nightmares GS-T
- 332
- 3
- Aug 18, 2009
Pearl,
Mississippi
Alright I recently changed my leaking tubular manifold with an erl and installed the innovate mtxl wideband along with my FP 3582r hta. Now I only got one pull out of the 35r before it died tragically. Sending it to fp tomorrow. Anyway put my 50 trim back on and went for a cruise and its pretty rough. Mechanically the only change is a non leaking manifold and now im simulating the narrow band and my afrs are all over the place. Ive tried to adjust the sliders a bit to fix idle and have been trying to work on cruise but I cant seem to get it right. Can anyone take a look at the log and tell me what im doing wrong?
. The sensor is directly after the turbo in the o2 housing. As for exhaust leaks shouldnt be any as theres only 2 spots it could leak. The turbo to manifold gasket is brand new and the o2 housing to turbo is v band so it also shouldnt be leaking. As for boost leaks none. The only one is from today when the boost gauge line blew off. Its fixed now. I would be happy to check for exhaust leaks. Is there a way to do it without damaging my sensor? Also would like to note that the sensor does seem to be accurate because everytime it starts jumping around once it goes above 17 afr it starts sputtering and you can feel the car lose power until it stops.
