LOGGED really high timing...
terminaltsi
309
Dec 16, 2001
louisville, Kentucky
well i made a run this weekend, with some 110 octane, found my knock to be 0, boost at 12 psi, 45* timing at 68xx rpm.... car felt good, egt's were cool at approx 840, 02 at .86v.....
does anyone think my timing is a little high though?
i'm only at 12 psi because my boost controller is not quite dialed in yet, having some stability problems, not creep, but loss of boost after peak boost is reached.
I bet you one hundred bucks you saw that timing right before you lifted to shift, right?
You weren't full throttle anymore, look at the log carefully.
Yeah, highly doubtful that you were really @WOT. You shouldn't be seeing that kind of timing unless its closed loop.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
