5% 1125 0
16° 101.4% 0.47v 14.5% 1125 0
16° 103.7% 0.21v 14.5% 1125 0
16° 106.9% 0.04v 14.5% 1094 0
16° 109.2% 0.00v 14.5% 1063 0
15° 111.5% 0.00v 14.5% 1000 0
13° 113.9% 0.00v 14.5% 969 0
13° 116.2% 0.45v 14.5% 906 0
12° 114.7% 0.64v 14.5% 875 0
10° 112.3% 0.66v 14.9% 813 0
9° 110.0% 0.66v 14.9% 750 0
8° 107.6% 0.66v 11.0% 750 0
8° 105.3% 0.57v 11.0% 750 0
8° 103.0% 0.62v 11.0% 813 0
10° 100.6% 0.68v 11.0% 906 0
11° 98.3% 0.70v 11.0% 1000 0
13° 95.9% 0.68v 11.0% 1063 0
15° 92.8% 0.64v 11.0% 1125 0
16° 89.7% 0.49v 11.0% 1125 0
16° 92.8% 0.23v 11.0% 1125 0
16° 95.2% 0.06v 11.0% 1094 0
15° 97.5% 0.00v 11.0% 1063 0
14° 99.8% 0.00v 11.0% 1031 0
13° 103.0% 0.00v 11.0% 969 0
13° 105.3% 0.00v 11.0% 938 0
12° 107.6% 0.00v 11.0% 906 0
11° 109.2% 0.37v 11.0% 906 0
11° 109.2% 0.60v 11.0% 875 0
11° 106.9% 0.66v 11.0% 875 0
11° 105.3% 0.66v 11.0% 875 0
10° 103.0% 0.68v 11.0% 875 0
10° 100.6% 0.68v 11.0% 875 0
11° 98.3% 0.68v 11.0% 875 0
10° 95.9% 0.68v 11.0% 875 0
10° 94.4% 0.68v 11.0% 844 0
10° 92.0% 0.68v 11.0% 813 0
9° 89.7% 0.62v 11.0% 781 0
9° 88.1% 0.64v 11.0% 750 0
8° 86.6% 0.57v 11.0% 719 0
8° 83.5% 0.59v 11.0% 719 0
8° 84.2% 0.37v 11.0% 688 0
8° 85.8% 0.18v 11.0% 719 0
8° 87.4% 0.08v 11.0% 719 0
8° 89.7% 0.04v 11.0% 750 0
8° 91.3% 0.02v 13.7% 781 0
8° 93.6% 0.00v 16.1% 813 0
9° 95.9% 0.00v 16.5% 844 0
10° 99.1% 0.00v 16.9% 969 0
15° 102.2% 0.00v 17.3% 1125 0
19° 106.1% 0.00v 17.3% 1250 0
22° 110.0% 0.00v 17.3% 1313 0
23° 114.7% 0.39v 18.4% 1313 0
23° 113.9% 0.59v 19.6% 1281 0
24° 110.0% 0.47v 20.0% 1313 0
25° 114.7% 0.20v 20.4% 1313 0
25° 120.1% 0.00v 20.4% 1281 0
24° 124.0% 0.00v 20.4% 1219 0
23° 127.9% 0.00v 20.4% 1156 0 This is where things lean out.
22° 131.8% 0.00v 20.8% 1156 0
21° 136.5% 0.27v 20.8% 1156 0
21° 140.4% 0.49v 20.8% 1125 0
20° 138.1% 0.59v 20.8% 1125 0
20° 133.4% 0.57v 20.8% 1125 0
20° 134.9% 0.33v 20.8% 1125 0
20° 138.8% 0.10v 20.8% 1188 0
22° 142.7% 0.04v 21.2% 1281 0
25° 147.4% 0.41v 21.2% 1375 0
26° 144.3% 0.64v 21.2% 1438 0
27° 138.8% 0.66v 21.6% 1531 0
28° 132.6% 0.64v 21.6% 1594 0
29° 127.1% 0.66v 23.9% 1656 0
29° 120.1% 0.49v 24.3% 1781 0
29° 116.2% 0.66v 24.3% 1875 1
28° 108.4% 0.62v 24.3% 1938 1
29° 102.2% 0.55v 24.3% 2031 1
30° 96.7% 0.45v 24.7% 2094 0
31° 107.6% 0.18v 24.7% 2188 0
31° 116.2% 0.29v 24.7% 2281 0
32° 116.2% 0.64v 24.7% 2344 0
32° 108.4% 0.64v 24.7% 2406 0
33° 99.1% 0.60v 24.7% 2469 0
33° 95.2% 0.35v 24.7% 2531 0
34° 106.1% 0.14v 24.7% 2594 0
35° 114.7% 0.60v 24.7% 2656 0
35° 104.5% 0.64v 24.7% 2719 0
36° 94.4% 0.53v 24.7% 2750 0
36° 103.7% 0.14v 24.7% 2844 0
36° 115.4% 0.10v 24.7% 2875 0
37° 123.2% 0.57v 15.3% 2969 0
38° 113.9% 0.70v 10.6% 2844 0
39° 106.1% 0.74v 10.6% 2781 0
39° 99.8% 0.72v 10.6% 2656 0
38° 99.8% 0.64v 10.6% 2500 0
38° 99.8% 0.60v 10.6% 2344 0
38° 99.8% 0.47v 10.6% 2219 0
37° 99.8% 0.18v 10.6% 2094 0
37° 99.8% 0.12v 10.6% 1969 0
35° 99.8% 0.08v 10.6% 1875 0
32° 99.8% 0.14v 11.0% 1719 0
30° 99.8% 0.04v 11.0% 1625 0
27° 99.8% 0.10v 11.0% 1594 0
26° 99.1% 0.64v 11.0% 1625 0
27° 95.2% 0.68v 11.4% 1656 0
28° 90.5% 0.70v 11.4% 1625 0
27° 85.0% 0.70v 11.8% 1625 0
27° 81.1% 0.70v 11.8% 1625 0
My safc2 settings are as follows
Low point 40% high 80%
low thr
800 +27
1600+35
2200+35
3200+23
4200+13
5000+13
5400+13
6000+13
6400+13
7000+13
7400+13
High thr
800+27
1600+35
2200+35
3200+23
4200+23
5000+28
5400+28
6000+28
6400+28
7000+28
7400+27
Am I doing somthing wrong? What do you recamend that I do next? What is causing these whacky air fuel ratios on low throttle? I need some help espashaly in the 800-4200 range. Please help.
Most of it looks pretty normal. This one section looks alittle lean, you can try adding more fuel hear and see what happens.
Do you think this lean condition could be caused by the stock injectors? As you can see I am pushing them prety hard already. Also my gas milage is terible. Did I tune right on high thr from 800-4200? I just caried over from low throtle settings. I think thats what your suppose to do? Please corect me if I'm wrong.
I will use these settings on data file 1 for everyday driving.
I have moved my throttle points to:
Low 30% high 80%
My net points have changed to:
Low thr
800 +19
1200 +28 I was able to get the low fuel trim in line this way.
2000 +28
2400 +26
2800 +26
3000 +19
4000 +13
5000 +13
6000 +13
6400 +13
7000 +13
7400 +13
High thr
800 +19 These settings will not work for high throttle.
1200 +28 Too much knock and not enouph adjustment.
2000 +28
2400 +26
2800 +26
3000 +25
4000 +28
5000 +28
6000 +28
6400 +28
7000 +28
7400 +27
So this is what I did for high throttle settings where I needed more adjustment. I opened data file 2 and this is what I will use for racing.
High thr
800 +20
1600 +26
2200 + 26
3200 + 19
4000 + 28
4400 +28
5000 +28
5400 +28
6000 +28
6400 +28
7000 +28 Steady timing curve, peak of 22*
7400 +28 This is with no knock and o2's around .90 at 15-17psi
This is the only thing I could think of to get the adjustment I needed.
Latest datalog at wot.
timadv ltft o2ft 02r tps rpm knock
38° 87.4% 99.8% 0.31V 93.7% 2656 5
25° 87.4% 99.8% 0.86V 100.0% 2656 5
25° 87.4% 99.8% 0.88V 100.0% 2625 5
24° 87.4% 99.8% 0.88V 100.0% 2656 4
23° 87.4% 99.8% 0.88V 100.0% 2688 4
22° 87.4% 99.8% 0.88V 100.0% 2750 4
20° 87.4% 99.8% 0.88V 100.0% 2781 4
20° 87.4% 99.8% 0.88V 100.0% 2844 3
19° 87.4% 99.8% 0.88V 100.0% 2906 3
18° 87.4% 99.8% 0.88V 100.0% 2938 3
17° 87.4% 99.8% 0.88V 100.0% 3031 2
14° 87.4% 99.8% 0.88V 100.0% 3063 2
17° 87.4% 99.8% 0.88V 100.0% 3125 2
17° 87.4% 99.8% 0.88V 100.0% 3219 2
18° 87.4% 99.8% 0.88V 100.0% 3281 1
20° 87.4% 99.8% 0.88V 100.0% 3313 1
20° 87.4% 99.8% 0.86V 100.0% 3406 1
21° 87.4% 99.8% 0.88V 100.0% 3500 0
22° 87.4% 99.8% 0.86V 100.0% 3531 0
22° 87.4% 99.8% 0.86V 100.0% 3625 0
22° 87.4% 99.8% 0.86V 100.0% 3688 0
22° 87.4% 99.8% 0.86V 100.0% 3781 0
22° 87.4% 99.8% 0.86V 100.0% 3844 0
21° 87.4% 99.8% 0.86V 100.0% 3875 0
21° 87.4% 99.8% 0.88V 100.0% 3969 0
21° 87.4% 99.8% 0.88V 100.0% 4063 0
21° 87.4% 99.8% 0.88V 100.0% 4156 0
21° 87.4% 99.8% 0.88V 100.0% 4219 0
21° 87.4% 99.8% 0.88V 100.0% 4250 0
22° 87.4% 99.8% 0.88V 100.0% 4313 0
21° 87.4% 99.8% 0.88V 100.0% 4438 0
21° 87.4% 99.8% 0.88V 100.0% 4406 1
20° 87.4% 99.8% 0.88V 100.0% 4688 1
20° 87.4% 99.8% 0.88V 100.0% 4594 1
18° 87.4% 99.8% 0.88V 100.0% 4688 0
19° 87.4% 99.8% 0.88V 100.0% 4813 0
20° 87.4% 99.8% 0.88V 100.0% 4875 0
19° 87.4% 99.8% 0.88V 100.0% 4844 0
19° 87.4% 99.8% 0.88V 100.0% 5000 0
19° 87.4% 99.8% 0.88V 100.0% 5094 0
19° 87.4% 99.8% 0.88V 100.0% 5094 2
19° 87.4% 99.8% 0.88V 100.0% 5219 1
20° 87.4% 99.8% 0.88V 100.0% 5250 1
21° 87.4% 99.8% 0.88V 100.0% 5313 1
21° 87.4% 99.8% 0.88V 100.0% 5406 1
21° 87.4% 99.8% 0.88V 100.0% 5406 0
22° 87.4% 99.8% 0.88V 100.0% 5531 0
22° 87.4% 99.8% 0.88V 100.0% 5719 0
22° 87.4% 99.8% 0.88V 100.0% 5688 0
22° 87.4% 99.8% 0.88V 100.0% 5844 0
23° 87.4% 99.8% 0.88V 100.0% 5813 0
23° 87.4% 99.8% 0.88V 100.0% 5844 0
24° 87.4% 99.8% 0.88V 100.0% 6063 0
24° 87.4% 99.8% 0.88V 100.0% 6156 0
24° 87.4% 99.8% 0.88V 100.0% 6094 1
22° 87.4% 99.8% 0.88V 100.0% 6250 1
22° 87.4% 99.8% 0.88V 100.0% 6219 0
21° 87.4% 99.8% 0.88V 100.0% 6344 0
22° 87.4% 99.8% 0.86V 100.0% 6313 7
17° 87.4% 99.8% 0.86V 100.0% 6438 7
18° 87.4% 99.8% 0.86V 100.0% 6469 6
18° 87.4% 99.8% 0.86V 100.0% 6531 6
18° 87.4% 99.8% 0.86V 100.0% 6563 6
18° 87.4% 99.8% 0.86V 100.0% 6656 7
16° 87.4% 99.8% 0.88V 100.0% 6750 6
17° 87.4% 99.8% 0.88V 100.0% 6688 6
17° 87.4% 99.8% 0.88V 100.0% 6781 6
16° 87.4% 99.8% 0.88V 100.0% 6781 7
15° 87.4% 99.8% 0.88V 100.0% 6938 6
16° 87.4% 99.8% 0.88V 100.0% 7031 6
16° 87.4% 99.8% 0.88V 100.0% 7000 6
16° 87.4% 99.8% 0.88V 100.0% 6938 6
16° 87.4% 99.8% 0.88V 100.0% 7000 5
16° 87.4% 99.8% 0.88V 100.0% 7031 5
Time before that with the same settings. notice the higer 02 voltage and less timing
timad ltft 02ft 02r tps rpm knock
25° 81.1% 99.8% 0.86V 92.9% 1969 0
22° 81.1% 99.8% 0.90V 100.0% 2000 0
21° 81.1% 99.8% 0.90V 100.0% 2063 0
21° 81.1% 99.8% 0.92V 100.0% 2094 0
20° 81.1% 99.8% 0.92V 100.0% 2156 0
19° 81.1% 99.8% 0.92V 100.0% 2188 0
17° 81.1% 99.8% 0.94V 100.0% 2219 0
15° 81.1% 99.8% 0.94V 100.0% 2250 0
