Limited Slip/ Locked Differential ?
If your talking about a 4bold rear LSD yes... the ones that were made before june of 1992 i believe. On the side of the drivers side door there should be a sticker that says if it is equipped with LSD.
Hope this works, not really sure what you want to know
-ADAM-:talon:
yes it does have limited slip.............. what would happen if you rotated a tire while it was on jack stands ?
or does that only apply when it was started ?
