Log question
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
My first question is can i shift at 5k when i log, i know your suppose to take it to 7k but i have my boost set at 15 psi and after 5k it creeps to 20psi, so can i do a log till ~5k. And my second question is how do i get my logs on here, i can't copy and paste?
You should fix the creep before you attempt to do any tuning, otherwise it's just a waste of time.
the reason i am asking casue it will be at least a week or so to get everthing in and running,and i keep pulling fuel trim malf code, i reset it everyday and it comes back
As CanadianTSi said, FT's are only used at idle and cruise, so that has nothing to do with your other problems. On that note, what is your O2 voltage while you are at idle?
Normally a FT malfunction is becuase your O2 is shot and the ECU has reached it's limits of compensation. The other thing that can cause that problem is when you have your lo throttle SAFC setting all screwed up. :thumb:
