Log Help
TinoTalon
Mar 28, 2010
New Britain, Connecticut
So I pulled a log last night 3rd gear 2k-7k Can someone help me out on correcting the issues here? I'd really hate to have to pay someone to do it out here when i could do it myself.
Please fill out your profile so we know what mods you have.
I'm not sure why you've adjusted the MAF Clamp feature, but don't have it turned on. Your log shows you don't go above 2400Hz so there isn't really a need for it.
I'm guessing you have a GM MAF with MAFT?
You should get some larger injectors or turn the boost down, since your IDC % peaked around 95%.
I'd also recommend getting a wideband sensor.
Im an idiot, should have posted the setup, but i got distracted and ran out the door right after....
Wiesco 9:1 pistons
Carillo Rods
E316G
RC550 injectors
Aeromotive AFPR
FMIC 2" Piping
2.5" Exhaust Turbo back
Wally 255
Link 2.5 using v3 software
It is a GM MAF w/ MAFT
I do have a PLX wideband and I see AFRs from 11.3-10.2 @ WOT
I'm not a Link user nor a professional tuner but maybe you could...
Log your wideband?
linearitems [ECMTuning - wiki]
R-500 installation instructions (info you need on page 9-10)
It's tough for me to make any assumptions about AFR or MAF values and delivered fuel accuracy without seeing wideband or MAP and calculated load values in the same log, mainly since that's what I'm used to. Based only on throttle position, the turbo you're using and logged rpm, it looks like you have an issue during spool-up. Detonation is tough to quell once it gets started and it looks like the ECU is fighting with knock sensor feedback through that whole log. Your commanded timing appears to be relatively in the ballpark, possibly slightly aggressive depending on how much boost the engine is seeing, so I'm wondering if your base timing might not really be 5* BTDC. If base timing checks out good, you might try dropping the timing adjustments to -4, -6, -7, -6 starting at 3000 up to 4500 to see if that gets rid of the abrupt onset of knock.
as soon as I get into boost, my AFRs are richer than i feel they need to be, all the way out... i know too rich LOL ive questioned my base timing, but I also have an unorthodox crank pulley which I've heard the markings are off on... So I need to find a stock one to set the base timing.
LOL @ how rich i am under accel.. hows 9.9 sound? thanks for that like that helps alot, I'll use this method when I pick up my timing light this weekend.
I think your wideband might deserve checking. If you hold the sensor in free air outside the exhaust, does it read max lean at 20:1 AFR? Your stock narrowband is indicating rich, but at ~10:1 it should be reading a full rich 1.00v.
  • Wanted 6 bolt NT water pipe
    • chrisman287