16° 81.1% 99.8% 0.94V 100.0% 2313 0
17° 81.1% 99.8% 0.92V 100.0% 2344 0
17° 81.1% 99.8% 0.92V 100.0% 2406 0
18° 81.1% 99.8% 0.92V 100.0% 2469 0
19° 81.1% 99.8% 0.90V 100.0% 2531 0
19° 81.1% 99.8% 0.90V 100.0% 2594 0
18° 81.1% 99.8% 0.90V 100.0% 2656 0
17° 81.1% 99.8% 0.90V 100.0% 2688 0
16° 81.1% 99.8% 0.90V 100.0% 2719 0
16° 81.1% 99.8% 0.90V 100.0% 2781 0
16° 81.1% 99.8% 0.90V 100.0% 2875 0
16° 81.1% 99.8% 0.90V 100.0% 2938 0
17° 81.1% 99.8% 0.90V 100.0% 3000 0
17° 81.1% 99.8% 0.90V 100.0% 3094 0
17° 81.1% 99.8% 0.90V 100.0% 3125 0
18° 81.1% 99.8% 0.90V 100.0% 3188 0
18° 81.1% 99.8% 0.90V 100.0% 3219 0
19° 81.1% 99.8% 0.90V 100.0% 3344 0
20° 81.1% 99.8% 0.90V 100.0% 3406 0
21° 81.1% 99.8% 0.90V 100.0% 3469 0
21° 81.1% 99.8% 0.90V 100.0% 3531 0
21° 81.1% 99.8% 0.90V 100.0% 3594 0
22° 81.1% 99.8% 0.90V 100.0% 3656 0
22° 81.1% 99.8% 0.90V 100.0% 3719 0
21° 81.1% 99.8% 0.90V 100.0% 3813 0
21° 81.1% 99.8% 0.90V 100.0% 3938 0
21° 81.1% 99.8% 0.90V 100.0% 4094 0
21° 81.1% 99.8% 0.90V 100.0% 4156 0
21° 81.1% 99.8% 0.92V 100.0% 4156 0
21° 81.1% 99.8% 0.92V 100.0% 4281 0
21° 81.1% 99.8% 0.90V 100.0% 4406 0
21° 81.1% 99.8% 0.90V 100.0% 4344 0
20° 81.1% 99.8% 0.92V 100.0% 4531 0
20° 81.1% 99.8% 0.90V 100.0% 4594 0
18° 81.1% 99.8% 0.90V 100.0% 4656 0
19° 81.1% 99.8% 0.92V 100.0% 4750 0
19° 81.1% 99.8% 0.92V 100.0% 4781 0
19° 81.1% 99.8% 0.90V 100.0% 4875 0
19° 81.1% 99.8% 0.90V 100.0% 4938 0
19° 81.1% 99.8% 0.90V 100.0% 4938 1
18° 81.1% 99.8% 0.90V 100.0% 5094 0
19° 81.1% 99.8% 0.90V 100.0% 5125 0
20° 81.1% 99.8% 0.90V 100.0% 5250 0
20° 81.1% 99.8% 0.90V 100.0% 5375 0
20° 81.1% 99.8% 0.90V 100.0% 5438 0
20° 81.1% 99.8% 0.90V 100.0% 5563 0
21° 81.1% 99.8% 0.90V 100.0% 5656 2
20° 81.1% 99.8% 0.90V 100.0% 5625 1
21° 81.1% 99.8% 0.90V 100.0% 5688 1
21° 81.1% 99.8% 0.90V 100.0% 5781 1
22° 81.1% 99.8% 0.90V 100.0% 5906 7
21° 81.1% 99.8% 0.90V 100.0% 5906 6
21° 81.1% 99.8% 0.90V 100.0% 5938 6
21° 81.1% 99.8% 0.90V 100.0% 6094 6
21° 81.1% 99.8% 0.90V 100.0% 6125 6
20° 81.1% 99.8% 0.90V 100.0% 6094 5
20° 81.1% 99.8% 0.90V 100.0% 6156 5
19° 81.1% 99.8% 0.88V 100.0% 6281 5
19° 81.1% 99.8% 0.88V 100.0% 6344 5
18° 81.1% 99.8% 0.88V 100.0% 6469 4
20° 81.1% 99.8% 0.90V 100.0% 6469 4
18° 81.1% 99.8% 0.90V 100.0% 6531 4
18° 81.1% 99.8% 0.88V 100.0% 6594 5
18° 81.1% 99.8% 0.90V 100.0% 6625 4
17° 81.1% 99.8% 0.90V 100.0% 6688 4
17° 81.1% 99.8% 0.90V 100.0% 6781 4
17° 81.1% 99.8% 0.90V 100.0% 6844 4
17° 81.1% 99.8% 0.90V 100.0% 6875 3
17° 81.1% 99.8% 0.90V 100.0% 6813 3
18° 81.1% 99.8% 0.90V 100.0% 6938 3
17° 81.1% 99.8% 0.90V 100.0% 6969 3
17° 81.1% 99.8% 0.90V 100.0% 7031 2
17° 81.1% 99.8% 0.90V 100.0% 7125 2
17° 81.1% 99.8% 0.90V 100.0% 7188 2
17° 81.1% 99.8% 0.90V 90.2% 7250 1
